Question about HP Photosmart C7280 Printer
Schematic diagram of HP Photosmart C7280
Need interior diagram of HP Photosmart C7280 in order to put it back together
kevin000
  • 1847 Answers
SOURCE: hp photosmart c7280 won't work
Solution
If the color or photo paper is loaded in the input tray when the printer aligns, the calibration might fail.
Follow these steps to resolve the issue.
Load unused plain white letter or A4 paper into the input tray.
Press the OK button on the control panel.
Cause
An incorrect type of paper is loaded in the input tray
Posted on May 30, 2008
  • 54 Answers
SOURCE: HP PHOTOSMART C7280 ERROR 0xc18a0001
Follow the steps carefully from the front panel of the All-in-One.
1. Get the unit into the “Support Menu” by following the steps given below.
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Now Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
Now the Display should say “Support” and display the FW rev (something like R0631R)
2. Press and release the right arrow button until the display says “System Configuration Menu”.
3. Press and release the “OK” button.
4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
5. Press and release the “OK” button.
6. Display should say “Hardware failure status: Clear. Press OK to clear”.
7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11.Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12.To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
Posted on Sep 12, 2009
seeker5211
  • 1089 Answers
SOURCE: HP02 Ink (Expired)
Don't use expired ink. HP puts date codes on the in cartridges for a reason.
Posted on May 07, 2010
nirikip
  • 56 Answers
SOURCE: HP Photosmart C7280 color ink running out despite not using it?
  1. Unplug power cable while the printer is ON.
  2. Press and hold the '#' and '3' buttons, and plug the cable back into the printer.
  3. Continue holding the buttons down for 20 seconds, and then release it.
if doesn't initialize successfully repeat
on step 2 press and hold the '#' and '6' button and plug in the power cable.
Posted on May 13, 2010
  • 30 Answers
SOURCE: How do i repair: hp Photosmart C7280 Printer ink
Try holding down the ok -- cancel -- black -- color buttons with 4 fingers while at the same time powering the unit off. Keep them held down till it is off. Then turn it back on normally & it should try to do "Maintenance" & you hear a whirling noise --- that is the ink pump spinning to try & pump in ink to the print head.
Here are the details. Got the Ink System Failure message. The error code shows was '0xc18a0005'. The tech had me press and hold the '*' key on the key pad, then press the '#' key and release them both. Then he had me enter '123' to enter maintenance mode. He then had me press the right arrow (beside the OK button) until System Config. menu appeared on panel. Then pressed OK two times to clear the error condition, then cancel two or three times to return to the top menu. Then powered off and back on, printed a test page just fine, copied a document fine.
Posted on Jul 26, 2010
I want to disable messages about the inkcartridges.
Sadly not. The HP Photosmart C7280 insists on having a full set of cartridges installed in order to print. It does this because the printheads are actually part of the printer itself and can sustain damage if they pull air into the printhead.
The out of date message is also non-negotiable I am sad to say.
Feb 05, 2013 | HP Photosmart C7280 Laser Printer
I have an HP Photosmart C7280. The printer will not turn on. Every time I try a blue screen comes up on the display and then all of the lights start flashing.
1. unplugged the power cord for 20 seconds (actually went a little longer)
2. Held down the # and 6 keys together and then plugged the power cord back in (still holding the keys).
3. held down # and 6 for about 10 more seconds after plugging the power cord back in and didn't get any messages but once and release them It was able to turn the power on.
The printer then printed an alignment page
hope it works, if so do rate the solution
Nov 28, 2010 | HP Photosmart C7280 Laser Printer
Hp deskjet c7280 giving a error 0xc180501 what to do?
I myself have not tried this, but apparently it came from HP.
HP Photosmart C5180 show ink system failure message
This was what I was told to do for my C5180. First they told me to do a power drain. This is done by pulling out the power cable and then holding the on/off button for a minute, then putting the power cable back in (this didn't work).
Then we did a master reset. Unplug the printer, then pressing the help and ok buttons simultaneously plug it back in. This sorted it.
Have to say it looked like this whole process used up shed loads of ink, so by the time I had finished I needed to replace 3 cartridges!
Thanks,
Bhautesh.
Aug 21, 2010 | HP Photosmart C7280 Printer
Printed colors are not the same as document (I
you need to make sure all your ink cartridges are full, if they are, I would take them out and put them back in and rerun alignment
Jun 28, 2010 | HP Photosmart C7280 Printer
HP02 Ink (Expired)
I HP made cars they wouldn't start until you change your dirty motor oil.
May 07, 2010 | HP Photosmart C7280 Printer
Does HP C7280 need all color cartridges full in order to print black?
Hi there
Yes you need all inks to be working or printer not work
Feb 28, 2010 | HP Photosmart C7280 Laser Printer
HP photosmart c7280 printing photos with purple hue
Does the c7280 use seperate Magenta and PhotoMagenta cartridges? If so make certain the right cartridge is in the correct slot.
Jun 20, 2009 | HP Photosmart Pro B8350 InkJet Printer
HP Photosmart C7280 Printer Logo
234 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
