Question about New Home HF-1012 Mechanical Sewing Machine
New home 1012A sewing machine
My sewing seems very very stiff and when I turn the hand wheel when the needle gets to the lowest position it sticks and will not go any further. I was given this machine as a gift some time ago, and have never used it unfortunatly I have lost the manual please please can you help.
4 Suggested Answers
RickE1
  • 202 Answers
SOURCE: sewing machine no movement
I know what the problem is. Its a cracked gear. When you have the top open look at the big fiber gear on top. It is common for these to crack and now it is stuck. Needs a Bernina service guy to replace it. There is one more smaller fiber gear near the handwheel inside that could be cracked also.
Posted on Aug 29, 2009
bargainbox
  • 1388 Answers
SOURCE: old singer sewing machine (306k) motor works,belt
Apply a little singer machine oil to each of the holes along the top and in the working area next to needleplate.........rock handwheel gently and make several full rotations in each direction ......... keep at the rocking and rolling periodically over several hours if necessary....it should come good after a little patience and persistence. Do not apply too much oil, it will only make a mess. NOTE: Belt needs a little give to prevent motor overload, so do not overtighten.
Posted on Sep 10, 2009
SOURCE: I lost the foot pedal and leads of my New Home
sewingpartsonline.com or sewingmachineparts.net
Posted on Dec 08, 2010
Why is the wheel on the right hand side of my machine very stiff when turning
the "hand wheel" on a sewing machine is meant to only advance the mechanism far enough to thread and set the needle , the motor should be used to run the machine else wise , as its turning every thing inside the machine to keep all the functions in "TimE" as models increase in there complexity there hand wheels are harder to move as more stuff needs to be kept in "time" now , also on some models the bobbin winder is directly powered by the hand wheel , if its not in use it should be disengaged completely
Mar 02, 2016 | Sewing Machines
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
Jan 25, 2016 | Janome Memorycraft 6500P Computerized...
The handwheel will turn manually but it will not move using the foot pedal. The sound it makes when I press on the foot pedal *sounds* like I am filling the bobbin.
foot pedal not moving needle - Home Forums - GardenWeb
ths.gardenweb.com > Home Forums > Sewing
Nov 8, 2013 - We have a Brother Limited Edition Project Runway Sewing MachineRefurbished LS2250PRW. I was trying to sew on a button and was turning the hand wheel to do ... front near the needle where you can run the machine with foot pedal ...just what I would experience when my Bernina was running, or not, ...
Sewing Machine Repair ' ThriftyFun
www.thriftyfun.com/tf/Home.../Machines/Sewing_Machines/index.html
The thread is being picked up from underneath, but will not form a stitch at all. ... Butwhen I push my pedal down my needle won't move, the motor runs, but nothing happens. ... I have a Bernina machine which is sewing OK with the normal foot. ....The hand wheel, the wheel at the end that manually turns to make the needle ...
Help me diagnose and fix a problem with my sewing machine - Sewing ...
artisanssquare.com > ... > Sewing Machines
Jan 11, 2016 | Bernina Sewing Machines
Oily cotton when stitching
Oily Cotton:
1. Remove the bobbin case.
2. Wipe out the oil.
3. Bobbin case rides unto an area that looks like a race track. (Called Race). Wipe out oil.
4. After cleaning oil out take a drop and place unto race.
5. Replace bobbin. (Wipe oil if there is any.)
6. Remove oil from the needle arm. (Goes up and down holding unto the needle.)
7. Replace a small amount of oil on the needle arm.
The sewing the machine should sew very well. It may have some resistance when you turn the hand wheel by hand. Likely, this is due to the machine being new and not being broke in. Otherwise, it would need to be lubricated throughout the machine. Give it while!
Mar 23, 2015 | Janome Sewing Machines
Hand wheel & needle very stiff
Hai, I think your machine timing is changed. So you can't sewing properly. Please check the timing and put the oil everyday all oil parts properly.
Apr 16, 2014 | Singer 1507
My sewing machine will not pick up the bobbin thread
double check the timing. The hook must pick up the loop in the needle thread as it starts on its up stroke.
Remove bobbin cover, needle plate etc to expose hook. Turn hand wheel slowly towards you until needle reaches its very lowest point
then continue to turn very slowly until needle comes up about 3/16" in this position the tip of the hook should be exactly behind the needle and just above its eye
Feb 28, 2014 | Sewing Machines
Bobben timing
with needle in centre stitch position remove bobbin cover needle plate and bobbin assy .turn hand wheel towards you until needle at lowest position, watch the rotating hook, as you turn hand wheel slowly to raise the needle 3/16" the hook should be exactly behind the needle and be just above the eye
Feb 09, 2014 | Yamata FY811 Mechanical Sewing Machine
I have a Juki HZL-K85. I changed to a heavier thread for outdoor material, the thread bunched up and the machine made a crunch noise. I got the fabric free, but now the bobbin thread is not being picked...
Check the needle to see if it is bent. If not then check the needle to hook timing. Turn the hand wheel until the needle is at it's lowest position. Start to bring the needle upward. As the needle gets to the edge of the hook/bobbin race the point of the hook should pass slightly above and behind the needle. If it isn't the timing is out. I would suggest bringing it to a trusted sewing machine repair person to reset the hook timing and check for any other damage.
Sep 14, 2013 | Janome 1600P-DB Mechanical Sewing Machine
Singer 7442 - Needle hitting bottom
FIRST DETERMIN NEEDLE BAR POSITION TURN STITCH REGULATOR TO LARGEST STITCH, THEN TURN HAND WHEEL TIL' NEEDLE IS ABOUT TO ENTER NEEDLE PLATE.
AT THIS POINT THE FEED DOGS SHOULD BE JUST AT OR JUST UNDER PLATE. IF SO NEEDLE BAR IS, IN CORRECT POSITION,AND TIMING WILL BE SET AT THE HOOK.
TO SET TIME REMOVE NEEDLE PLATE TURN HAND WHEEL SO NEEDLE IS IN LOWEST POSITION. USING A SMALL RULE RAISE NEEDLE BAR 3/32 OF AN INCH ( OR 3 MM FOR A METRIC RULE) .HOOK POINT SHOULD BE IN CENTER OF NEEDLES WIDTH. LOOSEN THE 2 SHAFT SCREWS
SLIGHTLY,TURN HOOK TIL CENTER OF NEEDLE. TIGHTEN SCREWS. IF NEEDLE BAR IS OUT OF TIME. BRING HOOK TO CENTER OF NEEDLE AND LOOSEN SCREW IN LEFT COVER. RAISE OR LOWER NEEDLE BAR TO SET 3/32OF AN INCH. THE 3/32 MUST BE VERY VERY CLOSE.
Nov 26, 2007 | Singer 7442 Mechanical Sewing Machine
Brother 3022 Mechanical Problem
Make sure your needle is in correctly. Check your threading again. If that does not work, remove throat plate, install new needle, turn hand wheel until needle is at its lowest position and observe if the hook is exactly behind the eye of the needle. If that is correct then you do not have threaded correctly. If it is not then the machine needs to be re-timed.
Oct 09, 2007 | White Sewing 2037 Mechanical Sewing...
New Home HF-1012 Mechanical Sewing Machine Logo
145 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
