Question about Cell Phones
I plugged the AC charger into the bluetooth headset but no charging lights showed
  • 51 Answers
Hi
may be your charger is not ok try to charge your bluetooth by another charger
thanks
your friend from fixya!
Posted on Oct 26, 2008
My nokia bh503 headset not charging
Leave it plugged in for 4 hours. Yello should turn red then green when fully charged
Oct 20, 2014 | Nokia Bh-503 Bh503 Bluetooth Stereo...
Why My Nokia BH 505 Stays Blue When Charging?
Do an Hard reset. Plug charger into the headset, press and hold power button and plug the charger into AC, light indicator will change after a while from red to green/blue.
Feb 14, 2014 | Nokia BH505 Bluetooth Stereo Headset
Red blinking light
Hi, Ephraim. The flashing red light indicates that the device is showing "low battery". It could be that the LG phone charger fits the charging port on your bluetooth headset but it is not compatible with your device. In order for you to know that it is charging, the device should show a steady red light(means charging).
Please take a look at the table reference below.
•With the Charger Plugged In
______________________________________________________________________
•Headset Indicator Headset Status
Red-----------------------------------------------Charging (battery level less than 50% charge)
Yellow-------------------------------------------Charging (battery level more than 50% charge)
Green--------------------------------------------Charging complete
With No Charger Plugged In
Off ---------------------------------------------Power off
Three blue flashes------------------------Powering on/off
Steady blue --------------------------------Pairing/connect mode
Rapid blue/purple flashes -------------Connection successful
Quick blue flash --------------------------Incoming/outgoing call
Slow blue pulse --------------------------Connected (on a call)
Slow blue flash ---------------------------Standby (not on a call)
Slow red flash ----------------------------Idle (not connected to phone)
Slow purple pulse -----------------------Connected call muted
Steady red ---------------------------------Attempting to connect
Quick red flash ----------------------------Low battery
Note: After 20 minutes on a call or of inactivity, the light stops flashing to conserve power, but the headset remains on
Hope that'll help you in some way.
**Please rate my post and/or leave a comment** ...Thanks...
Sep 25, 2013 | Motorola Mobility H560 Bluetooth Headset
I get blue/ red light instead of red/blue wen m pairing wid my iphone
Try resetting the headset: When plugging in the AC charger, hold the power/pair button down. The headphones will show a solid red or blue light when they have been successfully reset.
Good luck from Headsets Direct - 800-914-7996.
Aug 17, 2011 | Plantronics Backbeat 903 Bluetooth...
Charger shows blue light, however after charging for several hours, headset will not turn on. This is a re-furbish headset from eBay however cannot tell if the charger is working or a bad headset, any...
Since you have nothing to compare it to, it's going to be difficult to pin down the culprit. Being a refurbished headset you want to make sure the ac adapter is the right one (the light on Plantronics chargers is green, not blue). You can call them at 800-544-4660 x5 x5538 to get the specs on the charger.
Good luck from Headsets Direct!
Jun 26, 2011 | Plantronics Voyager PRO Bluetooth Headset
My voyager pro+ keeps flashing red when charging. However when it is unplugged with charger, it does not work at all. Please kindly help.
If it is flashing red like it is supposed to be charging, and it is not, look at the connections. Are they worn, not connected properly? Make sure that the AC charger is plugged in firmly. If this still fails to charge your bluetooth, it may have to do with the bluetooth itself. If this is still under warranty have it replaced. Try a different outlet or charger to see if that is what is not working.
Jun 19, 2011 | Plantronics Voyager PRO Bluetooth Headset
My plantronics voyager pro will not charge turn on or anything. do you know the peoblem?
I have seen on some Plantronics Bluetooth headsets that you can perform a system reset by doing the following, It might help but not sure.
Instructions:
While plugging in the AC charger, hold the power/pair button. The headphones will show a solid red or blue light when they have been successfully reset.
Jun 18, 2011 | Plantronics Voyager PRO Bluetooth Headset
Can't get it to show up on my phone
How to perform a system reset
Start with the headset off (no light). Press and hold the on/off button and without letting go plug in the AC charger (you will see steady light on the headset). Let go of the on/off button as soon as you see the steady light. Unplug the AC charger from the headset. Test the headset to see if the reset was successful.
If this does not resolve your issue you may have to replace the headset through Plantronics Service Center.
Apr 20, 2011 | Plantronics Backbeat 903 Bluetooth...
I am having problems getting my Voyager Pro bluetooth to recharge. I am not getting the solid red light to indicate the unit is charging.
So if it won't charge, it may be that the charger is bad, and you may not have a way of charging it to find out if it is the charger or the battery. If it is the charger you can get a new one, there is a link below to the right part. If it is the headset and it is still under warranty return it to the vendor.
Plantronics 79414-01 AC Adapter
Oct 21, 2010 | Plantronics Voyager PRO Bluetooth Headset
Cell Phones Logo
37 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
