Question about Amana ARS9266BS Side by Side Refrigerator
Freezer cool, but Frig section is not cool
The freezer section iw working fine. However, the frig section is not working. I have set the dial to the coldest setting and this make no difference. The fan is running in the freezer section, but not in he frig section. Is there a fan for each section in the Amana? What do ou think is causing this problem?
  • 3 more comments
  • Jim Ervin Aug 21, 2006
    It appears to get the evaporator cover off the ice maker motor assemble needs to be removed. Is this correct? I assume the cover you refer to is the cover in the back of the freezer section??
  • Jim Ervin Aug 23, 2006
    Yes, I have a defost issue...this is for sure! Now I need to figure-out which part is the issue. I guess I will start with the thermostat. I can't seem to find your part number. The part number I see is as follows (of course this number is for this vendor);
    http://www.partselect.com/xq/aspx/Invent...
  • Jim Ervin Aug 25, 2006
    I see why you say to splice the wire. What a poor design for changing the part! Anyway, the part "looks" normal. It does NOT seem to be "popped-out". From looking at the design it appears this part is a simple switch which completes the circuit to the heater element. The part is a bit costly. Does the part simply switch when (to a short circuit) it gets cold? I guess I can check it with VOM?
  • Jim Ervin Jan 27, 2008
    I forgot to say thanks!!
  • Anonymous Mar 16, 2014
    frig fine freezer only cool
    President:
  • 878 Answers
Volman, take a look in the freezer section and see if you have a heavy build-up of frost on the back panel. You want to take the evap cover off and see if the evaporator is frozen up. If so, your refer did not go into defrost and cannot move the air over to the refer side. If this is the case you will have to defrost that evaporator completely. On these Amanas the culprit is usually the bi-metal which sits on the evaporator. Look at it and see if it's buldged. The part number for the bi-metal is ro131661. If you defrost the evap your refer will start cooling again normally until it freezes over again. This will give you time to replace the bimetal....Catriver...post back.
Posted on Aug 21, 2006
  • Ron Marek
    Ron Marek Aug 21, 2006
    Volman, take a look at the attachment. If yours looks like this, you have a defrost issue. More than likley it's the bi-metal...Catriver...post back.
  • Ron Marek
    Ron Marek Aug 24, 2006
    Thats the part, it just defaulted to a different number. Look at the one that is on the evaporator now, if it is bulged and lifting at the top, this is your problem. An easier way to install the new one is to splice the new one in with wirenuts, seal the wire nuts with a little silicone and your done. Of course you have to defrost the evaporator first. Use a hair dryer. Unplug the unit when making the splices...Catriver..post back.
Paid 2 people to look at it and still wont work
check air flow at frezer. also were is freezer/frig dial set to? place it in the middle. also look for freezing up on back wall and bottom of freezer. DO NOT SET FREEZER/ FRIG DIAL ALL THE WAY TO FREEZER!!!. PLACE HAND WERE YOU CAN FEEL AIR FLOW AND TURN DIAL AND YOULL SEE WHAT I MEAN.
Feb 20, 2014 | Whirlpool Refrigerators
I have a kitchenaid, KSRS25RSMS01, refrigerator and the freezer is fine and the fridge is not cooling. I have checked the evaporator and it has normal frost, and the fan is turning fine, but the air coming...
Your frig has the classic symptoms of a frig with a clogged or blocked vent between the
freezer section and the refrigerated section. This clog can occur due to (a) stuff in the freezer blocking the vent, or (b) ice in the freezer blocking the vent, or (c) both of the above.
The way a refrigerator works is it cools the freezer, and the warmest air in the freezer is vented out
to the refrigerator section. If this vent is blocked (and everything else is working), your refrigerator
just became a eye-level small freezer atop a well-insulated section of dangerously warm food.
May 13, 2011 | Refrigerators
Frig doesn't cool. Freezer works fine. freezer
You have solved your problem :D You need to get that fan blowing. The vast majority of the time that is all you need. Other times, there can be another part controlling the operation of the fan (ADC - Adaptive Defrost Control). Post the model number and I will see if you have one of these ADCs in your appliance :D
May 31, 2010 | Whirlpool Refrigerators
Refrig compartment does not cool on my new Kemore Frig.
Check and make sure the fan in the freezer is running. if not possible bad fan. If fan is running, check to see if you have any ice built up on back freezer wall. Normally frost type ice. If so, you may possibly have a bad defrost bi-metal mounted in the freezer section. Next could be a defrost timer control. Model number usally will help more in getting it right.
Feb 28, 2010 | Kenmore Refrigerators
We have a LG Two Side Fridge.
Look for the air ciculation regulator sliding vent between frig & freezer section open accordingly. Set both sides to #3 on dials if frig not cooling to less than 40 degrees, might need new cold/temp controller behind frig dial
Apr 30, 2009 | LG LRSC21934 Side by Side Refrigerator
Freezer to cold refrigerator not cold enough
sounds like your defrost timer is not working properly . Most fridge/freezers the fridge gets cooled from the cool air from the freezer . But when the defrost timer is not working properly the section between the fridge and freezer freezes up and hence doesnt allow the flow of cool air into the fridge. The defrost timer can be easily replaced.
Jan 28, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Dometic 2652 runs sparatically, then quit
If the burner area is geting hot its has a leak
Dec 11, 2008 | Dometic RGE400 Top Freezer Refrigerator
Refrigerator not getting cold
hello, my refrigerator got the following problem; it works fine at the freezer but there is no cold in the frig, when i unplug it from the wall connection and after few time connect it again, it start working, after few hours, the refrigerator stop, the freezer is fine and very cool,but the frig is not cool and the refrigerator do not start working again, even after the freezer gets warm.Please i hope you can help me with this problem.
Sep 03, 2008 | Refrigerators
Frig won't cool, freezer works fine
Defrost unit completely. You're frosting up. Then, avoid leaving the door open, leaving liquids and food uncovered. Clean condenser coils. If it happens again, you need refrigerant.
Jun 09, 2008 | Refrigerators
Whirpool frig. freezer works frig doesn't
access to the evaporator fan is in the freezer behind the rear wall.
Feb 18, 2008 | Refrigerators
Amana ARS9266BS Side by Side Refrigerator Logo
192 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
