Question about KitchenAid Kitchen Ranges
Model # kdrp467k550
Dual fuel range, oven make noise
SOURCE: Lofra MXD96AMFE/C Dual Fuel Range Cooker
Hi
The timer on our Lofra MXUD76MFE broke about 2 months after the 12 month warranty ran out.
Being a bit of a fiddler i took the top off the cooker to access the timer (not that difficult) when i ispected the timer i was astonished that it had lasted the 14 months it had such was the quality of it.
The timer was easy to set to ensure the cooker worked but unserviceable to restore the timer mechanism.
I thought given that it was such a cheap looking part (even allowing for the exorbitant price of parts) it would be worth replacing.
Came across the new appointed distributor - Premier Appliance Brands - based in Warrington (01925 248980)
They gave me a part No of 03010631 but didn't have stock and initially could not give me a price. i left it a couple of weeks and rang back this week.
They quoted £77 - needless to say i didn't order it
Posted on Nov 30, 2007
SOURCE: Dacor oven will no heat.
This solution worked for me. My gas oven would not work even though my burners would. There were 6 screws to undo and I removed the screen that led to the thermostat. Note: the reset button is located on the top of the thermostat and is red (actually is a square red button) - it is behind another round metal disk (that you first will see after removing the metal screen) with wires plugged into to but if you look from the front side view you will see it behind the disk. I reached back with my finger and pressed it down to reset. Thanks all for this great tip - saved me a service call!
Posted on Dec 24, 2007
Techsim
  • 59 Answers
SOURCE: how do you use the self cleaning option for Kenmore dual fuel ove
Simply press the "Clean" button and set a time (Hi or 4hrs is best) it will the lock the door and burn everything inside. If you have silver colored shelfs remove them fist. After its done and has cooled wipe out the ash that has collected in the bottom of the oven.
Posted on Dec 28, 2008
MNTECH
  • 1543 Answers
SOURCE: My broiler works - but the oven does not - GE Dual Fuel range
Thanks for providing the full model number, which allows us to look up part numbers and see exploded views of your product.
Most likely the bake ignitor is bad (even if it still glows, it may not draw enough amperage to allow the gas safety valve to open). One way you can test this on your model is to swap out the broil ignitor for the bake ignitor, as they are the same part number on your model. (part number WB13T10045) The broiler is normally used much less than the oven, so the part does not fail very often on the broiler. You will have to take the cover off the floor of the oven, then the flame spreader, to reach the burner area. The ignitor is the rectangular part at the back, on the side of the burner. (only two wires to deal with) (By the way, for future reference, your model number ends is SS, as in stainless steel, not a 55)
Posted on Jan 15, 2009
SOURCE: F2 Error on Whirlpool Dual Fuel Range
I was baking and the stove suddenly changed to Maxi Broil and then to ERR F2EO Stuck Key. I cannot seem to change it by start or off or even turning the unit off and then back on. Any suggestions? Thanks.
Posted on May 29, 2009
HI, a mouse has eaten the insulation between the ovens, can this be replaced?
Yes. Use your model number and call a parts supplier, they can help you find the right piece of insulation... Range Stove Oven Insulation WPW10208653
May 13, 2016 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Jenn-Air dual fuel double oven range - oven wont work.
You can make the repair yourself. What is the model number?
Nov 07, 2012 | Jenn-Air Kitchen Ranges
Heard popping noise and circuit to stove blew. could not set time or oven temp when reset breaker
Hi
Sounds like your oven heater failed. Not sure if its a fan oven or static type. If you hear a fan inside the oven then its classed as a fan oven
Nov 16, 2009 | Frigidaire PLCS389DC Dual Fuel (Electric...
Have a Viking range, gas top, electric oven, neither work.
Check connector block where electric is brought into stove for loose or burnt wires. Check Breaker in house power box. Push the breaker firmly to off and then return to On position. Read owner's manual to see if ignitor circuit has a fuse and check said fuse.
Sep 12, 2009 | Viking 30" Dual-Fuel Range, VDSC3054B...
The clock on my fridgidare oven is making a grinding noise. When the oven isn,t even being used. model # REG533MD-2
You have a failing clock motor. It "was" available as part of an entire clock assembly only, but the part has been discontinued.
Apr 28, 2009 | Rangemaster Classic 110 (Dual Fuel) Dual...
Thermador range electric model ref 30
in pre heating the oven it does not go beyond 250 degrees. what could be the problem. I have a thermador 30 inch dual-fuel range (rdf30).
Feb 16, 2008 | Thermador RDF30 Dual Fuel (Electric and...
Open Questions:
Kitchen Ranges Logo
29 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
