Question about John Deere 4020 Gas & Diesel Tractor Radiator
Location of push pull cable on a John Deere 4020 stuck in park
  • 14 Answers
SOURCE: 1969 John Deere 4020 won't start
Replace solonoid
Posted on May 29, 2009
  • 4 Answers
SOURCE: 4020 w/ 24v system sparks when the battery is connected
I usually fix electrical problems by process of elimination. Disconnect the wires attached to generator and touch the battery cable to the battery if it still arcs disconnect the regulator. continue until you find whats pulling current from the battery.
Posted on Jun 05, 2009
wilsodfarm
  • 986 Answers
SOURCE: i need a diagram for the battery wiring on a 1969
They came out with 24
Posted on Jul 29, 2009
  • 8404 Answers
SOURCE: John Deere f1145 front mower's engine stops
You must be in the seat to run the mower ... safety interlocks ... operator presence control is what it is called.
Posted on May 02, 2010
  • 7 Answers
SOURCE: JOHN DEERE 4020 SETS FOR A COUPLE DAYS AND WONT
On some of the 4020's the starter brush dust will pile up and cause a partial short circuit. This will drain the batteries after a couple days. Short of removing the starter I don't know if there is a way to jar or blow it away.
Posted on Aug 31, 2010
Need a Harmonic balancer puller for 4020 John Deere tractor
Your local Jd dealer can get you service guard tool for that specific pulley or they can advise you on how to remove it. Some dealers may loan you the tool. Just depending on dealer.
May 19, 2015 | John Deere Garden
Replace a fanbelt on john deere 4020 diesel tractor
Most older models had the adjustment on the alternator. loosen it and push it toward the engine. remove & replace the belt. Pull the alternator away from the engine until the pulley cannot be turned by hand due to the tension. Tighten the adjustment bolt to secure it. Don't overtighten the belt.
Sep 22, 2014 | John Deere 4020 Gas & Diesel Tractor...
I ran my john deere 790 out of fuel.how do i restart
With diesel, sometimes you have to bleed air out before it will run again. Typically you disconnect the fuel line going to the injector pump, manually activate the fuel pump, or turn over until fuel comes out, then release one or more of the injectors, and turn engine over again. Normally that bleeds enough to start and then the rest of the air gets pushed through.
Feb 13, 2011 | John Deere 4020 Gas & Diesel Tractor...
JD 4020 Row Crop Tractor; No power Steering, No
In regard to the problem - JD 4020 Row Crop Tractor; No power Steering
What was the problem and how did you fix it I'm having a simlar problem
Apr 29, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Which way do i install thermatate in john deere 4020
looking at stat top part looks like a handle around it
Feb 02, 2010 | John Deere 4020 Gas & Diesel Tractor...
The parking brake on my John Deere L118 is stuck in the activated position. Therefore the tractor won't roll. How can I disengage the parking brake?
Usually there is a red handle under the steering colunm that locks the pedal down. You will need to depress the brake as you push down on the red handle which should release it.
Oct 11, 2009 | Garden
Jun 01, 2009 | John Deere 4020 Gas & Diesel Tractor...
John Deere 4020 Gas & Diesel Tractor Radiator Logo
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
