Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool refrigerator won't cool GD25DFXFW02
When switching the thermostat to coldest setting the refrigerator will turn on. Then it will stop and not turn back on.
  • 125 Answers
SOURCE: Whirlpool refrigerator model ED5GTN cooling problem.
With the unit unplugged, take off the back cardboard panel. On the lt rear side you will find the compressor. On the lt side of the compressor you will see a white box mounted on the side, this is the relay, and it most likely will have a zip tie holding it on. Cut the zip tie or unhook the clip. Gently pry the relay from the side of the compressor. If it is badly burnt make sure there are 3 connectors on the compressor, sometimes they will burn one off or burn it so bad the compressor will need to be replaced $$$$ if not in warranty. If its not burnt thats hopefully what you will find, hold out your hand with the compressor side of the relay pointing down. Shake the relay like a salt shaker into your hand. If you get grey flakes/chunks in your hand the relay is bad and will need to be replaced. easy fix for about $45 - $50.
Posted on Apr 18, 2009
BIKER T
  • 909 Answers
SOURCE: my whirlpool ET8MTMXKQ01 'runs' but suddenly stopped cooling
Switch off completely for a day and give a good defrost. If when you retry and it still does not cool,(assuming the compressor is running) then you have either got a blockage or an internal leak. Need to then get a technician to sort out.
Posted on Sep 21, 2009
aasc
  • 1606 Answers
SOURCE: whirlpool refrigerator stopped cooling. the
You have a bad overload/relay . This is the piece pluged onto the side of the compressor , with 2 or 3 wires going to it . The part number is 8201786 . It is easily replaceable and instructions come with it . Price is around $60.00 .
Posted on Nov 13, 2009
hh0405
  • 77 Answers
SOURCE: Refrigirator stop cooling
if you hear a noise like clicking when the compressor tries to start and unit will not cool the starter overload on the side of the compressor that starts it has burnt out simple replace the starter overload and it should start
Posted on Apr 03, 2010
  • 41 Answers
SOURCE: Whirlpool Gold Side by Side (GD25DFXFW02) is over
the drain sump under the evaporator plate may be blocked or you may require a new defrost element
Posted on Jun 12, 2010
Cb 18 m
The cold control (thermostat) could be defective
May 30, 2013 | Whirlpool Refrigerators
Fridge won't cool
The problem is either the fresh food section thermister or the=> W10196393 Damper12_11_2012_5_08_54_am.jpg
If you would like a Service Manual for this model click here=> MBF2562HEB_Maytag_Refrigerator_Service_Manual When ready I will be here to answer your questions, Thanks Sea Breeze
Dec 11, 2012 | Maytag MBF2556KE (251 cu ft) Bottom...
I have Whirlpool ET8MHK Top Freezer Refrigerator and all of a sudden it stopped cooling. I had to crack up the setting to coldest to work. what part needs to be placed?
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 29, 2010 | Whirlpool ET8MTKX Top Freezer Refrigerator
Motor not running Refrigerator not cooling
There are three possibilities why the compressor motor is not running. #1. The thermostat switch is not closing to turn the motor on. #2. The compressor motor is bad. #3 The defrost timer is engaged, preventing the compressor motor from starting.
Solution for #1: Locate the thermostat switch behind the console in the refrigerator. It is attached to the freezer temperature adjusting knob. If you jump the switch out, the compressor motor should start. If it does, replace this switch.
Solution for #2: get another refrigerator. It is not worth repairing.
Solution for #3: Turn the freezer temperature switch to the coldest setting. Locate the defrost timer in the console on the ceiling of the refrigerator compartment. Look for position labels like "cool control" and "compressor". Jump between these two wires. The compressor should start. If it does, replace this module.
Mar 06, 2010 | Kenmore Refrigerators
My whirlpool ET8MTMXKQ01 'runs' but suddenly stopped cooling the freezer and refrigerator compartments, even when set to the coldest setting/ tje refrogeratpr was made in 11/01. never had any problems...
Sep 21, 2009 | Whirlpool ET1FHTXM Top Freezer...
My freezer is not cold
Three should be the coldest.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 03, 2009 | Refrigerators
Whirlpool side by side refrigerator not cooling
yes do the check for the baffle. set the controoler for the thermostat to off and the freezer to the coldest setting while have the doors open. take the cover off the baffle and observe if its closed . should close in 10 seconds, also the compressor should be on, as should the evaporator fan and the condenser fan. turn the controls the oposite and the baffle should open. Also make sure that you have seperation of product so that you haev adequate air flow in frig.
Feb 05, 2009 | Kenmore Refrigerators
Fridge/Freezer random shutdown
without turning off can you just wiggle the control up and down a little perhaps smack the knob to get it to go on , that would tell me you have a short in thermostat for sure
Mar 18, 2008 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
