Reset drum on oki c610 - Office Equipment & Supplies
SOURCE: How do you reset the OKI c5800 drum?
You don't need to go through all that mess of replacing the fuse. The tone gets everywhere and getting the Drum unit back together with all the gears and shafts lining up is a real pain.
The Drum reset system is very simple. When the printer powers up and runs through its system check, one of the tests energizes the erase LED array built into the Drum unit. The reset fuse routes a small amount of low voltage current off this LED array. There is a contact on the end of the Drum unit that the printer senses. It there is voltage there (ie the fuse is good), the printer resets that Drums counter to 100%. If there is no voltage (ie the fuse is blown), the printer continues on its way.
All you have to do it act like fuse at the instant the printer sends power to the LED array.
There's no soldering, no screws to undo, and no toner all over the place.
The best thing is it takes about 3 minutes start to finish and cost $0.00!
Here's what you need:
• A simple volt/amp meter (an analog one works best, but digital is fine also) • Two pieces of thin wire about 300mm long. I used old telco wire. With insulation, its about 1mm wide. • A pair of scissors to strip the wire ends • X-acto or thin razor knife
1) Strip about 4-5mm off the one end of each wire and 25mm off the other end. Bend the 5mm end at a 90 degree angle right at the base of the stripped part. 2) Pull out the Drum unit (leave the toner cartridge attached to the Drum unit) 3) On the right end of the Drum unit (DU) there are three square brass contacts about 3mm wide. The right end is the end with the blue handle. Looking at the end of the DU, you are interested in the 1st and 2nd contacts from the left (they are the two closest to the screws on a c5800 cartridge) 4) Use the X-acto knife to lift the contact metal and slide the 90 bent end of the wire under the contact. Do this with the other wire on contact #2. 5) Put a little vertical tension on the wires and route them around the blue toner release handle. 6) Gently insert the DU/toner cartridge into the printer. Keep slight tension on the wires until the unit is seated. 7) Wrap the 25mm stripped end of the wires around the volt meter leads. Wrap one so it makes electrical contact, but you could pull it apart instantly at the right time. 8) Set your voltmeter to the lowest amp setting. I put mine on 200micro amps. Also make sure your voltmeter leads are in the correct holes of the voltmeter. You want the amperage or milliAmp holes not the voltage holes. Don't forget to turn the meter on. 9) Get prepared to pull one of the leads off of the one of the thin wires and turn on the printer. Don't be afraid to touch the metal of the wire; the voltage/amperage supplied to the LED array is very low and will not hurt you. A 9 volt flashlight battery is more dangerous. 10) About 10 seconds into the startup routine, you will see you voltmeter display a reading. Instantly pull the leads apart.
Congratulations, you are now officially a 1/16amp fuse.
Your printer will reset the Drum Unit counter and you have another 20K impressions (if the image quality is acceptable to you)
If you have any question, just respond to this post. I'll get the email and answer you.
Good Luck.
Paul
Posted on May 22, 2010
  • 123 Answers
SOURCE: Oki c5500n drum reset
To get the OKI C5500 to keep going (without opening and closing the lid constantly) in spite of toner cartridge & drum life messages:
1) Turn off printer.
2) Hold down "+" and "-" buttons at the same time, and keep them held down while turning printer back on... continue to hold until the word "OKIUSER" appears.
3) Use "-" button to scroll down to "FUSE KEEP MODE".
4) Press "Enter" button, hold for approx. 10 seconds, then release.
5) Press "Enter" button again, followed by rapid release and repress with hold for approx. 10 seconds.
6) Release "Enter" button, then press and let up one more time quickly.
7) You will see "INITIALING" and then "ONLINE" messages.
If you currently have an error message for toner cartridge life, the message will continue to be shown until after you've sent one print job, and then it will usually disappear for awhile. It will stay gone for longer if you have your printer set up so the toner sensor is turned off.
If you currently have a error message for drum life, it will continue to appear, but you will still be able to print.
Beware that you will have to keep a closer eye on print quality (since you are no longer relying on error message to tell you when your toner cartridges are in need of a replacement or refill, or the drum truly needs to be changed or refurbished).
