Question about Clarke Power Products 2 Clarke Mig Welder Gas Diffuser 130en 180en Tip Holder
I need a power/slector switch for a Einhell SGA 175 Mig Welder
luxur4
  • 92 Answers
SOURCE: mig welder powers up but only clicks when trigger is squeezed
1] Remove the power cable from the power. (socket on the wall) remove the top cover there should be a fuse located on the wiring panel.
2] perform all your house keping- like, all plugs and socket are tight, the correct contact tip with the the right wire size, roller/s are also the correct ones for the wire size and are turning if they are turning but not feeding the wire, then, the rollers need to be tightend , get back to us.
Posted on Jan 23, 2009
  • 105 Answers
SOURCE: Is there a source for Clarke welder parts? Got
machine mart uk
Posted on Dec 15, 2009
luxur4
  • 92 Answers
SOURCE: Have Clarke MIG 130 EN. replace Power Cable Assembly 23000054
Your local welding supplier would be you first choice. you will be able to fit an alternative power cable, dosn't have to be Carke,
Posted on Jan 26, 2010
  • 258 Answers
SOURCE: clarke pro 90 gas mig welder wont penetrate
hi my names josh ive got the same welder i would say check the gas valve if your running gas that would be the reason for no heat sometimes you just have to remove and reconnect the valve from the tank
Posted on Apr 19, 2010
  • 23 Answers
SOURCE: Do you have any info
goggle it
Posted on Dec 17, 2010
I need a heat selector switch for a silver beauty 90100 mig welder or something that will work
Clarke Mig Welder 6 Position Heat Selector Switch Parts
I found a heat selector switch, but I don't know if that's what you need. You can do web search for ' heat selector switches' or' mig welder switches'.....
May 23, 2014 | Garden
My friends millermatic 175 mig welder burns way too hot and burns through almost everything. Whether the voltage control is turned all the way down or all the way up, there does not appear to be any...
The potentiometer can be checked with a multimeter ohms range. Analogue is best.
I would be surprised if the potentiometer is faulty but you might be lucky. MIG welders rarely use a pot to control the voltage - most often the voltage or power is adjusted in steps by one or more switches and it is the wire speed and current that uses a potentiometer.
Sep 08, 2017 | Miller Welding Tools
Miller mig welder #175 stopped welding, fan comes on and wire does feed, just no weld.
This usually happens when the main Power semiconductors fail. You need to check out the two main places, the Power Supply, make sure ALL voltages are correct, and the main Output semiconductors, check these to make sure they are Not open circuit or short circuit.
http://www.millerwelds.com/service/ownersmanuals.php
Above is your support link.
You need to contact Miller and obtain a service manual, before attempting to service this unit.
Aug 14, 2010 | Miller Welding Tools
Having problems with wire feed of Mig 175 any tips to correct issue please?
Need more info! Slipping not enough tension!
Balling up wire in welder: Pinched liner in gun!
Jerking: Tension of spool too loose!
Here are a couple things to check for!
May 16, 2010 | Welding Tools
Century mig welder. The wire speed is spinning at max speed as soon as the machine is turned ON. Will only stop when machine is OFF.
My Century 225 mig has lost its power ...with adjustments to max it leaves a high weld deposit and low penertration.
What is the fix ?
Aug 14, 2009 | Lincoln Electric LE 83180 Century...
Lincoln MIG welder: Gas not shutting off.
gas regulator needs checking or replacing!
Or you can use GASLESS WIRE!
Jul 24, 2009 | Welding Tools
What is a Solar 2-175 mig welder worth?
A consumer grade machine. Nowhere near a miller or lincoln How much are you wanting to get?
May 19, 2009 | Welding Tools
Clarke Power Products 2 Clarke Mig Welder Gas Diffuser 130en 180en Tip Holder Logo
162 people viewed this question
Top Clarke Power Products Welding Tools Experts
Wade Mobley
Wade Mobley
Bill Boyd
Are you a Clarke Power Products Welding Tool Expert? Answer questions, earn points and help others
