SOURCE: owners manual
Is this a 10" contractor's saw?
I can't seem to locate that number, but did turn up a 34-348. If that's close, you may have a look at the parts list and diagram at http://www.dewaltservicenet.com/Products/DocumentView.aspx?productid=66707&typeId=14646&documentId=33737
I hope this will prove to be of some help!
SOURCE: I need a wiring diagram for a Delta xl-10 table saw.
Unfortunately, the manual for the XL-10 saw is no longer available online. Here is a link to the parts list and diagram.
If that is not helpful, please consult a qualified electrician, who should be able to guide you in the wiring of the switch and motor for that saw.
Without access to the schematic, I'm afraid the best solution to your wiring question is for some capable electrician to take a look at your saw in person.
SOURCE: How do I align the saw blade with the saw table
The Blade Arbor is held to the bottom of the table with mounting screws and stop/adjusting screws. Loosen the mounting screw and adjust the stop screws to make Blade true with miter slot.
SOURCE: My Delta 10 inch table saw stopped working in mid-saw
you have to use a meter and check the voltage at the switch and to the motor.
SOURCE: i need the wiring diagram for my 10 table saw
Im guessing ... the motor is 110 volt AC (AC dont care if it is coming or going) ... find the two terminals in the motor and hook the wires back up. If it HAPPENS to be incorrect, the saw will run poorly or the overload will trip.
I wouldnt be afraid to use this method on my craftsman table saw.
