Question about Toshiba SD370E DVD Player
Connections How do I connect this to a Freeview Top up box and a LCD TV?
    Guru:
  • 1,463 Answers
Can you explain the set up you have how it connected to each and is this just a dvd player or recorder.
riz.
Posted on Nov 18, 2008
Why am I getting after retuning two vertical black lines either side of my screen on some programmes "?"
Try to check the connections between boards inside the tv. If you can then remove those connections and reinsert it. especially the connection which go to lcd panel from the mother board
check the videos to know hoe to remove the connections .
If you wish to get some details; check the site linked here
http://electro-medical.blogspot.com/
Plasma TV Repair Ribbon Cable Removal Install Tutorial Overview LG LCD TV Repair How to Replace 6871L 2045A Con Board How to Fix LCD TVs
Nov 04, 2015 | Finlux 19H6030 19" LED TV 1280x720, 50 Hz,...
I bought a freeview box, My tv has only one scart socket. how do i connect my dvd player to combine with this?
You need a video switch box, that has two video and audio inputs and a video and audio output that connects to the video and audio connections on the scart cable.
Then you can switch between the DVD player or the freeview box.
These devices are available on the Internet, use Google to search for these devices.
Dec 17, 2011 | Televison & Video
I can not set up my freeview on my samsung 52 inch LCD can u help me step by step as I hav no instructions thanks
Plug your aerial into the freeview box. Connect a scart lead from the freeview box to your TV and switch on.
The freeview box, if new, will search for channels itself and as your TV will recognise that it is plugged in, will auto switch to the freeview box.
If it is not new, select menu on the freeview box and follow the instructions for tuning.
There is nothing to tune on your TV as you are using a scart lead.
Hope that helps.
Nov 14, 2010 | Televison & Video
I have just purchased the sony video player SLV SF900 for my mum. I have used a scart socket to connect through the freeview box and to the back of the video. I have also added the aerial sockets. The...
Not all SCART connectors and cables carry the IN and OUT connections - make sure that the one from the freeview box has OUT connections, that the cable can carry them and that the one from the recorder has IN connections. Then , to record what you want, all you have to do is to tune the freeview box on that channel and set the recorder to use that SCART connector as source.
Sep 03, 2010 | Televison & Video
Does this tv have freeview?
Sorry but this tv doesnt have freeview, it was made before freeview was built into tvs. But a freeview box can be connected to it via scart
Nov 07, 2009 | Sharp LC-15SH1E 15 in. EDTV-Ready LCD...
Built in freeview doesn't work but digibox does
Have you done a channel search on both tv sources(atv and dtv). most new tv's will automatically start will "New Install". If you havent had a digital installed recently then this could the problem. set top boxes and TV's will pick up the signal ok but others wont.
Sep 16, 2009 | Hitachi Televison & Video
Question regarding audio connections Akai 30" LCD TV
a switch box is needed the s video shares the red/white audio with the yellow rca that is being used already
May 07, 2008 | Televison & Video
Can't record Freeview
You should have the Freeview box connected to the VCR, then the VCR to the TV
Hope that helps =)
Apr 12, 2008 | Philips VR550 VHS VCR
Top box conns
your freeview box tv scart goes to the tv /the dvd goes to the aux on freeview and you can connect your vcr to the tv if it has a spare scart socket or the dvd player
Jan 14, 2008 | Computers & Internet
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
http://dysonmanuals.llc.nu/
Chris..
Jan 08, 2008 | Televison & Video
Toshiba SD370E DVD Player Logo
46 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
