Question about Five Star TTN325-BGW Dual Fuel (Electric and Gas) Kitchen Range
Oven door does not appear to
Our oven door does not appear to close properly it seems as though it is half an inch open all the time. Is this normal or should we get in a repairman. Many thanks.
0 characters
1 Points
Roper Gas Range Oven Makes Sound
check you have ventilation. i.e. try with the window open
Feb 14, 2010 | Roper FGP305 Gas Kitchen Range
I have a Kitchen Aid range model KGST307GBS0. The
The door light switch was broken (upper right face of oven). The door switch is automatically activated when the door is opened to turn on the oven light. When the door is closed the switch is depressed to turn off the light. It seems the switch position is detected by the oven and if it is in the open position it will not allow the oven to function properly (reach temperature or allow the cleaning cycle to run). I temporarily locked the broken switch in the closed position, which allows the oven to function. A new switch was ordered for replacement.
Jan 02, 2010 | KitchenAid KGST307 Gas Kitchen Range
The oven door won't close JGS968
The hinges are sping loaded Take the door off to see how much he bent it maybe you can bend it back or the screws can adjust it.
Dec 04, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
How do I set the oven to self clean
The oven door must be closed and all controls set correctly for the cycle to work properly. After a Clean Cycle You may notice some white ash in the oven. Wipe it up with a damp cloth after the oven cools. If white spots remain, remove them with a soap- filled scouring pad and rinse thoroughly with a vinegar and water mixture. These deposits are usually a salt residue that cannot be removed by the clean cycle. If the oven is not clean after one clean cycle, repeat the cycle.
You cannot set the oven for cooking until
the oven is cool enough for the door to unlock.
While the oven is self-cleaning, you can
touch the TIMER/CLOCK pad to display the time of day.
To return to the clean
countdown, touch the COOKING TIME pad.
If the shelves become hard to slide,
apply a small amount of vegetable oil or cooking oil to a paper towel and wipe the edges of the oven shelves with the paper towel.
Using the self-cleaning oven.
How to Delay the Start of Cleaning
Make sure the clock shows the correct time of day. If your model has a latch, latch the door. Touch the SELF CLEAN pad. Using the + or or the number pads, enter the desired clean time. Touch the DELAY START pad. The earliest start time you can set will appear in the display. Using the + or or the number pads, enter the time of day you want the clean cycle to start. Touch the START pad. On models without a door latch, the door locks automatically. The display will show the start time. It will not be possible to open the oven door until the temperature drops below the lock temperature and the LOCKED DOOR light goes off. The oven shuts off automatically when the clean cycle is complete. When the LOCKED DOOR light is off, slide the latch handle to the left as far as it will go and open the door. If your range does not have a latch, the door will unlock automatically. n The words LOCK DOOR will flash and the oven control will signal if you set the clean cycle and forget to close the oven door or forget to latch the door on models with a latch. n To stop a clean cycle, touch the CLEAR/OFF pad. When the LOCKED DOOR light goes off indicating the oven has cooled below the locking temperature, unlatch the door (on models with a latch) and open the door.
Oct 17, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Dacor oven door does not close completely
Place a hammer handle between the hinge and the door frame. Exert moderate pressure to close the door. It should spring back to normal position. Do both sides.
May 05, 2009 | Dacor Epicure ERD36 Dual Fuel (Electric...
DCS wall oven door won't close
there is a broil stop integral to the hinges but shouldn't be the problem. make sure the little swinging stops used to remove the door assembly are rotated up and are in the "stowed" position.
Jan 09, 2009 | Hotpoint RB787 Electric Kitchen Range
My oven - St George UGM-4 model - won't light. I don't know how old the oven is. There have been problems for a while, with the flame going out after about 5 minutes when it's first lit (it makes a...
this one is hands on fix,many times the spark ignition the one that makes the clicking noise is clicking on a different position,so you most look inside the oven to see the spark, you can see it better at night or when is dark to see the spark, that spark is right at the tip of the oven pilot, make sure you see the spark lighting the long as the pilot does not ignite.the clicking sounds continues making the noise. if the pilot lights the noise will stop, if the oven burner does not light after pilot is being for about 1 minute and a half the safety valve needs replacing
Dec 06, 2008 | Kitchen Ranges
Oven door won't unlock
I fixed the automatic oven door lock on my oven. While the door was open, I pushed the button on the upper left hand side a couple of times (the one that senses when the door is closed.) Then I was going to call the repairman when the door closed! I had to run the self clean cycle again to get the lock light to go off, but it worked!
Nov 25, 2007 | Frigidaire FEF336BC Electric Kitchen Range
Five Star TTN325-BGW Dual Fuel (Electric and Gas) Kitchen Range Logo
Top Five Star Kitchen Ranges Experts
Dan Webster
Dan Webster
ray gallant
Tom Chichester
Are you a Five Star Kitchen Range Expert? Answer questions, earn points and help others
