Question about Brother MFC 7420 All-In-One Laser Printer
BLACK VERTICAL LINE ON RIGHT HL 2240 - Brother MFC 7420 All-In-One Laser Printer
2 Suggested Answers
clrvuedoc
  • 175 Answers
SOURCE: vertical single black line on printed pages - does
The first thing I would try is to fix the corona wire. Here is a link to Brother's website outlining the process (clean corona wire).
What you need to do is pull out the drum and look for a blue tab on the top of the cartridge. Slide that tab back and forth along the wire and see if that clears things up.
I have had some luck cleaning the drum when I get black streaks but I have also hear this can be dangerous and make the problem worse.
Posted on Mar 02, 2011
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
Brother HL 2240 ready light it on, call for print but nothing happens.
if you press the GO button 3 times very quickly (1-2-3) and you get a printout from the printer then the most likely reason is problem with the connection or the windows driver
Aug 20, 2013 | Brother HL-2240 Monochrome Laser Printer
My samsung hl-r5087w has black verticle lines how do i fix that
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help to fix the fault, do take care in handling the solution
May 26, 2011 | Samsung HLR5087W 50" Rear Projection HDTV
Just installed new toner cartridge and there is a vertical line of black specks down the page, to the right of center. Other specks, too.
Hello sir; Remove the cartridge, look inside the machine, on the bottom you may fine a piece glass clean up the glass will be take care this problem.
Oct 06, 2009 | Brother HL 1240 Printer
Black Vertical Line on the paper
start a print from tray 1/manual feed and just as the trailing edge of paper is entering the machine;quickly open it to stop print and take out the cartridge and look at it's drum and the paper underneath. if the issue is there at that point then it would point to the cartridge. if not then the fuser
Let me know....
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 21, 2009 | Brother HL 5140 Laser Printer
MY brother HL-5140 quits printing,and also has a black vertical line down the page before it quits. After a while, say 30 to 45 minutes, it will start printing again. But there are black smudges on the...
Sounds like a fusing error ... If your able to wipe the toner off the page its a fuser unit problem (replace fuser unit) If toner is sticking to paper but the print quality is poor , replace the drum unit  (PCU)  good luck
Brother hl-1440 laser printer
Did you mean 'vertical' (from top to bottom) line rather than horizontal? If it goes 'straight down,' it has to be. I think so, otherwise the added info that it is closer to the right wouldn't make sense.
This problem is normally due to contaminents on the surface of the drum itself although can also occur if a wire that discharges the excess toner from blank areas could be dirty.
Changing the drum cartridge will correct either of those problems since they are contained in the drum cartridge. If you are using 'recharged' cartridges and it only has a few copies on it, most companies will exchange it for you.
Oct 23, 2008 | Brother HL 1440 Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
135 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
