Question about Honda CR 125 R Garden
I need the fuel/oil ratio for a 1983 cr 480 - CR 125 R Honda Garden
dontbother10
  • 2220 Answers
SOURCE: i need to know a fuel oil ratio.
Regardless of what the manual says once adjusted your saw will perform better with this mix.
Do you need bar oil? Available at any Hardware or Home Center.
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL suppliers recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Lou
Posted on Dec 28, 2009
  • 4088 Answers
SOURCE: Ineed to know what the fuel to oil ratio is for
Run 30:1 or 32:1. With modern synthetic oils, you could probably get along with 40:1 without trouble (and a lot less smoke). Good luck!
Posted on Apr 29, 2010
  • 583 Answers
SOURCE: eager beaver 60012312 fuel to oil ratio
to be safe always use 25 to 1 on anything
Posted on May 09, 2010
  • 12 Answers
SOURCE: fuel to oil ratio.
40 to 50:1.
Posted on Jun 13, 2010
  • 2239 Answers
SOURCE: i have a 1983 jonsered 520 sp and don't know
You should run it at a 25-1 fuel oil mix, use a good quaility two stroke oil.
Posted on Oct 10, 2011
Bike is bogging down under power, oil leaking from header pipe and tail pipe possibly from shot rings
wot make of 2 stroke oil you using ? wot fuel oil mix ratio ? per gal use 2.5 oz with quality race oil !
Apr 08, 2012 | 2003 Honda CR 125 R
I have a 1983 jonsered 520 sp and don't know the fuel ratio for this saw
Oct 09, 2011 | Garden
I have an 04 husky cr 125 and the fuel ratio i had is 32-1 and it fouled on me! i just go around the yard but sometimes on trails. should i go to a 40-1 ratio? or a 50-1 ratio?
Some guys will tell you to go to 50-1. Don't. 40-1 would be okay. If that doesn't stop the fouling, go to a hotter spark plug. An example would be BR8ES to BR7ES. The lower the number, the hotter the plug. By the way, you ARE using two stroke ENGINE oil and not MOTOR oil aren't you??? Please rate my answer.
Aug 15, 2011 | 2004 Husqvarna CR 125
What is the oil,fuel ratio?cause it runs like the spark plug is filed,and it iddles fine,cranks fine but will not open up!can it have anything to do with the RC power valve?
maybe-but carb jets are more important-the high speed ones are dirty or need ajust-get a pro to doit cos without proper lean/rich ratio u cud fry the engine
May 16, 2011 | 2003 Honda CR 250 R
What motor oil do i use for my 2005 CR125 honda
You need to use a 2 stroke motor oil. Look for oils that say 2 stroke motorcycle oil, injector oil or smokeless. Do not use a standard automotive motor oil, your bike will smoke. It should be pre-mixed with your gasoline. I am relatively sure the ratio is 32:1, but you should check your owners manual to be sure. At this ratio you would use 4 ounces of oil to each gallon of gas. This ratio allows for an all-around use of your bike. If you are not going to use the bike at high speeds for extended periods, you may want to consider a different fuel/gas ratio - 50:1.
The above information is recommended for a Stock motorcycle.
Regards.
Jan 09, 2011 | 2005 Honda CR 125 R
Model PM374 mixture ratio please
Hello George:
I cannot find an OM for your saw. I did find 3 IPLs the oldest being 1993. I have 2 McCulloch (1983 & 87) saws both older than yours and their OMs recommend the current mix ratio of 40:1
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
May 10, 2010 | McCulloch Garden
I need to know how much oil my 1983 yz 125 takes
HI MATEON SIDE OF CASING IT WILL SAY SOMETHING LIKE 700CM2 OR 700CC WHICH WILL EQUAL TO 700ML OK OR LOOK AT SIGHT GLASS IF HAS ONE
Aug 29, 2009 | 2003 Yamaha YZ 125
Oil to petrol for 5.litre can
the fuel to gas ratio should be 50;1 50 parts oil to 1 part fuel
Mar 26, 2009 | Water Sport
1983 Maico 490 Spider
The bike uses around 600ml of gear oil, but you should always check the level at the level bolt. When the bolt is removed, fill oil until it flows out the level hole. Replace bolt. Run the motor briefly and then inspect the level again. Add more oil if needed. Use BelRay trans oil 10w80.
The fuel mix should be 3.5 percent oil to unleaded fuel.
If you are not racing, mix 30:1
Always use a good fully synthetic oil
Jon
Feb 19, 2009 | 2005 Maico 620 Supermoto Racing
GAS MIXTURE CR 125
i would mix it 50/1 it will make your bike run a whole lot better
Nov 28, 2008 | 2002 Honda CR 125 R
Garden Logo
107 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
