Question about Kenmore 24032\24036 Top Load Washer
Spin is weak - Kenmore 24032\24036 Top Load Washer
  • Kenmore Master
  • 19,396 Answers
You need to have the motor and the belt tension checked, if the belt is not well in tension, or if the motor or the motor bearings are defective, then you get weak spin.
Posted on Oct 26, 2008
Won't spin fast when fully loaded
You may have a weak clutch. If you can stop the washer during spin by hand, that's what it is.
Jan 26, 2014 | Kenmore 24422 Top Load Washer
Weak agitation and spin
Possible that the drive belt is loose or the motor RPM is down or there is slipping.
Check this link for tips: replacing belt
Jul 05, 2012 | GE Washing Machines
Kenmore 90 weak spin and agitation, good coupler,
go to www.searspartsdirect.com put in you model number and you can pull up a explode view of the transmission.
Apr 13, 2010 | Kenmore 15864/15862 Top Load Washer
Im having trouble with my maytag neptune tl washer it wont finish the spin cycle
Please see the following Whirlpool / Maytag service manual for Neptune washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/dc59d905140253e18525729c005765f4/$FILE/Maytag_Neptune_Washer.pdf
On page 3-1 the manual explains that if the washer shuts off during the spin cycle, the problem points to a weak spring in the door lock mechanism.
"Shuts OFF In The Middle Of The Spin Cycle:
During the spin cycle, the machine control
monitors the door lock mechanism to ensure
the door is locked. This is done through the
door lock enable switch. During "lock mode,"
the shaft of the door lock mechanism is
pressed forward by the door lock wax motor,
and the shaft presses in the button of the door
lock enable switch. If the machine control
board sees the switch OPEN during the spin
cycle, the machine control board will automatically
shut the washer OFF. This is caused
by a weak spring in the door lock wax motor.
Replace the complete door lock mechanism.
Oct 25, 2009 | Washing Machines
Kenmore type 111, very weak spin
Clothes do not spin out good on NORMAL regular express, but do on casual.
Jun 24, 2009 | Kenmore 22422 Top Load Washer
Front Load Washer moving around because of the high rpm
if you dont have a weak floor just lock the legs,,,on the legs theres a nut on each leg..your unit came with a little wrench..that fits theses nuts,,,now you have to put unit on spin ,,when you get in highest or fastest spin ..adjust leg nuts than thighten them one at a time all the way up to the base of unit,,you might have to spin on high speed twice ..you will see when unit becomes steady...this wont work as well if you have a wooden floor or a weak floor..onthejob
Jan 31, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore washer weak agitate even at fast load and no spin
It could need a new belt. If there is damage on the belt it may also be dirty or stretched and thereby slipping and not giving you it's best performance.
Aug 01, 2017 | Kenmore 43142 Front Load Washer
Washer spins but not enough to extract water from clothes or tub.
could be a loss belt or a kinked hose, since you say it feels weak i would think it is not getting up to speed which would be a loss belt or drive train issue, of course it could just be to big a load or on slow spin speed setting
May 22, 2008 | Washing Machines
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Dec 31, 2007 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
