Question about Sony Cyber-Shot DSC-S40 Digital Camera
Sony cybershot dsc-s40
When turning on the power the camera makes a noise like its trying to start up but is jammed, you see the word Access on the lcd screen but then it says turn the power off and on again. whilst the camera is on you can see previous images if you turn it on to playback.the shutter wont close when the camera is switched off. any ideas and is it costly to fix ?
  • varinder Dec 24, 2007
    when turning on the power the camera makes a noise like its trying to start up but is jammed, you see the word Access on the lcd screen but then it says turn the power off and on again. whilst the camera is on you can see previous images if you turn it on to playback.the shutter wont close when the camera is switched off. any ideas and is it costly to fix
Same thing here Tankengine. My problem started when my camera took a spill of about 4 feet. After that I've been getting the same message you have been. I've sent a message to Sony so hopefully they will have an answer. Something tells me it's going to involve sending the camera away, and spending money on an old camera.
Posted on Nov 09, 2006
The lens is jammed. It is stuck in a position extended about 1/16 inch out. I can not square it with gentle pushing or tapping. How can I open the camera to get better access to the lens to straighten...
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Nov 26, 2010 | Nikon COOLPIX L19 Digital Camera
My cameras lense wont fully extend, it just makes a funny noise. It wont fully retract and go back in the main part like its supposed to either it tries for a minute and gives up, and just turns off with...
Oct 23, 2010 | Olympus FE-5020 Digital Camera
Hello, i have a casio exilim and the lense is jammed! i dont know how it happened because it was fine one minute and the next it was jammed, it lets me view pics and stuff but i cant take any new videos or...
Oct 15, 2010 | Casio Exilim Card EX-S100 Digital Camera
THE SCREEN IS BLURRY AND NONE OF THE BUTTONS WORK.
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Jul 22, 2010 | Polaroid t1031 Digital Camera
My screen is blurry and I can't take a pic the screen looks grey
Jul 03, 2010 | Kodak EASYSHARE M340 Digital Camera
My Samsung SL202 isnt working the back screen stays black when i try to turn it on and it makes a sizzling noise then then lens comes out but dosent pop back in
Jul 03, 2010 | Samsung SL202 Digital Camera
Error C:13:10, displays ''access'', ''turn the power off and on agai
Lens jams can happen without dropping the camera. The lens motor is bad, or a grain of sand has got stuck in one of the lens cogs. Either way will need lens repair/replacement.
Nov 12, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Whirring noise, camera won't turn off, blank screen
The problem isn't fixed but I found out on the Nikon website that it may be due to an electronic component failure. I downloaded a form from Nikon to send it back in to them for free repair. I'll keep you on my list for future problems. Thanks.
Mar 28, 2008 | Nikon Coolpix 4500 Digital Camera
When t
its only lens cover problum this cover is motorised this is reparable
Dec 24, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera Logo
158 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Terry Weaver
Terry Weaver
Are you a Sony Camera Expert? Answer questions, earn points and help others
