Question about Daewoo Televison & Video
Daewoo DSL-17D3 automatic tuning
I have moved this tv downstairs and it has lost most of the channels stored in it. I have been to install but there is no option to automatically tune the channels. Also the tv is connected to sky and isn't picking it up??
cell expert
  • 30 Answers
SOURCE: Tuning playstation into the TV
Posted on Nov 24, 2007
  • 372 Answers
SOURCE: Unable to Tune TV to Sky + RF output
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
Posted on Jan 31, 2008
SOURCE: tuning TV onto AV chanel
How do I get the TV screen back to an AV chanel?
I cant get a slide show to view on the TV screen.
Posted on May 19, 2008
SOURCE: code for sky+remote control for lg tv 50pc56
1293 worked for me. But here are some more
0037, 0056, 0060, 0065, 0080, 0081, 0125, 0137, 0178, 0191, 0204, 0244, 0245, 0275, 0318,
0389, 0391, 0398, 0405, 0459, 0502, 0742, 1146, 1367. We also have some older codes;
206, 037, 060, 065, 080, 137, 191, 244, 245, 275, 318, 389, 391, 398, 405, 459, 502.
The codes are stored in a database of the Sky remote. If the above codes don't work
you may need to buy the latest Sky remote. Otherwise it is a matter of waiting for the
new Sky remote which may have the updated codes. Best regards, LG Electronics.
Note: LG Support supplied the following for Rev.8: 0206, 1293, 1665, 1174, 1176, 1219, 1280, 0857, 0851.
Posted on Nov 05, 2008
SOURCE: technika tv lcd 19-907 tuning in to sky in bedroom.
Hi, with regards the tuning in of the required station I started from the beginning again and after the digital channels had been automatically tuned in it asked if you wanted to tune in the analogue channels . I clicked on the yes button and it tuned in a number of channels and when checking through the channels I found the sky channel required from downstairs which is linked by an aerial connection.
AS Gordon Ramsey would say :------ telly tuned in DONE
Posted on Dec 15, 2008
Have daewoo tv model dsl-17d3 and need code for one for all remote control
028,081,072,091,095,099 are the codes to check. If you wish to get more details, check this site. Pull up previous posts there. Setup code list and setup proceedings to many popular brand remote controls are given. Three digit, four digit, five digits and two-digit code list are there. Check the site with patience. Surely you'll get a solution to your problem. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter."
Mar 31, 2013 | Televison & Video
DAEWOO DTQ-20V8SSFG Shows one Channel only
First ensure that you are performing the auto channelling procedure correctly.
If you are sure you have done everything in the proper way, and channel tuning still does not work, than that means that the tuning board inside your TV is faulty, and is not storing channels in memory, therefore should be replaced.
Oct 29, 2008 | Daewoo DTQ-20U4SC 20" TV
Instructions to tune Philips tv 54cm colour TV. Search & store channelss
You haven't mentioned about the model number of your Philips TV. Different models have different type of tuning procedures. Any way I hereby send a procedure to set it autotuned. If it Doesn't work, please inform me through Fixya, stating your TVs model number also. ok
Press "Menu" on the remote control handset, and select the installation language.
Select a language and confirm it by pressing "OK" button on the remote control.
Press ' button to return to 'Instalation' menu.
Press "Menu" on the remote control handset and select Installtion > Preferences > Location.
Select 'Home" and press "ok" to confirm.
Press ' to come to the Installation menu.
Press "Menu" on the remote control, "Select Installation" '>' Channels '>' Autoprogram '>' Start now.
Press "OK" and allow the start installation automatically.
If you run autoprogram when you have locked channels, a messege appears asking to enter your PIN code in order to complete instllation.
Try this, if doesn't work inform me with TVs model number. OK.
Nov 04, 2010 | Philips Televison & Video
Hi, I have a digital tv plugged into an extension cable in an upstairs (Toshiba) bedroom; it works perfectly - receiving all channels. I have a digital tv downstairs (Samsung) where it seems the wall...
Hi Fiona
Somewhere along the line from the aerial there must be a signal splitter that feeds the upstair and downstair terminals.
Try to find that splitter and switch the output to see if the problem goes from up to downstair.
If it does switch then you know the problem is with the splitter block, and if it stays the same then the problem is with the cable and/or the connectors that run downstairs.
Also the reason you get a pixellated(snowy) picture is because of signal loss during the length of the cable you ran downstair.
If running a cable downstair becomes the best option to fix your problem , then you could buy a cheap 10db signal booster/r.f amplifier to correct the signal loss and a cable splitter to feed both tv`s
That booster would be installed upstair in your case(near the source of the signal to be amplified).
I could send you a small diagram if need be. Hope this will help and Merry Chrismas
Dec 14, 2009 | Televison & Video
My daughter can't get BBC1, 2 and 3 since 4 November. Signal comes from Winter Hill. My TV is a Goodman (with built in Video)and my freeview is a Pace. My Pace system automatically searches but misses...
When TV channels are moved from one frequency to another frequency that was previously used by a different channel (sorry, but there's no simple way of saying that !) as has happened recently in th UK, some digital TVs and digiboxes struggle to sort the channel list out properly and channels can go missing as you describe.
If your equipment has the option to delete all currently stored channels (normally in the tuning menu options) then do so and then do a full re-tune.
Sometimes, this solves the problem as the equipment is no longer aware of any previous use of a frequency and just loads every channel it finds.
If this doesnt work, or your equipment doesnt have the option, then there is normally the option soemwhere in the menus to retore the item to "factory defaults/configuration". This will clear all previously stored channels and after a full re-tune your missing chanels should be there. However, any other configuration changes you previously made, e.g picture size, output type (RGB/NSCT/etc), etc will be lost and you'll need to set these again.
NB. some regions of the country have lost some channels temporarily now until after the switch over programme completes at the end of 2012. If you visit the Freeview website, this will tell you if your area is affected.
Nov 06, 2009 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Technika tv lcd 19-907 tuning in to sky in bedroom.
Hi i had the same problem but i have sorted mine now. What i was doing wrong was i wasnt tuning in the analoge channels only the freeview digital ones. To do this you need to first turn your tv on. Then press the "source" button, this will bring up a little menu at the top left hand side. When this menu comes up press the "Programme +" button (the one that you use for changing channels near the volume button) press this until you get up to "TV", when T.V is highlighted just wait 3 secs and it will switch over. You will probably get a blue screen with a no signal message (you are now on analogue) when you get this blue screen press the "tune" button. It will automatically start tuning in all of your channels, at first they will be fuzzy but as it works they will become clearer. Your sky channel will also be tuned in. When mine tuned in it didnt tune them in on the right numbers though, bbc2 was on number 1 etc. If you ever need to use a playstation or something it goes into the scart connection at the side of the t.v and you need to press "source" and go up to "scart". To get back onto the digital channels just press "dtv/dvd".
hope i helped!
Dec 14, 2008 | Televison & Video
Problem getting cable to tune in to Daewoo TV
you need to get back origenial daewoo remote control to do the setup input & output. good luck!
Mar 02, 2008 | Daewoo DTQ-20U4SC 20" TV
Televison & Video Logo
62 people viewed this question
Top Daewoo Televison & Video Experts
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