Please note that anytime you turn the printer off, you will have to go through the whole process again when you turn it back on. It doesn't take long though, and will quickly become habit whenever turning on your printer for the day!
Good Luck.
Posted on Apr 08, 2008
  • 628 Answers
SOURCE: OKI c5600 drum reset
It usually resets automatically when you replace the drum/toner units. Are you trying to get it to reset before it's supposed to? I don't know of any way you can do that.
Posted on Apr 20, 2009
SOURCE: oki b4600 drum reset ?
On the printer press the menu button until you reach MAINT.Then press the item + button until you reach DRUM CT RESET. Then press select.YOUR DONE!!!!!!!!
Posted on Jul 09, 2009
  • 73 Answers
SOURCE: How do you rest an OKI c3530 image drum
Turn off the printer
Turn the printer on whilst holding down Menu button. (Display says user maintenance.)
Press the menu button three times. (The display will say drum counter reset.)
Press enter key. The system should go back on line, if not press on-line key.
You can just put a new fuse on the drum.
When you insert the drum the machine resets the counter and then blows the fuse. So if the unit is ok and you just wish to run it through another cycle just change the fuse.
This means you cannot just put a full unit in from another machine as it will not reset the counter until you put a new fuse in it as you found out.
This applies to drums transfer belt etc.
Note with regard to refilling the toner, some printers have 2 sections. 1 where you put the fresh toner and an after collection section in the same unit. You must empty the 2nd section if you refill it more than 2 or 3 times
Posted on Oct 07, 2009
Testimonial: "Great fast response."
Can I reset the belt
How to reset your OKI C3300 C3400 C3600 laser printers ...
? 2:40
https://www.youtube.com/watch?v=czyqKMpy2-E
Oct 6, 2014 - Uploaded by Toner Man
How to reset your OKI C3300 C3400 C3600 laser printers drum unit ... drum message you can install the chip on your drum unit and continue printing. ... Replacing the Transfer Belt on an OkiC3000 Series Printer - Duration: ...
Nov 26, 2015 | OKI C3400n Laser Printer
OKI B410dn drum life
Every Oki B410d printer, Oki B410dn, Oki B430d, Oki B430dn, Oki B440dn, Oki MB460, Oki MB470, Oki MB480 are contacting the module of the Oki 43979002 drum and fuse with chip developed in the module imaging unit through joints being in the bottom part of a printer like in a photo. Eksploatacja Oki B410 pochodne drukarki reset kasowanie bbna
Jan 28, 2014 | Oki Electric Industry C8600n Led Printer
Oki b431 DRUM reset
hello good afternoon, friend u can give a hint of how I resouvo the problem of drum printer oki 431dn + b, pending
Jul 05, 2012 | Oki Electric Industry B431d Printer
I have an OKI C3400 color laser printer. Can the
The counters reset when you install the new drums. Did you purchase Oki drums or were they after market drums..that could be the problem.
Feb 11, 2010 | OKI C3400n Laser Printer
How to reset drum for the oki B410DN
Most of the OKI printers have a fuse installed in the drum to do the reset. If you google the drum reset kit you can find the drum kits and fuses.
Jan 14, 2010 | Office Equipment & Supplies
Resetting image drum after replacing for oki b4600
Oct 03, 2009 | OKI B4600 Printer
How to reset black drum counter OKI C3300 ?
Buy a pack of 10 x .062A (1/16A) pico fuse RS part No 738-3062. Switch off printer. Remove the drum and toner together from the drum slot to be reset. Carefully crimp the legs of the fuse around the contact wires on the right side of the drum slot. Make sure fuse legs are making a good connection to the wires and aren't touching the frame. switch on printer and allow it to detect the absence of the drum. Switch off printer and carefully remove the now blown fuse. Re-install the toner and drum assemnbly. Drum life is now reset. see pic:
Sep 15, 2009 | OKI C3400n Laser Printer
Oki b4600 drum reset ?
Jun 19, 2009 | OKI B4600 Printer
Apr 20, 2009 | OKI C5500n Printer
3,456 people viewed this question
jasbo
jasbo
