Question about HP Compaq Business nx7010 Notebook
Battery problem HP compaq nx7010
Hi all,
Maybe someone can help me out with my battery!
It takes longer than usual to charge and then it runs out in about half an hour. The power meter says that 2h left but in half an hour is gone.
I read your other posts but couldn't find a solution.
Any idea please?
Michael
Could be memory effect. Have you tried letting the battery run out completely, and then recharging?
You need to set the power option in control panel not to turn off for low power, and just let the battery run out.
Or it could be a faulty battery. Have you tried another battery?
Posted on Oct 28, 2008
Hi, I have an HP Compaq Laptop 6710B which
Usually this is cause by a defective battery. Replacing the battery should fix if.
Thanks Tonm
Aug 07, 2011 | HP Compaq 6710b Notebook
Hp compaq nx7010 is not charging the battery. I tried the battery and the adapter in another nx7010, all works. It's a motherboard problem about charging. Is there any solution without fixing or changing...
if it is working fine with the adapter (charger ) on ..it means that it is just a matter of connections at the battery level ...or a matter of the driver that master the charging..Verify it in the device manager to see if you have any drivers in yellow with an ask sign on..in thi scase go to the support site and download all drivers and reintall them (in case you do not know which one ) or just the missing one ...
In case that no drivers appears t be missing ..check the contacts from the battery ( the ones on th emotherboard ...cause the battery appears to work in another device...)
Dec 21, 2010 | HP Compaq Business nx7010 Notebook
Battery is not charging hp nx 7010
Batteries last only 1 or 2 years in my experience, unless higher capacity batteries are used. If your laptop doesn't charge, it's likely a new battery is required to enable good charging of the battery. Try amazon.com or ebay.com for your make and model.
Dec 18, 2010 | HP Compaq nx7010 Notebook
Battery problem with HP Compaq Presario V2000 laptop
When batteries fail, they usually lose the cells inside them, which means that the cell is no longer able to function as a holding cell for power and therefore cannot do its job anymore, when a battery fails to hold and refuses charging it is bad and needs to be recycled. The flashing is telling you to purchase a new battery. The larger the number of cells in the battery, the longer and better it will perfrom,,RE: 6 cell, 9 cell, 12 cell.
Jan 13, 2010 | HP Compaq Presario V2000 Notebook
Laptop HP COMPAQ NX7010. Dead, with lights on..
Sometimes removing the cmos battery for 5 minutes isnt enough, with all the parts assembled in the original configuration, remove the running battery, the cmos battery and any external power supply. Let it sit for about a day. Let my know if the problem is unresolved after that.
Nov 09, 2009 | HP Compaq nx7010 Notebook
Have compaq nx7010 can power up but screen blank and hard disc light (between power and mains power symbols) not staying on. have tried removing battery and refitting which has worked once before but now...
The HDD light is not meant to be on solid, it comes on only when the hard drive is actually working. The situation you're describing is usually just a lockup in standby.
Although you're onthe right track with the battery, To reset the power, unplug the AC cord, remove the battery and then hold the power button for 30 seconds. Now put the battery back plug it in and turn it on. It may give you an error about not being able to resume, this is normal.
If this doesn't work get back to us with more info: does it beep when it turns on, how many times, longs/shorts.
Did you try plugging and external monitor into the laptop and rotating displays to see if your backlight is out?
Ok, giver a try and let us know.
Chris
May 24, 2009 | HP Compaq nx7010 Notebook
How to switch to battery power source on a compaq nx7010
If you have the AC adapter plugged into the portable, it will run on AC power while recharging the battery. Once you remove the AC adapter, it will go onto battery power.
If once you remove the AC adapter the computer dies, with a battery installed, then your battery is weak/dead or there is a connection problem, and the battery is not charging. But, I doubt this is the case, since it thinks the battery is at 80%. The system does not know if the battery is holding a charge.
You power settings are only timers, which reduce power consumption when idle.
Dec 01, 2008 | HP Compaq Business nx7010 Notebook
Laptop won't run on battery power
Have you tried a KNOWN good battery? If your laptop does this with a battery that's known to be good, then the charging circuity is at fault. Also, try this: while the AC and battery is plugged in, unplug the battery. If nothing changes, then the laptop is the problem, if the status changes, then the problem MIGHT be the battery(ies).
Hope this helps, and please rate my advice.
Thank you, and good luck!!
Feb 05, 2008 | HP Compaq nx7010 Notebook
Won't rub on battery power
replace a charger,or change a capacitors on them,you have a low voltage on charger
Feb 04, 2008 | HP Compaq nx7010 Notebook
HP Compaq Business nx7010 Notebook Logo
90 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
