Question about Cerwin Vega LW12 Subwoofer
Cerwin Vega Sub LW12 blows fuse
Ive replaced the fuse twice and it blows each time.
2 Suggested Answers
  • 29 Answers
SOURCE: I have a blown LW12 Cerwin Vega Speaker. Can
You have several ranges of options.
1) Contact Cerwin-Vega customer service: http://www.cerwin-vega.com/
2) Do a google search on "cerwin vega speaker replacement". You will find companies both that offer repair or repair kits (e.g., www.simplyspeakers.com) or sell replacements. Contact them - they have the expertise to tell you which of their products are most suitable for your model.
Posted on Nov 01, 2009
Bad plate amp
http://www.parts-express.com/cat/subwoofer-plate-amplifiers/332 Subwoofer Plate Amplifiers
Feb 18, 2014 | Cerwin Vega LW12 Subwoofer
Can i use another 4a 250v fuse for my cerwin vega LS12 if its not a (slow blow) ,and what would be the outcome
Fuses have different blow characteristics. Such to protect components differently. An extremely fast fuse would protect sensitive components like tweeters and slower fuse will allow transcients to pass and blow on long time fault. If you put a slow blow in place of fast blow, it won't blow as quickly, but it could allow the protected device to be damaged. In reverse, you put a fast blow in place of slow blow, it will blow at normal transcients and be a nuscience to always replace.
You can cross to a fuse of different manufacturer. The reliable manufacturers will have detailed datasheet and subsitute or similar fuse to the fuse you are looking for.
Oct 23, 2013 | Cerwin Vega LS-12 Speaker
I need a replacement sub woofer for my LW 12
Polk Audio PSW505, BIC America F12, Hsu, SVS, Outlaw, Axiom Chane Subwoofers
Sep 03, 2012 | Cerwin Vega LW12 Subwoofer
I was given a Cerwin Vega LW12 by a friend. It works fine for some music at any volume, but with certain types it has a popping coming out, even at low volumes. Switched speakers and still happens....
phreewillie,
If you are certain that the problem is not with the speaker(s) the problem then sounds like an issue before the amp.
Did your friend have this issue? If yes, the problem is with the built in amp/crossover. If no, there is some kind of problem in your location.
The amp will not produce the popping sound even if the the amp has a problem electronically. The problem could be improper voltage, line noise, wire resistance or a grounding issue. The first two would be eliminated by using a line conditiner with a built in surge protector. The resistance and grounding issues would be associated with the wire connecting the sub to your electronics. It could be simply the cable connecting the sub has an issue, try swapping it with one that you know works fine. Are you using in wall wiring? Try using like stated above, a short known good patch cable. Sometimes the wire of choice during a installation will not work for that amp. Try taking that in wall cable out of the loop. I have seen just this problem in the past due to the type of wire used. A low cost way to eliminate the voltage issues is to try a different source of electricity by taking the sub to a friends house and see if you can reproduce the problem there.
-Chris
Jan 19, 2010 | Cerwin Vega LW12 Subwoofer
Cerwin-Vega 12'', no power
It should have a small fuse on the board between the transformer and the board. Check that first. If it is good see if the transformer is putting out any voltage. Two easy fixes that can be done in house...
Jan 01, 2010 | Cerwin Vega LW12 Subwoofer
Nov 01, 2009 | Cerwin Vega LW12 Subwoofer
Cutting on and off
Same thing is happening to my Cerwin Vega 18" sub. Can't find solution at all. Guess I will have to buy a new sub.
Jun 19, 2008 | Cerwin Vega LW12 Subwoofer
Sub woofer cuts on and off.
I am an Electronics Tech and just finished repairing a LW12 for a customer. It also has the HUM. IF I place a finger on the RCA input and another finger on the heatsink..(black metal plate at the back) then the hum goes away. I did notice that Cerwin V maunfactured this older LW12 unit with a 2 prong cord. I personally own a newer CV 10" sub, 3-prong and has never had a problem with it and it has awesome Bass. So for my customer...I am thinking I will add a 3-prong cord. and see what happens.....
May 20, 2008 | Cerwin Vega LW12 Subwoofer
Cerwin Vega LW12 Subwoofer Logo
57 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Joe Lamb
Joe Lamb
Vito Vacirca Jr.
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
