Question about NComputing L230 Network Terminal
Can not connect server ncomputing - NComputing L230 Network Terminal
4 Suggested Answers
SOURCE: NComputing L230 won't connect to host
First Please check your Lan IP Address for host pc.
change IP address and subnet mask on L230
disable firewall or any antivirus that is blocking ports.
Then you will get connected.
Posted on Dec 30, 2008
  • 12 Answers
SOURCE: NComputing connected to existing Lan network
If your existing LAN has DHCP assigned IP addresses, you will be good to go. If you have statically assigned IP addresses, you will need to enter them in manually into the device. Their website has a very good instructional video on the procedures to hook up the devices. It will work with standard cat5,cat5E, or cat6 wiring.
Posted on Apr 29, 2010
Testimonial: "Good and quick response."
  • 86 Answers
SOURCE: ncomputing cannot connect to the
Please specify which Server 2K8 version you're using. If it's W2K8r1, and you had installed SP1 as of this posting date, their software didn't support SP1. They recently updated vSpace to support that so please either remove SP1 and retest, or update your vSpace software to the current version and you should be all set. Additionally, if you're server/host is a domain member, make sure it's a domain member when you install vSapce as the installation will manage the firewall port settings for you and many times those firewall port settings change when a system as added to the domain membership.
Posted on Aug 15, 2011
My ncomputing device gives a message that"Can't establish connection to server.Connection ended unexpectedly"
reset the ip , clear dns cache and check it.
if u use dhcp server, the reset ip using
netsh interface reset "c:resetlog.txt"
in cmd prompt..
Apr 28, 2015 | NComputing Ethernet Virtual Desktop (L300)
WHAT IS THE DIFFERENCE BETWEEN LAN(WORKGROUP) AND NCOMPUTING. ADVANTAGES AND DISADVANTAGES.
Not sure what you mean by LAN workgroup. If you're referring to traditional Local Area Networked PCs and sharing files on a server, the NComputing solution is very different. Imagine taking a standard LAN with 20 PCs, each costing at least $500 (usually much more), and having them access a network. That cost would run you $500 * 20 or $10,000. That's just for the hardware, not any of the soft dollar costs. Additionally each PC uses a minimum of 100 Watts of Power, more common these days is 250 Watts.
Now take the NComputing solution. Start by replacing ALL 20 PCs with a $150 L230 or a $200 L300 device, which only consumes 5 Watts of power. Purchase one server, say $2,000. Load up NComputing's vSpace on the server and connect all of the L devices through the network. Every user still gets their own desktop, access to the network and other peripherals. And the I.T. department now has ONE Desktop OS touch points, not 20 as they did before. Thus the NComputing solution can reduce support costs, consume less CapEx and OpEx budget while delivering desktop sessions to each user. In this example the cost would be $2,000 + (20 * $150) = $5,000.
Aug 13, 2011 | NComputing L230 Network Terminal
Cannot connect server ...... client PC diplay this message
Can you PING the L230 device from the server? In other words, are you confident there is a clear IP path from server to device? Also, if you're running on XP, turn off the XP firewall as a test. If that works and you still want to run with the firewall on, then you'll need to specify specific ports to be opened up on your firewall or your domain's firewall policy. Those ports, as listed from NComputing's website are:
Port Exceptions
  • For L-series device connection
    • TCP: 27605, 27615, 3581, 3597, 3645, 3646
    • UDP: 1027, 1283, 3581
  • For vSpace registration
    • TCP Port 3630
    • Point to:
      • register.ncomputing.com
      • or 85.214.107.229
  • For vSpace Update
    • TCP Ports 20 & 21
    • Point to:
      • 70.182.176.102
      • or 81.169.173.128
      • or 81.169.173.128
Jun 12, 2011 | NComputing L230 Network Terminal
First l230 connect to vspace ok,then i installed safe360 , then l230 report "terminal server - yet not ready. please, retry ..."
What is Safe360, an AntiVirus or Firewall software? If so, the program may have inadvertently blocked port access to the kernel which vSpace needs access to for user sessions. Below are the port exceptions for firewall configurations and file exceptions for Antivirus configurations. Current as of this post.
  • Port Exceptions
      • TCP Port 3630
      • Point to:
        • or 85.214.107.229
    • For vSpace Update
      • TCP Ports 20 & 21
      • Point to:
        • 70.182.176.102
        • or 81.169.173.128
        • or 81.169.173.128
  • File Access Exceptions
    • For vSpace functionality
      • C:\Windows\system32\KMServc.exe
      • C:\Program Files\Common Files\NComputer\Bootsrv.exe
    • For vSpace tray icon
      • C:\Program Files\NComputing vSpace\KmMsg.exe
    • For vSpace Registration
      • C:\Program Files\NComputing vSpace\KmRegWiz.exe
    • For vSpace Update
      • C:\Program Files\NComputing vSpace\KmUpdate.exe
May 01, 2011 | NComputing L230 Network Terminal
Cannot get license, because server send error code:47-ncomputing
Cannot get license, because server send error...47
what is solustion this prbloems
Jan 31, 2011 | NComputing X550 PCI CARD W/ VSPACE F/LG...
Cannot get license, because server returns error code:-47 NComputing Error
Nov 18, 2010 | NComputing X550 PCI CARD W/ VSPACE F/LG...
I have config the ncomputing dell powerdege T110 systems. i have in installation and configuration win2003server sp2 when i configuration on dell T110 systems server my ncomputeing dives not connecting to...
Hi Jerod - we'd like to get some more info from you on your specific configuration to narrow this down. But, it's likely an issue specific to the T110 (quick way to isolate is to run 2003 Server in a VM on the same machine to see if you still have the issue). Please contact us at http://www.ncomputing.com/techsupport (online or phone support) and we can help you with this.
NComputing Tech Support
Nov 11, 2010 | NComputing L230 Network Terminal
turn on ncomputing, hit f10 keyboard, click setup, and entry ip address server. try....
Aug 20, 2010 | NComputing L230 Network Terminal
Aug 13, 2008 | NComputing L230 Network Terminal
NComputing L230 Network Terminal Logo
46 people viewed this question
Top NComputing Computers & Internet Experts
Tom Chichester
Dan Shibata
Dan Shibata
Are you a NComputing Computer and Internet Expert? Answer questions, earn points and help others
