DH-10PF Comtrend dim red lightWhat's your problem?
When switched on status light is dim and adapter will not work
3 Suggested Answers
damonumber5
  • 340 Answers
SOURCE: i have 2 comtrend dh-10pf
To start you need to factory reset both adapters,
plug them both into a wall socket next to each other, press the config/f reset button, hold in until ap light goes off, repeat on the other one.
Now you should have a red status light on both.
Press the config/f reset button on one for about 5 seconds, wait until ap light stays on, this one is now your access point (ap) that should be plugged in to your router when you have finished config.
Now press the ap adapter config button again for about 5 seconds until ap light flashes, then press the config button on the other adapter until ap light flashes, wait until they both stop flashing, wait a few seconds, the status light on both adapters should be green, and one adapter should have an amber ap light.
Hope this helps.
Posted on Mar 09, 2009
multilinkent
  • 739 Answers
SOURCE: Comtrend 9020 connection problem Unable to
Hi..
look at the problem you describe. Internet activity is most likely normal, but can not send a good Powerline Standard or High Definition (HD) movies
I said like that because the red led error is when the connection is less than 4Mbps, normal Internet activity Powerline possible but can not send good films Standard or High Definition (HD) movie
see in the picture below
try to do reset to default again
ways to do factory reset
Download manual guide for your reference
CLICK HERE TO DOWNLOAD
regards
hope this will help you
Posted on Apr 02, 2011
Help. I need help properly connecting wires on a new ceiling fan.
Usually, the fans with remotes will dim the lights by holding the light button for a few seconds. So, the red wire would stop this feature if wired directly to the fixture. That would eliminate the wire coming out of the receiver for the lights. If you want the light to dim, then tape off the red wire, so the remote will dim them. The wall switch won't work anymore. If you want to connect the red wire , tape off the wire from the receiver that connects to the light sockets and connect the red wire to the wire for the light sockets. This will operate the fan but the remote will not dim the lights. If you have a motor speed controller in the wall from the old fan, remove it and replace it with a switch or eliminate the switch altogether so the remote will control the fan speed.
Nov 13, 2016 | Dryers
My acer aspire 4730Z is not turning ON....battery is down....when am connecting dh charger pin to dh lap, dh green indicator of dh charger goes on blinking. Lap top is like completely dead dat even dh...
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Replacement Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Intocircuit Acer Aspire 4730 AC Adapter 65Watt 19V 3.42A
Nov 19, 2012 | Acer Computers & Internet
Please help......!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Dash lights don't work anymore after installation of a new cd player. I have a 1999 honda passport. There are two 'extra'...
Sure about the connection,you are supposed to use audio fuse circuit 2 and or audio fuse 19. the color out are Red/yell, Red/white. This comes from the dash box fuse
Mar 14, 2012 | 1999 Honda Passport
Turned my ethernet adapter off on the upstairs one and back on to find that there is no green lights anymore, just a red light on status. Then did the same with the downstairs one and they both have a red...
Powerline adapters are generally not durable. You can try to reset the power adapter by pressing the reset button located on the device itself. If it still gives you a red light than call the manufacture and get it replaced.
Jul 15, 2010 | Powerline Ethernet Network Adapter
Can not turn my comtrend powerline adapter of standby
i have the same problem,and i'm working on it,most probably a faulty capacitor in the power supply,i will let you know.
Feb 18, 2010 | Computers & Internet
I have 2 comtrend dh-10pf powerline adapters. one of the adapters status is a red flashing light and the AP light and the Ethernet light are blank. the second powerline adapter has a solid red status...
Hope this helps.
Jan 28, 2009 | Computers & Internet
Comtrend ct507 no power
- try to use a known working power adapter with the same specs, it might be the power adapter is not supplying enough power, or
- try to press the reset button (if it has one) for like 30 secs, then turn the device off for another 30 secs. (Note: this might delete all the settings on the device)
- most probably the device is dead if same thing happens after pressing the reset button.
hope this'll help you
Jun 08, 2008 | Comtrend CT-507 Router
Computers & Internet Logo
David Payne
David Payne
