I have a frozen Coby MP826 4G how do i fix it
My mp3 is frozen for a Coby MP601 (2GB) how do i fix it
I wish I knew mine is frozen too. If you figure out a way let me know, hopefully before I smash it
Dec 30, 2010 | Coby MP601 MP3 Player
After downloading a playlist my MP3 has been "stuck" with the screen saying "Update DB" - it's been 30 minutes. I cannot get it to turn off or do anything.
I had this same problem. I hit the reset button with a paperclick, it reset, but became frozen logging on. Coby said I may have loaded a bad MP3 file on it. Hence, I ran three different programs to fix and repair my files, got a new MP837 and the same thing happened. Pieces of &^%$#. Don't bother calling Coby, they don't care and can't help!!!
Dec 29, 2010 | Coby MP837 (8 GB) MP3 Player
My mp3 froze and i pressed that rest button but it still frozen.. So how do i get it to work if i pressed the rest button but it is goin no further than COBY on the screen when i turn it on?
I can help you with you Coby 610 mp3 player.
Replacing the firmware in your mp3 player should have it working like new again.
Please try these steps to fix your Coby MP-610 MP3 Player.
I hope that helps.
May 06, 2010 | Coby MP-610 MP3 Player
Coby 610 MP3
Replacing the firmware in your mp3 player will unfreeze it.
I hope that helps.
Apr 23, 2010 | Coby MP-610 MP3 Player
MP3 player seems to be frozen. How do I reset it?
Replacing the firmware on your Coby MP-610 should fix it. Please try these steps to fix your Coby MP-610 MP3 Player.
Feb 25, 2010 | Coby MP-610 MP3 Player
Mine wont even turn on had it on loaded music and it has frozen and now it wont come on or charge.it is brand new.
Replacing the firmware in your mp3 player should have it working like new again. Please try these steps to fix your Coby MP-610 MP3 Player.
Feb 22, 2010 | Coby MP-610 MP3 Player
I have a frozen Coby MP610 8G how do i fix it?
Here are instructions for a solution to your frozen Coby 610 problem.
Replacing the firmware of your Coby 610 MP3 Player will unfreeze it and help it act normally again. This will also fix the 'File System Error' that has been popping up with some Coby 610 players. You can find it at the cobyusa.com website by choosing 'Mp3 & Portable', then 'Mp3 & Mp4 Players', then your model 'MP610', from the support page. Or, here is the direct link to the file from Coby's servers.
Unpacking the zipfile from the Coby Website will give you a PDF file with instructions, and a program file to run.
Your music will be erased when you run this firmware update. The instructions suggest that even if your mp3 player won't startup properly, if you plug it into your computer you should be able to access it as a removable disk, and copy all your music to a temporary folder on your computer.
Here are the steps:
  1. Plug your MP610 into your computer.
  2. Copy all your music to a temporary folder.
  3. Disconnect your MP610 from your computer.
  4. Disconnect as many USB devices as possible from your computer (to simplify identifying the MP610 at a later step, and avoid damaging other devices by trying to load the MP610 firmware into them by mistake.)
  5. Run the Firmware Update program 'MP610 T LCD Firmware Update for file sys err.exe'
  6. You will see a screen with up to 24 numbered, empty boxes.
  7. Connect the MP610 to your computer. It will show up in one of the boxes.
  8. Once the MP3 player shows up, click on the Firmware Feature icon to start the firmware upgrade.
  9. After the firmware update is complete, you will receive a checkmark in the firmware box.
  10. Disconnect the MP610.
  11. Close the firmware update software.
  12. Turn on the 610 to confirm it starts up and the display reads 'COBY'.
  13. Plug it back into your computer and copy your music back on to it.
You can refer to this Coby 610 solution here.
I hope that helps.
Jan 05, 2010 | Coby MP-610 MP3 Player
Frozen on coby red dot screen
i bout one of those and it wouldnt turn on 4 days after i got it so id take it back or something
Jan 21, 2008 | Coby MP-C7085 MP3 Player
23 people viewed this question
 Grubhead
Grubhead
