Question about Teac PD-H300 CD Player
Open the CD player on a PD H 500
The cd tray does not open, what can I try to open it again?
4 Suggested Answers
robotek
  • 1512 Answers
SOURCE: Tray Sticking on CD Player
reoccurring tray problems are a paim. It mauy be a spot of oil or grease on the tray motorbelt, or the wrong belt fitted, and or dry failing bubricant to opening cam and sliders. Best approach is to strip and clean everything, lube only with white plastic grease, and sparingly. I use graphic powder on tray sliders, be careful not to get lubricants on drive belts. try next size down belt also, or be sure the belt fitted is 2.0 mm crosssectional area
Posted on Dec 17, 2007
  • 3 Answers
SOURCE: Display doesn't work on TEAC PD H300mkIII
I had the same issue today. I found that opening the unit you can see that there is a white ribbon cable connecting the head unit to the main board. removing this cable and re-inserting it the connector fixed the problem. The display now works again...hope this helps
Posted on Nov 21, 2009
DrWho_64
  • 35 Answers
SOURCE: I have a Teac PD-495
Sounds like the door may have something sticky around the edges. Even a little sticky stuff (like from candy-coated fingers...?) can prevent the door\drawer of any CD player from opening.
Try gently "assisting" the door during the few seconds it's trying to open. If it seems like it's not sticking to the housing try the manual eject button.
Depending on your specific device, there should be a very small hole near the door\drawer (Refer to your owners manual for the exact location). It will be just big enough to stick the end of a large paperclip into. Insert the end of a paperclip into the hole and push firmly (make sure nothing is blocking the door\drawer from opening) and the door\drawer should open slightly. Then pull the door\drawer open the rest of the way. If you have to do this, make sure the power is off as the unit might try to close the drawer automatically while you're trying to pull it open.
Once you have the drawer open, inspect the inner surface of the drawer and the area it contacts for anything sticky. Clean with a damp cloth only. Do not spray any cleaner on the unit. If you need to use any cleaners, spray them on the cloth. Clean the area around the inner drawer faceplate and surrounding areas. Let dry for a few minutes then power up and test for operation. It should work fine now.
If not, it may be time to replace this old unit with a new one as repair costs generally exceed the cost of replacement.
Hope this answers your problem. Good Luck!
Posted on Dec 04, 2010
When i switch my teacpdh300 cd player on the drawer open and when i close it, it reopens
hi,
Check the tray loading belt of your cd player. If the loading belt is over sized then this problem can occur. Normally the loading belt will become over sized after a few years of use according to the weather condition. . If so the loading tray will not go inside fully and will not engage with close sensing switch. if so the it will open automatically without any external command .Normally in all players the loading belt will be under the loading tray near the frond side of the mechanism. check the same. keep the player in eject position remove power and then try to replace the belt.
ok
Jun 16, 2011 | Teac PD-H300 CD Player
The CD drawer refuses to open when I push the open button.
I know this sounds a little brutal for what is after all is a delicate piece of hi-fi; I've just fixed mine by turning it upside down and giving it a good shake, knocking the underside a couple of times. The tray jumps out of its guide track, you're just shakin it back in.
Oct 03, 2010 | Teac PD-H300 CD Player
Can't remove cd cartridge because won't power up.
With the top off the unit, you can turn the tray gears manually for slow eject function. Unplug unit before touching anything inside, check internal fuses.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams and shorts.
Make sure your tray retracts all the way into the player flush with the face plate when loading, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
Many Magnavox, Denon, JVC,
BMW 740 OEM and others.
Dec 04, 2009 | Pioneer PD-M426 6-Disc CD Changer
CD/dvd won't come out
Hi
Thanks for using FixYa. It is due to the short drive. In the front of the CD-ROM, there is a small pinhole. Put a straighten paper clip in that hole, this should pop the tray open. You may also try a small screw driver when pressing eject button, use it above the ejecting tray and it will eject the CD. This problem occurs when the ejection tray was tried to be opened in the ways other than it was designed for.
Once you get the tray open and have salvaged your CD, close it and check in Device Manager for yellow exclamation points by the CD-ROM listing. Somebody may have deleted the driver Also, check in the bios to see if it's listed.
Its probably either loose or maybe broken. Please replace it.
Generally something that is time related with a CD player indicates that there is something stuck in one of the gear teeth that drive the laser back and forth to play different areas of the disc. A very small piece of dirt/sand can get inside and stuck in a gear tooth preventing the laser from moving past that point on the CD, you can advance the laser unit a bit more quickly than if you were to let the disc play through, that might dislodge the piece. Another scenario could be a cracked gear in the same drive area. There is a piece that is attached to the laser which has gear teeth in it that mesh with the gears that move it. Make sure you do not have the player plugged in when you open it; the laser is capable of damaging your eyes.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Aug 22, 2009 | Teac PD-H300 CD Player
Mar 14, 2009 | Teac PD-H300 CD Player
Teac PD-1200 Compact Multi Disc Player
Hi
I think that we can get at least one of them going again :)
I suggest
  1. take the lids off both of them.
  2. load up some Cd's and close the drawer and watch what happens.
  3. does the disc begin to spin, is not, do you hear any noise as it tries to read each disc.
  4. can you kick start the CD when it first loads(clockwise direction)
  5. if not of these things happen, can you see if the transport loads the cd up off the tray.
While you are in there, with the front drawer open you should be able to see the laser lens. Use a cotton bud moistened with windex(glass cleaner) gently clean the lens in a circular motion and then also polish it with a dry one to be sure you have left no smears on the lens. Then.... try the unit again and see if the CD reads.
If you don't have any luck this far, please post back to me and we can try some other things. All this and you give me a FixYa... YAY :)
regards
robotek
Jul 04, 2008 | Teac CD-P1120 CD Player
Pioneer PDR-W839 Jammed Disc Changer (previously posted)
hello poopig1, after further review, I meant to describe this: look for a pinhole in the area of the CD tray to insert a pin...similar to the same pinhole you see on a PC's cd player to eject the tray manually. If there is none, then try this: Open the cover and find the motor that, when turning, performs the tray ejection. Then, turn that motor by hand until the entire tray (or cartridge) is ejected. Then power up and observe the events.
May 31, 2007 | Pioneer PD-RW839 4-Disc CD Recorder
PD-F505
try a lens cleaning cd,if this doesnt work is more than likely optic (laser) faulty as laser has to focus first before spinning disc.if it cannot focus disc will not spin..
May 15, 2007 | Pioneer PD-F505 CD Player
CD drawer will not open or close
Had The Same With Mine. Its was the belt Inside that joins Motor To Cd Tray. Its Black and directly under the cd tray at the front. Its probably either loose like mine of maybe broken. I replaced mine with an elastic band and its been fine since.
Nov 19, 2006 | Teac PD-H300 CD Player
Teac PD-H300 CD Player Logo
50 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
