Question about Jenn-Air JGS9900BDS Stainless Steel Gas Kitchen Range
Jenn Aire JGS9900BDS
Electronic display stopped working and oven does not work. Cook top still works, unit has 110V & gas supply OK
  • mcintd02 Nov 30, 2008
    Top 2 rows of digital display (numbers) stopped working and oven turns off, then back on. Same if I try to broil.
It is probably the control board. Mine did this and they changed the control board.
Posted on Dec 13, 2008
. Burners will not work unless the down draft fan is turned on and then neither works at full capacity.I flipped the breaker off and on.
Call Jenn-Aire to have a technician troubleshoot your cook top on site. You will save time and aggravation whether your cook top is gas or electric, possibly wired improperly, etc,etc,etc.
Apr 02, 2015 | Jenn-Air Cooktops
I have a jenn air jgs9900bds maytag and the display doesnt work at all it beeps but it doesnt do anything...i cant cook obviosly by this problem helpppp!!!
On something like this you have 3 components that could cause this symptom. The touch pad, display & main control board. The main control board should provide 12 volts DC to the touch pad & display boards. Test pins J1-2 to J1-1, J4-2 to J1-1 & J5-1 to J1-1 should all have 12 volts DC.
Oct 15, 2011 | Jenn-Air JGS9900BDS Stainless Steel Gas...
Oven will not ignite
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Dec 27, 2010 | Jenn-Air JGS9900BDS Stainless Steel Gas...
Oven heats very slowly (Jenn-Air JGS9900BDS). Cooktop works fine. Broiler works. No error codes.
hi, Could be a bad bake element or a bad temperature sensor. If the element will glow bright red/orange with no hotspots it is OK. Take a volt/ohm meter set for ohms and check the temp sensor. If less than 1050 ohms replace it.
NephetZ
Jul 08, 2009 | Jenn-Air JGS9900BDS Stainless Steel Gas...
Two of the oven controls do on function on SVE47500W
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 24, 2008 | Ovens
Jenn Air JMW8530CAB time/temperature light don't work
Steve Patterson
303-256-8494
Nov 18, 2008 | Jenn-Air JMW8530C Electric Double Oven
Wiring 4 wire cook top to 3 wire outlet
What you have is a 220v and a 110v circuit within the cook top. It needs a 4 wire feed to supply 2 hots, 1ground, and 1 neutral. The 3 wire outlet only has 2hots and a ground no neutral, which will probably not allow your control circuit to operate. You nee to run a neutral wire to obtain a 110v circuit. DO NOT try to run neutral off the ground or you will energize your cook top cabinet and it will shock you. Your solution is to run a neutarl wire from the closest circuit that you can find.
If you need further asst.
Eboukater@gmail.com
Sep 24, 2008 | Jenn-Air JJW8530C Expressions Collection...
Wiring diagram
This model of cook top needs the 4 wire install because it has both 220v and 110v circuits. The forth wire is a neutral that operates the 110v circuit. You can move the ground of the 3 wire outlet to neutral, but ONLY! if the ground wire is insulated. What this will do is give you both your 220v and 110v circuits. The problem with that is your cook top will not be grounded. The best solution is to locate a neutral wire and tap into it, this will give you your 4 wire circuit. Your missing a neutral in a 3 wire outlet.
More Asst.
eboukater@gmail.com
Electronic touch pad problems
From what your telling me, you have tried all the numbers and only 1,4 and 7 beep when touched. Also, the timer display was set at 0:00 when you started. Also, you followed the manual's instructions first, and looked in the back of your manual in the trouble section, and found no answer.
Did you timer ever work? If not, you should be able to a free replacement of the control panel module from an authorized Jenn-Air repair company. It may be a good idea to contact Jenn-Air first.
The timer shows only hours and minutes when first started. For example 2:05 is two hours and five minutes. It goes into the seconds mode only during the last minute.
Dec 01, 2007 | Jenn-Air JGR8875QDS Gas Kitchen Range
Jenn-Air JGS9900BDS Stainless Steel Gas Kitchen Range Logo
566 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
