Question about Samsung Washing Machines
Samsung washing machine wa 10B3 error code not spin drying
SOURCE: Error code dHE
Several reports in Australia of brand new LG Washer/Dryer combo (model number WD14700RD) getting dHE error's with very 1st dry cycle.
I bought a LG WD14700RD last week, and yup, washed fine.
Dryer cycle results in dHE error.
Everytime.
Cycle stops & you just have to power off the machine.
Service man found several possible causes.
He unscrewed the top of the machine off & said dHE errors are related to the dryer components. He started a dryer cycle & watched & lisened to machine.
He observed the dryer fan was not starting up.
He unplugged the power cable to the dryer & replugged.
The fan now started up, but only with cold air.
He then looked towards the front of the machine & noticed several cables had come loose from their sockets, one he identified was the heater element cable.
He plugged that back in & another unknown cable was also loose. He plugged that back in.
It worked.
dHE error gone & dryer fan started & pumped out hot air.
It seems at least a few of these machines during transit (from South Korea?) fail due to cables coming loose from their sockets.
dHE errors result if fan cable & fan heating element cable come loose.
My thanks to WAM electrical repairs in Box Hill (Melbourne) for helpfull advice & successfull repair.
For people looking at buying this machine, it washes & now dries perfectly well & I am happy with the machine.
But beware that this problem is out there (there are several other reports I read) and it have this problem, which is easily fixed but does require a service call out, under warranty of course.
Steve, East Melb.
steve_aust@hotmail.com
Posted on Jan 19, 2008
  • 105 Answers
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Posted on Aug 02, 2009
  • 193 Answers
SOURCE: error code E03 on washing machine
eo3 water not draining,check for kinked drain hose,check that drain filter is clean
Posted on Sep 28, 2009
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
richroth
  • 9472 Answers
SOURCE: I have a samsung washing
WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Posted on Dec 11, 2010
Samsung model wa 7584C1. has 1E error code have changed pressure switch and tub hose still shows the same error please help
IE - Water level sensor fault This fault code is fairly self-explanatory and tells you that the washing machine has detected an error with the pressure sensor or pressure switch
  • Check water level sensor
  • Check wiring to water pressure sensor
  • Check connections to water level sensor
  • Check main electronic controller
  • Apr 06, 2015 | Samsung Washing Machines
    Based on my experience, the same thing happens to me as you have mentioned that it happens every end of a cycle. I doubt if it was a fan error or a frequency error. for me, its just a simple overload for the autodrying. for example on my model. the manual says autodrying cotton-cupboard dry must be max 3 kg. since you cannot measure your wet clothes and it sometimes exceed the 3kg autodrying, that is when the FE comes out. but when i remove some clothes or spin the laundry again and put it into drying, everything works fine. when i use the machine with minimal clothes say 2kg dry, the whole cycle up to drying work fine without FE errors.
    So i believe its just an error for drying overload. also the manual says nothing about FE nor Error code for drying overload.
    Hope this help.
    May 31, 2012 | Washing Machines
    Getting error code LO and the door will not unlock
    To unlock the door on most Samsung Washing machines:
    Press "end of cycle" for over 5 seconds or press "options & select" until the light goes off.
    Else, try holding the buttons "dry" & "spin" together for a few seconds until the lock goes off.
    Apr 24, 2011 | Samsung Washing Machines
    I have a samsung washing machine wf7600naw washing machine that won't spin and is displaying the error code SE. How can I fix the problem?
    Dec 11, 2010 | Samsung Washing Machines
    We have a Samsung WF8802 RPZ washing machine with a 5ud fault code. What is the problem?
    We have a Samsung WF8604NGW front loading dimond 6kg washing machine. We had the 5ud error message. It turned out the filter was clogged with fluff from a new set of bathroom mats my wife washed. To fix: Put the machine on to drain (if poss) - should be 1 minute on our machine however as the machine was so clogged it took around 15 to finish. Also use the draning tube located next to the filter (on our machine) to get rid of as much water as poss. Now remove filter and clear (warning some water will remain in the system) Before spinning any laundry run the rinse cycle (with an empty drum) a couple of times and clear the filter each time. If the filter is still clogged the laundry will spin heavy as the water will still be in the drum leaving you with no very dry laundry and a horrible noise during the spin. Regards Rik.
    Nov 14, 2010 | Samsung Washing Machines
    Hi. After a Samsung washing machine error code chart. Where can I get one?
    Try here:
    http://www.keepingupappliances.com/repair-help/appliance-repair/washing-machine-help/samsung-washing-machine-error-codes/
    Jan 19, 2010 | Samsung SW62ASP Top Load Washer
    Washing Machines Logo
    29 people viewed this question
    Top Samsung Washing Machines Experts
    Jaime Hernandez
    shaun taylor
    Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
