Question about Whirlpool Washing Machines
Whirlpool WFW9150WW00 What's error code F6E1 mean?
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: I have a whirlpool duet, I am running into an
The error is an indication a motor speed problem. You will need to check the following:
- Check the wiring harness. Verify all connections between the Drive Motor, Motor Control Unit (MCU), and Central Control Unit (CCU).
NOTE: The MCU is a circuit board located in the vicinity of the Drive Motor on the bottom rear of the washer. To access the MCU, you will need to remove the back panel of the washer.
NOTE: The CCU is the main computer for the washer and is located behind the wash tub. You will need to remove the top panel to access the CCU. This is accomplished by removing the three screws in the back of the washer that hold the top in place. Once the screws are removed, the top panel will slide back, then lift off.
- Check the Drive Motor. Perform a continuity check of the Drive Motor windings. Remove the connector plug and check across pins 1 to 2, 2 to 3, and 1 to 3. All readings should be approximately 6 ohms. HINT: You can also take this reading by removing connector 2 from the MCU and measuring across pins 1, 2 and 3. If the readings are good, this will also prove the wiring and connector good.
- Check the MCU. The connectors are numbered 1 to 3 (L to R). That is, with the MCU installed, connector 1 is on the bottom, followed by 2 in the middle, and 3 on top.
Connector 1 - is the serial communications link between the MCU and CCU and has three wires. At the opposite end, this will be the 2nd connector from the rear on the left-hand side of the CCU.
Connector 2 - is the link between the MCU and the Drive Motor. Pins 1, 2, and 3 on this connector are the Drive Motor windings. Pins 4 and 5 are for the tachometer.
Connector 3 - is the primary power connector. Pins 1 to 2 should read 120VAC with the door in the locked position. Pin 3 is ground. At the opposite end, this is the 4th connector from the right on the front of the CCU.
NOTE: All the connector pins are numbered R to L.
If your continuity readings are normal for the Drive Motor and you have verified all connectors, replace the MCU.
If any of the Drive Motor windings indicate readings higher that 6 ohms, replace the Drive Motor.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 21, 2010
My GFE461LVS Whirlpool Electric Range overshoots temperature.
William muller, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (William muller), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 15, 2017 | Whirlpool Kitchen Ranges
On the whirlpool cabrio dryer what is the error code F 1 mean
Whirlpool F1 error code usually means that there is a problem with the control board.
Feb 25, 2017 | Whirlpool Washing Machines
F6E1 WHIRLPOOL OVEN CODE
what is the model #? sounds like a fused relay on the control board, or an element that is grounded to the frame. call a tech on this one, 240V appliances are not to be trifled with!
Mar 24, 2016 | Whirlpool 30" Self-Cleaning Freestanding...
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    What does f23 error mean?
    Display shows an error code - Front-load washer ' Whirlpool ...
    https://www.whirlpool.com/...error-code...w...
    Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
    What does error code f23 flashing mean on a Whirlpool ...
    Nov 30, 2015 | Washing Machines
    Whirlpool dp1040xtx flashing code 61 and 66. 61 flashed a couple times. What's wrong?
    F6E1 - Water is not present in the machine when it should be.
    Could be: inlet hose filter clogged, blocked holes on spray arms, dishes not loaded according to manual, water tap closed or water pressure too low, drain hose placed incorrectly, DW filters clogged, check dispenser (missing dispenser gasket, improper detergent), check water indicator (OWI or VWI) depending of model DW, check connections beetwen OWI (optical water indicator) and CB (control board), main motor, wiring, control board.
    Check the foam level in the appliance. Depending what kind of detergent was used. Was the foam level too high?
    Comment: Washing tabs combined with short washing cycles can produce too high foam level.
    Dado
    Jun 17, 2015 | Whirlpool Dishwashers
    What is Error Code "F6E1"
    I had the f6 e1 code flashing on Whirlpool Duet washer. It would stop midcycle and beep. I cleaned out the lint filter. This seemed to help but gradually the problem got worse. I cleaned filter again. Still beeping. I read more solution and finally found the answer! I never put the cover back on. There is a switch on the left bottom that is held in by the cover. Works fine now!
    Jan 14, 2012 | Whirlpool duet Washing Machines
    ERROR CODE # F6E1 displays and shuts down oven
    F6-E1 - Return Line Not Connected - Replace control board (clock).
    Dec 23, 2008 | KitchenAid Kitchen Ranges
    Washing Machines Logo
    116 people viewed this question
    Dan Webster
    Dan Webster
    Sal DeAngelo
