Question about Samsung CLP-500 Laser Printer
Dev motor error Samsung CLP 500
I'm getting the message Dev. motor error from my CLP 500.
I assume this motor will need replacement. Anyone done this?
  • ladams8729 Dec 21, 2008
    I have the same problem! Anyone know what to do to fix it?
  • itadvisor Feb 07, 2009
    I have the same error. The manual says its a fault with the developer motor..
    Problem Solver:
  • 8 Answers
The developer drive motor is identical to the main motor so you can swap them over and see if the same error persists or if it changes. The bad news is that it's a fairly involved strip down to get to it (both motors are behind the rear cover - you'll need to open left, right and top doors and remove the top plastic with the door release button before you can start to remove the rear cover) and even with the rear cover off, IIRC you need to remove the formatter PCB and PSU. In short it's not a job for the faint-hearted!
As others have suggested, it may be a mechanical problem with the toner cartridges and this is far more likely than an electrical fault; plus easier to confirm and fix...
Posted on May 04, 2009
Take the 4 cartridges out of the printer and check each toner cartridge to see if the rollers can be rotated. If its difficult to rotate a roller, then replace the cartridge. If you have a faulty cartridge you may see that the small white wheels at the end of the roller are misalligned.
This worked for me.
Posted on Mar 09, 2009
  • 193 Answers
The transfer belt maybe defective or run its course..end of life
go into the menu, and see what the setup tells you
Posted on Mar 08, 2009
Keep getting dev.home error. Does anyone have any ideas ?
it is time to replace your DEV Main Drive. it is normally couser by wear and tear with your printer fuser gear.
replace both will solve this issue.
Apr 07, 2010 | Samsung CLP 300 Laser Printer
Error message Engine Fuser Overhaet
The fuser rollers (large orange rubber rollers visible with top cover open) are getting too hot, or the temperature sensor/wiring is faulty and misreading the temperature. Assuming sensor is okay, check the exhaust fan is running and expelling warm air as over time it will clog with dust and the fuser unit won't be cooled effectively.
May 04, 2009 | Samsung CLP-500 Laser Printer
Brand New printer status led RED, Smart Panel error "dev home"
Samsung CLP-315 Dev Home error
It appears that the Dev. Home error is very common for Samsung printers. It obviously has different reasons. In my case I solved it by stabilizing the deviation clutch. It was too unsteady and the dev. sensor recognized a fault.
The dev. clutch is situated under the right cover, which is the power supply side of the printer. To remove this cover you need to firstly remove the top cover, which is held by two screws on the front. Then uncover the right side by unscrewing one screw on the back, near the power supply inlet and unclip a couple clips on the top side of the cover. After removing it you have to find the deviation electrical clutch. Check if it is too unsteady. If it easily moves, you need to somehow stabilize it, in my case by a couple of leather straps under it, so that they press it up and make it steady: 5_19_2012_1_08_58_pm.jpg
After that simply check if you have stabilized it properly. If you have the green light must turn on after switching the device on.
NB! Be extremely careful when power is ON, because there is high voltage running. I'd suggest that you would stabilize the thing with non metallic item to keep safe. Good luck!
Apr 13, 2009 | Samsung CLP 315 Laser Printer
Samsung CLP 500 Error message 'Replace transfer roller'
You need to enter the hidden engineer menu: turn the printer off then turn on again whilst holding down the enter key on the control panel. It should say something like EDC menu on the display and you can scroll through several menus to find the one about resetting counters. Be careful not to play with other options as you can screw the printer up if you don't know what you're doing!
Mar 31, 2009 | Samsung CLP-500 Laser Printer
Error Jam0 in tray1
Feb 09, 2009 | Samsung CLP-500 Laser Printer
"Lever Unlocking Error" Message
Probably a bad connection between the transfer belt contacts and those inside the machine - clean any dirt/toner off them and make sure they aren't bent out of position and try again.
Dec 30, 2008 | Samsung CLP-500 Laser Printer
Home dev. error
reinstall the affected dev assy, or try to removed and put back again
Oct 25, 2008 | Samsung CLP 300 Laser Printer
Waste Motor Error message on Samsung CLP-500
This error is caused by the Waste Toner Motor 'stalling' - usually as a result of the Waste Toner Full message being ignored for too long, and the waste system becomming overful.
Usually best to replace the Waste Toner Motor assembly.
They are for sale on auction websites from time to time.
Sep 12, 2008 | Samsung CLP-500 Laser Printer
Main Motor Error
I'm stepping out on a limb, but I bet it will be the Main Motor.
Mar 12, 2008 | Samsung CLP-500N Laser Printer
Samsung CLP 500 series Laser Printer
If the messages are because the two units have reached their rated page count, you need to reset this via the printer menu system - see user handbook
Nov 12, 2007 | Samsung CLP-500 Laser Printer
Samsung CLP-500 Laser Printer Logo
209 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
