Question about Bosch Dishwashers
Normal cycle time for a Bosch dish washer model # sgv53e43gb
SOURCE: Bosch SHU43C02UC/47
How to loose up the circulation pump
Posted on Nov 03, 2007
SOURCE: dish washer that does not pump out the water on it"s final cycle
I had this same problem and after having the repairman over to our house several times and having the circuit board changed, I figured it out on my own...
It turns out that the pressure created from the steam during the water heating stage (HO) was pushing on the door latch just enough to prevent the motor from running properly. Because the door wasn't latched completely, the water wouldn't drain and the dishwasher would go to the "Drying" cycle without ever pumping the water out of the basin.
I adjusted the levelling on the DW and that helped, but I'm still not sure that the problem is fixed. We may need a new latch assembly.
To test this, when the DW stops running at any time, push on the door. If the motor kicks back on, this is the problem.
Posted on Feb 20, 2009
  • 27 Answers
SOURCE: water standing at the end of the cycle in my Bosch dish washer
where is the water is it visible above the filter plate or is it in the bottom of the sump
if its in the bottom of the sump thats normal it will always leave water in the sump
Posted on Mar 13, 2009
  • 3 Answers
SOURCE: Dishes bottom rack are marginally clean. upper
Just fixed my Frigidaire. The outboard o-ring on the main pump became distorted and stretched. Check your local hardware store as Frigidaire wants $17.50 + shipping. Good luck
Posted on Jan 01, 2010
heatman101
  • 43501 Answers
SOURCE: 3 hour cycle - dishes not clean - bosch dishwasher
Check your heating element..
Dishwasher2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Jul 18, 2010
Replaced the control board in Bosch Dish Washer SHE44C and the cycle times are reversed???
I think this board requires coding to your particular model?? your dishwasher has four selection button and a delay start, whereas the module has five selections and delay as it is used in several different modesl. The coding info should have been in the box with the part and may need to be carried out directly on the module with the fascia panel removed. If you post the part number of the module I will see if I can get you the coding information..
Mar 01, 2013 | Bosch Dishwashers
Cycle starts, but does not fill with water
When I start a new cycle, I first hear the pump run to empty out all remaining water, and after that I hear the motor run for the regular washing cycle, but there is no water in the dishwasher. After a few minutes, the cycle stops, and the washer claims the dishes are 'clean'. When I try starting a new cycle over and over again, about one in 20 times, the cycle will run normally with water. But then the next time, the problem starts all over again. Once a cycle starts correctly, everything works fine, including the rinsing.
Jan 11, 2013 | Bosch SHX5AL02UC Dishwasher
My Bosch Dishwasher is not drying my dishes now. The model number is SHE44C05UC.
Unfortunately, it seems that the heating element has failed. The dishwasher uses steam to heat the tub to dry the dishes. I suspect your dishes are also being washed in cold water.
To check this, please run a regular full wash cycle. Allow the washer to fill with water and run for about 10 minutes, then open the door and feel the water temperature in the bottom of the washer. If the water is cold, it's more than likely the heating element has failed.
There are other possible faults which would cause the element not to heat, but these often prevent the dishwasher from completing the cycle. If the water is cold but the dishwasher still drains the water at the end - and completes the cycle - the heating element has probably failed.
Please try this simple test for water temperature and let me know if you need further assistance.
Regards,
BElectric
Feb 18, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
Washer will not dispense soap from dispenser.
make sure that the soap dispenser if clean and free of residue build up. if this is clean you need to replace the dispencer
May 19, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwasher cycles lasting too long
Good idea to look at the drainage system. If the system isn't draining, the system isn't going to proceed because the washer would flood. Look here for my guide on the drainage system and what to do to clear it. If it helps you, there is a guestbook I'd like to ask you to sign at the bottom.
Good Luck!
Jul 27, 2009 | Bosch Dishwashers
Cycle time
yes its normal.bosch dishwashers use very little water and energy but,the cycles need to be longer to get the dishes clean. its perfectly OK.(ps use cascade powder if you can)
Jul 24, 2009 | Bosch 24 in. SHU6802UC / SHU6806UC...
Dishes do not clean same detergent and rinse no change to amount
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Jul 06, 2009 | Bosch 24 in. SHX46A05UC Built-In...
Water standing at the end of the cycle in my Bosch dish washer
Mar 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Water left after finishing wash
I have a Bosch Dishwasher and the E-Nr is SGS4362EU/03. The machine is approximately 4 years old, in good condition and has been working very well. Suddenly, there is water remaining after it completes a 50 degrees C wash cycle. This is also evident with the pre wash cycle and the 65 degrees wash cycle.
I have checked and cleaned the filters. I have loosened the internal pump white cover (Torx T 20 screw) and checked for any physical blockage - none. I have also checked for any drainage hose kinks - none.
I have tried a series of empty washes and the machine drains the water during the wash cycles. The dishes are also have a dull colour and show show signs of not being properly rinsed during the wash cycle.
Please assist.
Reagrds,
Brian
Dec 27, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwashers Logo
42 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
