Question about Measuring Tools & Sensors
Wet ceilings my ceilings get wet everytime there is frost on my roof, why and what can I do to prevent this? My roof is just over a year old and the mositure problem started when I had the new roof done.
  • 115 Answers
As a former roofer I would suspect condensation dripping from a non-insulated roof underside where the actual beams are, if the plywood is actually exposed to your view, this may very well be where your problem lies. If when your roof was installed, it may very well be you had a handyman and not a certified roofer install your roof, which in turn would render you an improperly installed roof, you did not indicate whether this is a flat roof or shingle roof, however a coat a flashing cements by a brand called Karnak or metal flashing may indeed help your situation.
Posted on Apr 02, 2011
You need ventilation in your roof hot air is condensing on cold material which cause a water drip
Posted on Jul 05, 2009
You might be getting what they call freezeback. Ask your roofer if he installed "ice shield". Guaranteed he didn't. Ice shield is a stcky backed (tar) membrane that doesn't allow ice to crawl under your shingles and leak into your house. This happens when your gutter freezes and ice builds. Code is you should have enough ice shield to project into your house at 3ft. So you should have 2 rows or around 6ft of ice shield installed from the end of your roof up and then the rest is tar or felt paper. This is installed almost the same as felt paper. You jus peel the back of it and it sticks all by itself. Probably easier to install than paper. The cost would be about 90 bucks a roll.
Posted on Mar 12, 2009
It sounds as if the roofer did not install the vapor barrier, (rolled shiney black tar paper, then the rolled black felt paper ) under your shindles.
Blackcloud.
Posted on Feb 10, 2009
    Problem Solver:
  • 18 Answers
You must conact your roofer and complain... COMPLAIN.. it sounds like you have a leak and the installers have allowed moistere to get under the roofing materials...!!!
Basically water expands when it freezes (ice cube tray.. over filled ) so if there's any kind of leak the water penetrates.. feezes allowing it to migrate up under the materials and then as the warm air from inside the attic causes the ice to then melt. I'd call and find out what the deal is.. especially if this has been going on SINCE the new roof was installed....
good luck
Posted on Oct 26, 2008
2 years ago our roof started leaking causing damage to our ceiling but now ceiling has bad damage and insurance company is denied our claim saying lack of maintenance and old rusty iron on roof
have the policy read by a legal representative and if there is no requirement to maintain the roof in as new condition ( rusty iron is still water proof ), have them counter claim for breach of contract
Oct 04, 2016 | Cars & Trucks
What Is Roof Restoration Coating?
I am currently obtaining information on roof paints and I can share what I have found out
roof restorers use a membrane paint rather than an ordinary acrylic paint or enamel paint as it is the most resilient paint for the application
IT is applied at a pressure of 3000 psi from a special gun and paint pump, cannot be rollered or brushed and goes on to a thickness of 150 microns ( around .120")
the cost is around $400.00 for 10 litres which covers around 10 sq meters ( 3ftx3ft)
acrylic can be sprayed or rollered or brushed on and is good for about 10-15 years depending on the roof to start with (thickness around .030" --same as car paint job)
costs around $180.00 for 15 lts and covers 14-16 sq meters
namel should be avoided as it does not have the capacity to expand or contract with temperature changes
professional roof restorers will repair any problems , clean the roof off and then apply the membrane paint as it gives a good quality result
other than that I would talk with paint suppliers as they have the same membrane paint that the professionals use and get ideas as to the way to go.
Aug 07, 2015 | Air Tools & Compressors
We have a mold and mildew smell coming from our air condtioner in our fifth wheel,what can we do about it? Everytime we use the air conditioner it smells bad. We tried sraying lysol into the intake but...
You can shut off breaker to the unit and go on roof and remove cover to do a visual check under cover in drip pan etc, as well as shine a flashlight in where filter at ceiling goes to look at coils and fins (way up inside) for any sign of mold etc. The hard part here is that I am going to assume it is a ducted system, and we can't be sure the mold smell isn't coming from the ductwork. Hopefully you"ll see something when cover on roof is removed.
How old is the trailer?
Aug 16, 2011 | Dometic Rooftop RV Air Conditioner
My fan shakes and wobbles even on low and it also seems to by loose where it mounts to the ceiling. What do I need to do.
I imagine you have a ceiling fan hanging from the roof?? These fans are mounted on a hook which is loose from the roof. This is to prevent any vibration being transfered to the ceiling itself. Generally, there is a domed cover to hide the hook and associated wiring to the fan at the point of attachment to the ceiling. This dome should have a gap of a couple of millimeters away from the roof. If the fan is vibrating, it can also occur because one of the blades may be loose or dislodged. Try tightening up any screws holding the blades to the motor body or refitting the blades. If this doesnt help, you may need to remove all the blased and weight them seperately. 1 may have "thrown" a balance weight and is now unbalanced. Much like an unbalanced car wheel vibrates. All the blades should weigh the same. I used to fix these by supergluing metal washers to the top side of the lightest blades to make it up the weight of the heaviest. It works but someone may have a better idea...
Jun 15, 2011 | Heating & Cooling
Stops blowing air
remove cover at ceiling so you can see in at fins and see if they are frosting up bad. If they are, I suspect during AC installation, they didn't open up ducts on discharge properly and air flow is restricted, which will cause freeze up, especially if low flow from discharge ducts. I'm assuming it is a ducted system. You may have to remove or drop down entire ceiling assy, to see if the ducts into ceiling have any blockage. Sometimes they don't cut rubber roof material back far enough, or misaligned ducts and cause restricted flow to ceiling vents, which will cause unit to frost up, which kicks out compressor until frost is melted, then compressor kicks back in and cooling happens again.
Apr 06, 2010 | Dometic Rooftop RV Air Conditioner
Coleman 1300, condensation buildup inside unit, ceiling wet
Check for plugged drains under cover on roof, sticking out at base of unit usually. It should be running off roof.
Aug 04, 2009 | Heating & Cooling
Wet line on ceiling between 2 air vents that runs about 8 feet
I would begin by inspecting and repairing the flashing around each vent. Generally you can use a caulk gun with a tube of roof cement for this quick repair.
May 17, 2009 | Heating & Cooling
Whirlpool refrigerator stop cold but frosting bad
Hello Catherine Fu,
Welcome
You said, you got this whirlpool double door refrigerator for 4 years. cost me about 1.5k. the second year, right after warranty, the main brain is down-the light panel in the refrigerator is off. whirlpool tech told me to replace it will cost me 500, so you decide not to do it. Now you have bad frosting issue for 6 month. Inside the Refrigerator, the water keep on dripping on side wall and glass drawer ceiling. In the freezer, frosting all over each drawer, and the bottom drawer has too many frosting and ice that i can hardly close the door. Last night, the refrigerator section just don't get cold anymore, it shuts up by itself.
Help!! It is an very expensive refrigerator and ONLY 4 years old .
First,I think you need to have a new tech.
It sounds like you have either an air leak allowing out side air in and this causes the icing.
Or you may need some freon (coolant gas) .
If your freon pressure is low it can ice up.
Did that tech that was there check for a freon leak and also check the pressure of the freon in the lines???
You need to call a different tech and let him see what's happening.
Some company that is reliable!
Let me know what they do for you.
God bless, Huuum
please remember to leave a rating.
Sep 28, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Measuring Tools & Sensors Logo
428 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
