ALL LIGHTS ARE FLASHING WEN I START WASH CYCLE
  • lv1298 May 01, 2009
    hi my ariston margarita 2000 dial keeps turning and lights flash 11 times when i try to start it?any ideas? please help ive a mountain of washing to do!
    Brigadier General:
  • 6,966 Answers
Initially, pls try a reset, that is unplug from the mains. Should problem persist, pls post back brand and model. This indicator often signifies faulty controller board or protection circuitry has kicked in. Knowing the brand & model would narrow down interpretation and symptoms.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 26, 2008
    President:
  • 1,952 Answers
Have u checked all the wiring and components in ur front control panel?>
  • mohammed marika thambi
    mohammed marika thambi Oct 26, 2008
    Pull out the wash machine. Check it's electric cable is sound and
    undamaged (examine to see if the washing machine has been standing on
    it or chaffing it) then check the connection to the wall. It sounds
    like intermittent power. If the cable or wiring looks faulty get
    someone who is competent to fix it.
    mohammed marika thambi Nov 02, 2008
    disconect the power after 5 min now connect the power operat the funtion
Electrolux dishwasher not completing wash cycle and all lights flashing on door control panel and the 'wash pump' error light behind the lower kick space panel was flashing.
Good Morning friend, thanks for your post!
After researching the issue you are having with your Electrolux dishwasher it is possible that resetting your appliance may help. I would disconnect power from your dishwasher by unplugging it or flipping the household breaker for roughly ten minutes. If this does not resolve your issue I would recommend seeking assistance from a professional to properly diagnose and repair your dishwasher. -T
Jan 23, 2014 | Electrolux Dishwashers
Kenmore Ultra Wash 665 dishwasher: start button not lighing
It sounds like you have a bad control console, and the problem is that your START button (the most critical one!) is bad. You can't replace just that button or key; you have to replace the entire control console.
Jul 02, 2012 | Kenmore Dishwashers
The normal and economy lights are blinking and cannot get to wash through a full cycle. water is in the bottom of the washer
You will have to check if the dishwasher is stuck in the drain cycle or wash cycle.
The normal and economy lights flashing means there is flooding in the unit.
Reset the unit by pressing START button for 4 secs. If the flashing does not stop then you have to call the technician. There may be a leakage which is causing the flood switch to activate.
May 21, 2011 | Viking 24 in. Professional Series VUD040...
Wash cycle does not start. I push the normal wash (or any other cycle) button and a tiny amount of water flows. If I leave it alone, eventually, several lights start flashing. I have tried pressing the...
Either the hose is clogged at the entry point to the dishwasher or the solenoid vlave is bad...
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
No Water entering Dishwasher
heatman101
Dec 21, 2010 | Dishwashers
Want to disable the alarm
To Set the Cycle Completion Signal Tone Level
• With the "CLEAN" and "SANITIZED" and "RINSE AGENT" Indicator
Lights flashing.
• Press the "Tone Level.
• As you press the "Indicator Lights illuminating and the Cycle Completion Signal
Tone level changing.
o If none of the Wash Cycle Indicator Lights are illuminated,
there will be no tone. The Cycle Completion Signal is turned
off.
o If one of the Wash Cycle Indicator Lights are illuminated,
there will be a low Cycle Completion Signal Tone Level.
o If two of the Wash Cycle Indicator Lights are illuminated,
there will be a medium Cycle Completion Signal Tone Level.
o If three of the Wash Cycle Indicator Lights are illuminated, you
will be at the maximum Cycle Completion Signal Tone Level.
• Press "START" to save your settings.
Dec 16, 2010 | Bosch SHX3AM05SS Stainless Steel 24 in....
Starts bleeping 10mins into cycle
http://www.manualnguide.com/dl/12334/ Check on the troubleshooting page as to what certain flashing sequences mean and that may help
Jan 08, 2009 | Baumatic 23 in. BDW5 Built-in Dishwasher
Flashing lights
I've also been having problems with my Whirlpool. Try to turn off the power (unplug, flip breaker whatever) let the machine "re-boot". Then start the cycle again.
Good Luck!
Oct 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Aeg 76669 oko lavamat machine not starting all six lights [pre wash, main wash, rinse, rinse , spin, and end] flashing machine three years old just successfully completed wash cycle, loaded up for next...
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Jan 10, 2008 | AEG Washing Machines
Washing Machines Logo
242 people viewed this question
Top Washing Machines Experts
