Question about LG Washing Machines
Lg wd-10490tp won't start spinning
It drains fully, then tries to start spinning, but seems to cut out each time the voltage ramps up for the spin.
  • 383 Answers
SOURCE: OE problem with the LG WD - 12270BD Washer
Turn the knob to start and restart again let it run thru the course.
AND IF THIS DONT WORK TRY THIS:
Put knob on spin and let it run thru the course.
Posted on Nov 26, 2007
SOURCE: Washer LG Model WD-8013F Noisy & vibrates badfly when spinning
hi all you poor owners of this heap of junk, i have one too with the same problems, the shaking and moving around the bathroom was stopped by welding a 1/2 inch long piece of 1 &1/2 inch dia pipe to a 2 inch square flat plate of steel then putting double sided sticky tape beetween the plate and the floor
where you want the front rubber legs to sit, this stops it from running around the floor but it still needs to adjusted to have the
same on the front two legs to stop the shaking.by leaning the machine back a bit also helps to stop it leaking so bad while filling, it is only from the condersation from the hot water going in and the poor design of the soap drawer not allowing the water to run back into the washer which can be fixed by cutting the lip off
the bottom wher the drawer slides in then running a bead of silcone in the crack between the front cover and the inside piece
then another one on the front edge to run the water back into the washer. hpoe this helps. bryan.
Posted on Feb 26, 2008
SOURCE: LG WD-8013F wont spin
Hi deppgirl,
I checked the lint filter at the front bottom left hand side and it was full of junk.  Once emptied it worked a treat.  Pull the flap down and turn the large knob anti-clockwise and pull to remove.  Good luck.
Posted on Apr 22, 2008
SOURCE: lg-wm1832cw front loader washer won't spin and drain
did anyone solve this problem? Mine is doing the same thing... uggh!
Posted on Aug 03, 2010
SOURCE: 7KG WD-8050FH LG Clean Master
I had same problem and i have opened the the water pump and found some tissues blocked the fan from spining , i remove it and immediatly worked .
Posted on Aug 14, 2010
Lg wd 10490tp door
Is it loked, you know how you have to wait for two minutes before the lock unlocks and you hear a click, then you can open the door. Try a program like emptying the machine, or the program with the lowest temperature and as short as possible. Kolbrun
Sep 19, 2013 | Washing Machines
Washer won't go into spin cycle, stops after final rinse. When I try drain &rinse it still will not spin.
If the unit does not spin correctly, this is usually an indication that the unit can also not drain. The unit will not spin if it senses a blockage or issue with the drain lines and/or pump. Try to check the drain lines in the back of the unit for any issue, and then see if you have an access panel to get to the coin trap or drain pump itself. Often socks and debris will clog up in this area and cause your problems.
Dec 25, 2012 | Frigidaire ATF6000ES Front Load Washer
My LG WM2101HW front loader will not spin. It drains OK, but won't spin.
I would be leaning more in the direction of the door lock mechanism rather than the hall sensor as someone else posted. The hall sensor gives a very specific error code when it goes bad. Put the unit into a spin only cycle and verify that the door is locking. To do this power up the machine and only press spin speed and the start. It is also possible that it is a problem with any one of the three control boards that are on the unit but again, these normally present with very specific error codes. If the door is not locking, or even if it is but the switch isn't sending the signal back to the main control saying that it is locked then all it would do is drain and then spin 1/3 turns either way inside the tub until time runs out.
Nov 14, 2012 | LG WM2101HW 4.0 cu.ft. Washer
Won't fully spin and alarms nd as a code
You may want to check your drain to be sure there's not a clog/partial clog when draining out the water. Also, you may want to check the filter and possibly clean it. A partially clogged filter may cause this problem. And, you might try...turning off the unit for 10 seconds and turn back on...select Spin Cycle...press Start/Pause to drain the water. Good luck and hope this helps.
Walt
Apr 26, 2012 | Samsung WF218ANB 4.0 Cu. Ft. Front-Load...
The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Jul 13, 2011 | LG WD-1041WFH Front Load Washer
My LG washing machine model-fuzzy logic WF-s6607tc, is not spinning
The filter for your empty pump is probably clogged. The machine can't drain the water in the alloted time because it is draining to slowly through the clogged filter. The machine won't start the spin cycle if all the water hasn't been evacuated. You will need to find and clean out your empty pump filter (Probably behind a little door at the bottom of the machine.
Jun 23, 2011 | LG Washing Machines
What does the LE flashing mean? Water won't drain out of washer.
LE means that the motor sensor has failed and needs a technician to come out and repair the unit. To remove the water, turn on the unit, press the spin speed button once and press start. It will drain the water out and spin the drum.
Jun 15, 2011 | LG WD-1280FHD Front Load Washer
My washer won't spin. It stop and gave me a warning "UE". What is this mean. Please help me.
I have a LG LNC6753A71 the washer agitates drains rinses but won't spin. The motor runs but it won't spin.
May 01, 2011 | LG WM0642H Front Load
LG Washer WD 80490TP, At Spin Cycle not Spinning, seems to,start and then stop takes about a half hour to count down the 8 minutes of cycle, without spinning the clothes. Clothes are still wet
Pull the bottom panel off (if don't have access to the drain pump) and open the pump. I'll bet it's clogged.
Washers won't spin if they can't get all the water out...hope this helps.
Apr 02, 2011 | LG Washing Machines
Hi, I have an LG 1412RD washer dryer. I received the DE error message so opened the front to access the door lock and plugged in the electric socket which seemed loose. Now I am getting the OE message...
http://www.lg.com/au/support/product/support-product-profile.jsp?customerModelCode=WD-1412RD&matchedModelCode=NOT_MATCHED&searchEngineModelCode=WD-1412RD&initialTab=documents&targetPage=support-product-profile#
Owners manual above. LG washing machine error code – OEThe LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn’t pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Apr 10, 2010 | Washing Machines
Washing Machines Logo
43 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
