Question about Garden
Craftsman rear tine tiller model 917.296030 won't shift gears not even neutrel
Won't shift in to any gear, engine runs . wheels move
steve_lima
  • 181 Answers
SOURCE: what type of lube is used in 917-294261 tiller gearbox?
80-90 gear lube
Posted on Jan 09, 2009
  • 909 Answers
SOURCE: There is power to the wheels, but no power to the tines.
there is a manual on e-bay $3.75
I hope this helps
Posted on May 08, 2009
  • 10865 Answers
SOURCE: rear tiller won't go into gear.belt needs replacing
find your model number from the list on this link and click to get your manual
http://www.managemyhome.com/mmh/owner_manuals/search?query=Craftsman+rear+tine+tiller
Posted on May 20, 2009
  • 138 Answers
SOURCE: Craftsman tiller engine dies when I try to engage tines
tilt the back of the tiller up and check for a rock or stick wedged in between the tines and the shield
Posted on Aug 21, 2009
SOURCE: Yardman Rear Tine Tiller tines won't turn. Belt
The problem lies in the shift lever in the gearbox. A poor initial design that was upgraded twice. The shift fork arms have spread enough for pins to come out of the groove they run in when the tiller is shifted to the last position. (Bending back into position would only be a temporary fix as would not be any stronger.) To replace shift lever, the gearbox cover has to be opened. Seperating the cover can be somewhat challenging. When prying cover apart try to not damage the cover gasket. Gearbox grease is very thick, so gasket's real purpose is to keep water and contaminants out. Leave all gearing and chains in place. The shift lever part number is 618-0245B. Or use assembly kit number 753-0869 (contains shift lever 618-0245B, position indicator, and roll pin.) Part will run in the $56-$68 range and can be found through MTD as well as Cub Cadet. Also can get through Sears PartsDirect.
Posted on Dec 13, 2009
Won't shift gears from shifting lever
and when the engine is not running do you get gears
Oct 22, 2012 | 1998 Ford Econoline
Why won't the gear shift move to drive
you need to check and see if your brake lights are working, the same switch operates the shift interlock solenoid.
Mar 05, 2012 | Cars & Trucks
Kawasaki vulcan won't shift into upper gears above neutral.
Broken selector claw spring
Ride Safe
Bike-Doc
Jan 31, 2012 | kawasaki Motorcycles
My 1998 Honda civic ex won't move but the motor
Have you just replaced the clutch? Taken out the transaxle, and put it back in? Are you sure transmission was in good condition before this? If so, review your procedure carefully to be sure you got it all back right.
Watch the slave cylinder while someone depresses clutch. You should see the little plunger move slightly out and move the clutch lever back. The lever moves the release bearing inside bell housing into contact with the pressure plate. If slave cylinder doesn't move at all, try bleeding again. The plunger has to move when clutch is engaged.
I'm not sure what you mean by "will shift but won't go into gear". You mean it's actually going into a gear position and car won't move? Or it won't go into any gear, period. As if you had no clutch?
Nov 06, 2011 | 1998 Honda Civic
I have a 1997 suzuki rm125 , it only shifts when im goin slow any speed over 5 mph its stuck in that gear and won't shift up, but when i let off and slow down it'll shift into higher gear no...
the chain is to tight when you put it into gear you loose 2-3 links of slack and if its to tight you cant change gear move the back wheel closer to the swing arm that should fix it
hope this helps
John
Oct 15, 2011 | 2003 Suzuki RM 125
1991 Honda Civic DX Why am I able to push the car with automatic transmission while it's in park? The car won't start and run, either.
If the car rolls with the shifter in the park position and the starter will not engage the engine than the transmission is not in park. This could be caused by a bad shift cable. In order to confirm this you will need to find the area where the shift cable attaches to the transmission. While a helper runs the shifter through the gears check the linkage at the transmission to see if it is moving. If the linkage is not moving that there is a problem with the shift cable or the shifter. Some disassembly of the center council may be necessary to gain access to the area where the shift cable attaches to the shifter to see if it is still attached to the shifter. If it is and the shifter is moving the cable than the cable will need to be replaced. If the cable is moving the linkage at the trans than there is probably something wrong internally inside of the transmission. If you have any questions or need further help I will be happy to do what I can!
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Sep 06, 2011 | 1991 Honda Civic
Bike has trouble shifting gears, chain won't move
Chains are intended to move in multiple dimensions while driving the bike or shifting among the gears. YOUR calibrated eyeball can see it while we can't. The Web has lots of advice and resources to well-crafted queries like "front derailleur won't shift" or "rear derailluer won't shift".
"how to (whatever)...." works for many things, too.
Great resource ...
http://www.parktool.com/blog/repair-help
Aug 14, 2011 | Schwinn Cycling
Why wont car shift into gear
Hello and welcome to FixYa!
You may want to start adjusting the brake pedals. If it detects that you are not stepping on the brake then it won't shift into gear.
If the gear is moving but won't shift gears while running then you may want to start on replacing the transmission fluid. It can be burnt that's why it's not operating properly.
Hope this helps and thank you for using FixYa! Have a good one!
Aug 14, 2011 | 1997 Ford Escort
Garden Logo
371 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
