Question about Philips DVD633 DVD Player
Disc not being read - reading reading reading
When I load a disc into the DVD player, it only flashes "reading" continuously then ejects disc.
I have bought a disc cleaner but this does not solve the problem.
It has been playing dvds up until last week. I have tried switching off at wall and rebooting this.
  • Philips Master
  • 19,396 Answers
That looks like a lens problem, when there is a fault of different kind you usually get an error message.
If you use a CD cleaner , use a good one , the $2 CD cleaners do not work, you need a kit with cleaning solution. Check here.
Run the CD cleaner a couple of times more , and see if this work.
If it does not work , the unit must be taken apart, and the lens cleaned directly with a cotton stub and cleaning solution, or isopropyl alcohol.
If the lens is defective, then the lens pick up should be replaced.
Posted on Oct 26, 2008
Player reads DVD as bad
Are you using the correct format disc.If you are playing a blu ray disc in a non blu ray player the player will not read the disc
Jan 02, 2018 | Durabrand Audio Players & Recorders
Load dvd disc, dvd reads disc then comes up with
I am just wondering whether the unit has got condensation inside.
Just try to do this as a process of elimination.
Take the dvd and place in a warm room.Plug it into the mains (try and eject disc if not leave in) and leave for 2-3 hrs
Give it another try..fingers crossed.
Dec 04, 2009 | Panasonic DMRES15 DVD Recorder
Won't read Dvd/Cd as loaded
It is a problem of the optical head being covered up by foreign particles obscuring the optical lens. Try using a CD/DVD cleaner disc which has double brushes and one add some solvent which comes along with the pack.Simply play it & keep ejecting and inserting the disc makes the disc to spin, till your player starts reading it..............................sodeep
Oct 06, 2009 | Coby DVD-224 Player
Dvd in in player and won't eject. screen reads "loading".
Try unplugging the unit and plugging it back in after a couple of minutes, if cd still won't come out you can unplug the unit and manually remove the cd by taking the outer casing off.
Sep 07, 2009 | Alpine DHA-S680 6-Disc CD/DVD Changer
I have a Samsung DVD-R155. When I insert a DVD, the screen reads "load", but eventually it screen will say it can't read the DVD, and then ejects the DVD. It doesn' t matter if it is a new or used DVD. I...
Try using a DVD scanner eye cleaner. It is aDVD with a brush grafted to it. I suspect the scanner eye is dirty so it cannot read the boot starp properly and so ejects
Aug 15, 2009 | Samsung DVD-R155
Dmr-e55 disc will not eject
Try pressing and holding ENTER and RETURN on the remote simultaneously and see if that clears the problem.
Apr 12, 2009 | Panasonic DMR-E55 DVD Recorder
Player won't read a DVD
Sounds like a bad pick up assy (Laser)
Nov 24, 2008 | Samsung DVD-R155
JVC DVD player read no file then eject the disc tray.....
Dear friend,
do u have a universal ic programmer lab tool? if u have a lab tool reflash ur dvd player flash ic. i have a flash dump do u want flash dump i will send u. Thank u
Oct 25, 2008 | Televison & Video
Philips DVD633 DVD Player Logo
111 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
