Question about Saeco Royal Professional Espresso Machine
Group bloque Hello, our machine is indicating the following message : Group bloque
WaltK
SOURCE: Saeco Vienna gear jammed
This has happened to me. If the problem is the brew group gear is in the wrong position, you can manipulate the brew group until it matches up with the drive gear in the machine. You'll know it matches if you can insert the brew group back in the machine full until it clicks.
Posted on Dec 08, 2007
JohnnyBeans
  • 223 Answers
SOURCE: removing the brew group
Directions on how to remove a jammed brew group: http://cerinicoffee.com/Saeco_technical_documents.asp
Shop for Saeco parts and cleaning supplies: www.cerinicoffee.com
Posted on Jun 02, 2008
  • 40 Answers
SOURCE: Saeco Vienna Digital Expresso Maker - brew group will not line up to fit back into espresso machine
Could be a number of reasons. If you "hear" the brew group moving in one direction, stop and then move again, then the microswitches are o.k. If the sound of the movement is low and/or slow ( slower that normal), the CPU/power board may be bad and needs to be replace. If the movement is as before (same sound and movement) but not lining up, perhaps the brew drive motor is bad.
To remedy this situation, an authorized SAECO Service Center would have to open your machine and replace damaged components. Contact Saeco USA Inc. to located a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Posted on Jun 19, 2008
mirran
  • 515 Answers
SOURCE: Brew Group will not reset
Hi Neil,
Try to put the dregsbox and driptray on place, close the door and turn on the machine.
When the machine stop again, open the door and put the brewing unit on place.
Best regards
/Mirran
Posted on Sep 25, 2008
  • 5 Answers
SOURCE: after a cleaning of the group, we're not able to put it back
First step: You need to make the machine think that the group is in place.
Solution: This can be done by locating the three microswitches that need to be set. Turn machine on/Open the door/insert wastetray&dredgebox (switch One)/with plastic stir stix(noconductive material) active brewer microswitch located in the centre of the back wall/with plastic stir stix(noconductive material) active door microswitch located top right side behind door. All 3 switches need to be actived simutainiously with the power one. When installing the brewer, be sure that the microswitch activator slide on the back of the brew group itself is in the up position.
Note: if you do not know what I was talking about(microswitches) best not to attempt
Posted on Jun 25, 2009
How do I join google+ private group I am invited to join?
Find and join a group Groups usually have a name that indicates the subject of the group, such as "cooking" or "music." To find and join a group:
  1. From the Home screen, type a subject, such as "cooking" in the search field.
  2. Press the Search button. A list of groups and messages is displayed.
  3. Click on a group name, such as "Live music." The Topics screen appears displaying a series of topics.
  4. Click on the 'Join group' button. The Join group dialog box appears.
  5. Fill in the options on the Join Group dialog box.
  6. Click the Join this group button. You are now a member of the group.
An open group is configured to grant you immediate membership. A restricted group requires approval from an administrator before you are added to a group. A private group requires you to click on a link to request membership from the owner. Note: Google cannot intervene in the approval process for private groups. Contact the group owner if you need your approval expedited.
http://www.bing.com/search?q=How+do+I+join+google%2B+private+group+I+am+invited+to+join&form=PRHPR1&src=IE11TR&pc=EUPP_HRTS
Jun 19, 2016 | Google Computers & Internet
How do I unfollow an issue on Facebook
Could you be more clear on what you mean by issue? On FB, you can unlike something to stop following it, or if it is a group message, you can go to that message and click, "Leave Conversation." If it is a group, you can click on "Leave Group" in the group. Without a bit more clarification, I can't really help you any further.
Jan 23, 2015 | Apple iPad 64 GB WiFi
Gmail email login
The error may have come from one of your recipients. Your group email may have BEEN sent to everyone else in the group, just not that one recipient, who hasn't retrieved their email since October last year.
Has anyone in the group died? Moved to a different email provider?
Jul 31, 2014 | Google Gmail
Error message: 'brewunit is blocked' and i cannot get the brewunit out of the machine to look at it. it is stuck pretty hard. dont want to break it...any suggestions?
Hi
Your showing a Syncrony but this is for a Syncrony Compact. They are different.
Open the door. Remove the drip tray, dredge drawer. On the left side and towards the back of the brew group, there is a single screw in the brew group. If you can't get the dredge drawer out, just move it as far to the left as you can to get to the screw. Remove the screw. Grab the handle, squeeze and pull carefully, but firmly fast. Everything will come out (drip tray, dredge drawer, brew group and there might be water in the drip tray). The brew group should come out. There is a piece that remains in the machine. Slide the piece down and to the right and it will come off. Insert the piece into the hole on the backside of the brew group with the clip up. Tighten the screw and move brew group back into position.
To return the brew group to the centered position, you first need to drop the funnel. To do this, look on the opposite side of the brew group from the handle. At the top you will see an object that looks like a sharks fin. If you follow this piece down you will see 2 horizontal bars on the brew group body. Push your finger between these 2 bars and the funnel will drop. Now you can push the puck slide on the left side down and then to the center of the brew group. If you look down through the funnel you should see a piston. This should be centered in the funnel. If not just push the slide to the right until it does. Push the press button and you are now ready to reinsert the brew group into the machine. First you must insert the dredge drawer back into the machine. Close the door and turn on the machine without having the brew group in. You will hear the motor turn on and when it stops completely, pull out the dredge drawer, drip tray, then open the door and insert the brew group. Slide the drip tray,dredge drawer back in, close the door and test.
