Question about Hotpoint Aquarius WD63 Front Load Washer/Dryer
Aqarius WD420 I'm concerned about the lack of filters on the pump out and does the dryer ever get clogged by fluff like other dryers I have used? Hope you can advise Regards Bob
    Scholar:
  • 155 Answers
Http://www.washerhelp.co.uk/washing-machine-usage.html
check out this link
good luck
thanks.
Posted on Oct 26, 2008
Is there a filter to catch fluff during wash?
How to Reduce Lint in Laundry - Home Ec 101
www.home-ec101.com/how-to-reduce-lint/
Sep 23, 2010 - I clean out the dryer lint trap every time and that doesn't seem to matter. ... If your washing machine is older, there is a chance that it has a built-in lint trap. If this is the case and ... Follow the directions for cleaning the lint filter.
Washing Machine Pump Filter - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 8, 2013 - Common problems and faults with a washing machine pump filter. ... a pump filter to protect the pump from a build up of lint, and obstructions such as coins. ... towel to catch water and don't take it out at all if the washing machine still ... If you can't see any blockage, or there is just the odd button in there that ...
Is there a filter to catch fluff during wash? - Fixya
www.fixya.com/support/t26006809-filter_catch_fluff_during_wash
3 hours ago - Locating fluff filter on aeg washer/dryer . After using the dryer facility the following wash resulted in garment containing patched of fluff ...
How To Clean Your Washing Machine Filter - YouTube
Dec 13, 2015 | Washing Machines
Lg clothescare dryer dlec733w
There is usually a sensor beyond the fluff filter that cuts in if over heating which can clog up with finer particles of fluff that evade the filter and give the impression of overheating, that is what is likely to be the reason. It is a job that needs a technician as it requires some dis-assembly.
Nov 11, 2013 | Dryers
My BOSCH dryer #WTE86300US keeps stopping in mid cycle and gives the signal -0- what does mean that error code?
check fluff filter usually in the door is clear, it can be that it is overheating due to lack of air as the fluff filter is full. also check air escape pipe is clear and not blocked or folded.
I hope this was useful.
Oct 20, 2012 | Dryers
Sometimes when using the tumble dryer of my Hotpoint WD420 I get a puddle of water on the floor. Doesn't happen with every use. Do you know what the problem might be?
I suspect your dryer vent is blocked or partially clogged.. Also if your washer is not opperating properly putting wet close in the dryer could also cause this.....hope this helps!
Feb 19, 2011 | Hotpoint Ariston Aquarius WD420 Front Load...
Where is the filter on a Hotpoint Aquarius wd420 washer dryer?
it is located at the back of the machine...are you encountering problems with this machine? check this link i will give you, this a forum/comments which the owners encountered different problems with this machine..
http://www.unbeatable.co.uk/p_rupr/Hotpoint-Aquarius-WD420-Front-Load-All-in-One-Washer--Dryer-Reviews/22394331.html
Nov 13, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
Dryer doesn't heat properly. There is warm air, but it takes two cycles to dry clothes
If your dryer gets warm but your clothes are taking longer than usual to dry, then the cause is most likely the Lint filter that is clogged thus blocking the moist air to escape: remove all the 'fluff' that is stuck to the filter.
In all cases, make sure that the hot air is exhausted outside the room where your dryer reside.
Hope the information is useful: let me know how you go.
Sep 24, 2010 | KitchenAid Dryers
Not pumping water out
You nead to check the filter.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well.
Hope this helps.
Dec 14, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
WHIRLPOOL DRYER- CLOGGED WITH FLUFF DOWN THE BOTTOM
Try hooking it out with a long piece of fairly strong wire with a hook on the end.
It won't stop the dryer from working, but if it is vented , remove and clean the vent hose by running water through it, this will remove all traces of fluff, and make sure the outside is clear if it goes through a wall.
Plz rate my solution.
Thanks.
in the hse.
Jan 05, 2009 | LG DLE5977 Electric Dryer
Hotpoint Aquarius WD63 Front Load Washer/Dryer Logo
102 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
