Question about Philips 43P8341 43" Rear Projection Television
Color convergence I cant get the blue cross to go up. It is all the way dowm.
  • henryj11 Oct 26, 2008
    Thanks. I'll try that. Where can I get one?
    Thanks a bunch. I'll get one.
    Genius:
  • 2,920 Answers
It sounds as thoough you need a new convergence board
Posted on Oct 26, 2008
  • Ronnie Houston Oct 26, 2008
    any tv shop can order it if u guve them the make and nodel of the tv.other wise you can look up your make and model on here and locate it that way.
I have a Sony KDP-57WS550 TV that has a convergence problem. Based on the symptoms, I'm not sure whether to indict the convergence ICs. In the convergence mode, I can move the red (and blue) crosses,...
With your TV in setup Use a small magnet to "move" the non converged Red, Blue, or, Green color lines "crosses" (each CRT will need to be adjusted in turn) by moving the magnet close to the offending Red, Blue or,Green color CRT yoke or, tube while observing the movement of the CRT color line "cross" in a mirror ( try several places near the tube and, several strengths of magnets:) a refrigerator sheet magnet works well (you can cut these with a scissors to make a better fit or, apply less magnetic "pull." by making them smaller (you may need more than one magnet per tube to fix each CRT's convergence) When you have each CRT tube's convergence right, apply some clear silicone adhesive to the magnet and, permanently affix the magnet to the now "fixed" CRT tube exactly where you placed the magnet to obtain the best convergence on the CRT.
(Do not adjust the "Green" CRT unless you must, as it is used as the color line to adjust other lines to)
Jun 30, 2011 | Sony Grand WEGA KDP-57WS550 57" Rear...
Toshiba51hx83 convergence problem
Sounds like your convergence ICs are faulty If you cant move both red and blue in all 4 directions its usually your convergence amp ICs. They are prone to failure as they operate at such high temperatures. If you need any further info on this proceedure please let me know.
Jan 21, 2008 | Toshiba 51HX93 51" Rear Projection HDTV
The color is off and the figures are outlined in blue and yellow, plus the picture is cloudy looking.
Press menu on your set scroll down to where it says picture then press select. Now scroll down to convergence and press select. A white cross should appear on your screen. Your objective is to merge or converge all the crosses into the one white cross. If done right you should see only the white cross. You may see a little green and blue but don't be to picky. Make sure you read the on screen instructions on how to do this. After this you continue to the next step and you should see several white crosses across your screen. Do a convergence for each one of these crosses. Your picture should brighten up and your yellow and blue lines should go away. If it doesnt you have a bad convergence chip or some bad capacitors. If the first step doesn't fix it I would that you had a tech come and check it out.
Aug 05, 2010 | Philips Magnavox 9P6034C 60" Rear...
Have a projection tv...RCA model 61830BL. Had
Hi the green cross it cant move that the reference for red and blue adjustement ;just try to put the red and blue cross over the green pattern then quit/
if that doesnt work you probly have the stk-xxx ic
who control the color alignment ,are blow/
you will have to replaced and make the convergence
check if you have an auto adjustement for that most projection tv have one...
hope that help..
Mar 28, 2010 | RCA P61830BL 61" Rear Projection...
I have a ultrascan hd the convergance is off i dont have an owners manuel it tells me to use a curser what do i do to get the red blue right ?
The cursor probably is just a cross in the center of your TV screen whichever color your setting will be a color cross that you want to move by using the up, down, left, right, buttons on your remote. You want to move your color cross over the top of the center cross until it looks like one cross. Generalized setting instructions can be found here.http://www.ehow.com/how_2034880_perform-convergence--tv.html
If this helps let me know with a vote.
Mar 04, 2010 | Televison & Video
I'm having convergence problems, the three colors will not align
this is a free question you have posted--I know these sets very well---red and blue move, but not far enough?
sd tech
Feb 15, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Blue color
On front bottom panel remove behind it will be your focus/screen block cobtrol adjust Blue screen drive and focus also how to enter service mode for convergence with set off PRESS and hold at same time ch-&vol- untill set comes back on release you should now be in service mode for convergence.
Feb 19, 2009 | RCA D52W19 52" Rear Projection Television
Screen hazzy and issue with blue convergence
bad convergence would cause show to look as if it was supposed to be a 3-d movie, if a bulb was going out then people would look purple blue -green,or some other off color, so likely the green bulb is going out from the color of the people you described.
Feb 06, 2009 | Philips 60PP9202 60" Rear Projection...
Convergence problem
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
You can download the manual here. Insrtuctions for auomatic convergence are described. I copied the instructions below.
Automatic Convergence
Your HD Monitor’s picture tubes might have been disturbed during delivery or
after you moved the HD Monitor, causing the color in your HD Monitor to be
out of alignment. The colors adjust by starting auto convergence.
IMPORTANT: Auto convergence works best once the HD Monitor has
warmed up for at least an hour. If you've just unpacked your HD Monitor,
it's a good idea to repeat the Auto convergence function when the
HD Monitor's been running for at least an hour. See page 38 for more
information about Auto convergence.
1. Press OK to begin auto convergence.
2. When the auto convergence is complete, the Red center convergence menu
appears. The cross in the middle of the screen should be yellow. If it is not,
use the arrow buttons to move the red cross to overlap the green cross.
Press OK when adjustments are complete.
3. The Blue center convergence menu appears with a cyan cross in the middle
of the screen. If it is not, use the arrow
Sep 23, 2008 | RCA R52WM24 52" HDTV Projection Television
Color problem
Did you try alignment of color convergence in setting up. Try this
1 Press MENU
2 Select SET UP
3 Select CONVERGENCE
4 Select screen mode ZOOM this accesses the center convergence adjustment.Press set/enter
5 Use arrow keys to aline the red cross to the white cross.Press set/enter
6 Use arrow keys to alingn the blue line in the same manner. Once adjustment is complete press MENU to turn the menu off.
I hope this helps if you cant move the red or blue lines you face the same problem I face. I still havent gotton any solutions to my post about being unable to adjust the red line.You could also call Pioneer's help line 800-421-1404.
Oct 04, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Philips 43P8341 43" Rear Projection Television Logo
63 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