May 14, 2011 | Gaggia Syncrony Compact Digital Espresso...
Hello i can nbot assign rigntones mto my contacts on my nokia e72
Hello Ban,
Only Group can use different ringtones, but not each contact.
You have to create Group then add contacts to the group.
Select Menu---> Contacts.
To create a contact group, scroll to each contact you want to add to the group, and select
Options > Mark/Unmark > Mark.
Select Options > Group > Add to group > Create new group, and enter a name for the group.
Add contacts to the group from option in contacts.
In the Group Option, you'll have menu to assign ringtones to the saved contacts in group.
Mar 19, 2011 | Nokia E72 Smartphone
How do I send one fax to multiple receipents?
you need to set up a group to send to. So if the group is always changing this may not help much.
Groups allow you to send the same fax message to multiple numbers (broadcasting). You can store the Groups on your One-Touch keys or SpeedDial locations and then broadcast by pressing a One-Touch key and Fax Start or by pressing Search/Speed Dial, the three digit location and FaxStart. First, you will need to store each fax number you wish to includein your Group as either a One-Touch or Speed Dial number. Then, you can combine these numbers into a group. Finally, you can have up to six Groups, or you can assign up to 131 numbers to one large Group. Each Group uses one One-Touch key or Speed Dial location. To set up a Group, please follow these steps:
1. Press Menu, 2 (Fax), 3 (Set Auto Dial), 3 (Setup Groups).
2. Press the One-Touch key on which you wish to store the Group or pressSearch/Speed Dial followed by the three-digit Speed Dial location where you wish to store the Group. The LCD will read SETUP GROUP:G0 ENTER & SET.
(from the Brother manual)
Nov 18, 2010 | Brother IntelliFax-4100e Fax
How do I do a group fax with a M20i?
NOTE: The following solution applies only when the WorkCentre has the fax feature.
Speed Dial numbers must be set up before creating a Group Dial. If Speed Dial numbers have not been set up, See the Related Items below for additional information.
  1. Press the [Machine Status] button on the Control Panel. 'Machine Setup' will be displayed on the Display Screen.
  2. Press the [Up] or [Down] arrow button until 'Fax Setup' is selected, and then press the [Enter] button.
  3. Press the [Left] or [Right] arrow button until 'Group Dials' is displayed, and then press the [Enter] button.
  4. Press the [Left] or [Right] arrow button until 'New' is displayed, and then press the [Enter] button.
  5. Enter a Group Dial number between 1 and 200 using the numeric keypad, and then press the [Enter] button.
    NOTE: If a 'Location No. is Registered' message is displayed, the number has already been stored as a Group Dial. Enter a number that has not been stored, and then press the [Enter] button.
  6. Enter a Speed Dial number to be added to the Group Dial using the numeric keypad, and then press the [Enter] button. The name and fax telephone number stored for the specified Speed Dial number will be displayed.
    NOTE: If a 'Not Assigned Enter Again' message is displayed, the number has not been stored as a Speed Dial number. Enter a number that has been stored, and then press the [Enter] button.
  7. Press the [Enter] button. The Speed Dial number will be added to the Group Dial.
  8. Repeat steps 6 and 7 to add additional Speed Dial numbers to the Group Dial.
  9. After all required Speed Dial numbers have been added to the Group Dial, press the [Menu / Exit] button.
  10. If required, enter a name for the Group Dial using the corresponding buttons on the numeric keypad, and then press the [Enter] button. If a name is not required, press the [Enter] button.
  11. Press the [Stop] button to return to the Standby mode.
Feb 17, 2010 | Xerox WorkCentre M20i All-In-One Laser...
My friends always use Group message or (GM) haw they do that?
You need to right click on the Group Name and choose "Broadcast an IM to this group". The send message to group box wll open and you can already type the message you want for the group and click the "send" button.
If you still have no group, you can create one. Just right click inside the main Yahoo! Messenger window and choose "Create New Group". Once your group is created, you can just click-drag your friends' names on that group.
If you need further assistance, just let me know.
Oct 08, 2009 | Yahoo Messenger
Nuova simonelli master
Your proble is that the coffee group is blocked. There many reason why you have this problem, like the group motor is damage ither the motor or a gear but you have to replace the complete unit. Their is also the posibility that something is bloking the group to complete the full motion, or something might have been bend. Their is also the posibility that the group limit switches to give wrong indication so the machine can not get any move responce. Unless you have experiance with this machines you have to ask professional help since you might damage the whole group system even that the cause is might be a very stubit one.
Aug 14, 2008 | Nuova Simonelli Master Espresso Machine
Brew unit blocked
You can remove the brew group by following the "how to remove a jammed brew group?" on this page http://cerinicoffee.com/Saeco_technical_documents.asp
For Cleaning Supplies and Saeco Parts visit:
May 30, 2008 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco Royal Professional Espresso Machine Logo
245 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
