Question about Boating
Speedometer not working on Yamaha AR210 Jet Boat
Took the boat out on a very windy day and tied to shore line overnight. The boat rocked against shoreline all night long. When we got back on boat the next morning the speedometer did not work. Why?
captainjeffq
  • 52 Answers
SOURCE: need Wiring Schematic/Diagram for 89 Astro GT16 boat
In all honesty, its probably impossible to get the original wiring diagram. Also, I would be willing to bet that there has been alot of re-wiring and changes made to the wiring and electrical system of the boat. If you describe exactly what your trying to do, install fix or re-wire I may be able to better assist
Posted on Apr 14, 2009
ronaldo_ross
  • 1056 Answers
SOURCE: my boat refrig works on shore power but won't
The inverter that converts the 12 volts to 120VAC is not working. An eletronic repair shop can fix this. refrigertor technician will replace the whole inverter, Or you can order the inverter unit and replace it yourself if you are somewhat a handy kind of person. It is not really that hard to replace them. Make sure first that the inverter is not putting out 120VAC when you connect 12V to it, before you take it to a shop.
Posted on Jun 28, 2009
  • 86 Answers
SOURCE: I need year of starcraft boat
If you find the hull identification number which is always stamped on the right side of the transom then the last two numbers indicate a year. Ex. BUJ5C45208 Would be a 2008.
Posted on Aug 09, 2009
SOURCE: Yamaha 115hp 2 stroke Outboard Boat Motor. Went
my 115 does the same thing, i just bump the choke when it starts bogging down and it takes off and running at hi speed.
Posted on Nov 17, 2009
  • 97 Answers
SOURCE: have everstart 24dc-6 boat battery is it 6 or 12 volt
From your discription it's a 6 volt
Posted on Dec 31, 2009
I have a 2012 mercury 6hp four stroke that will not idle without the choke on
Hi, Lee and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting ***** set too low.
8. Air/fuel mixture ***** set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
Boat Motor Won Stay Running Watch This
Mercury Outboard Idle Adjustment
2010 6 hp Yamaha 4 stroke wont run with choke in Page 1 iboats Boating...
8m0055686r. google this for a free manual
Won Idle Here what did to fix it Yamaha Outboard Parts Forum
Apr 13, 2016 | Motorcycles
7000 double horse ep racing boat broke.
it is the force you aply to some thing and all that
Mar 03, 2014 | RC Gigantic Cyphelurus EP Racing Boat
My new Coleman SCANOE sank.
Look up the "Bird Of Prey Canoe Stabilizer" on YouTube. For less than $80 a guy made stabilizers for this model of canoe. I'm looking into buying one and found your post. I have read in another area that people were having issues with it taking on water in the back while using a motor. We mostlly row, so at most I was considering a small trolling motor.
Jan 15, 2013 | Coleman Scanoe Canoe
How can I maintain my pedal boat?
The best way to keep your pedal boat is to move your boat into a garage after you use it. You can also keep it on the shore but make sure it is covered. Remember that if you have a plastic boat, water can get in between the hull and the deck. You should make sure that you get the water out before it creates mold.
Jan 14, 2013 | Boating
I took out my fuel pump and my 1998 r1 runs great...for now can it just keep running good ????if you have advice on this let me know .with a hey kato ...........
Hi, Dj_kato whatever floats your boat ties your sneakers or puts a smile on your face go for it otherwise for this situation I would call my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
1998 1999 Yamaha YZF R1 Service Manual R1 Moto Data Project
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
Yamaha R1 Performance upgrade 1
Yamaha YZF R1 02 03
Jan 11, 2012 | 1998 Yamaha YZF-R1
Yamaha Exciter jetboat: eng stops when warm, not overheating
I have a 1998 Yamaha Exciter jet boat as well and am having a similiar problem. I just took it in today and the mechanic believes that it may be the oil pump failing which causes the pistons to stick and not lube the engine properly, thus causing overheating and eventuallly stall. The one motor sounds beautiful and the other sounds unhealthy. He checked compression and it seemed fine and it has new plugs. Maybe this is the same problem you are having...Hope this helps...
Mar 24, 2010 | Yamaha 12V Air Pump
Yamaha ar 230 engine middle lightcome on in on both tach and shut
With the newer yamaha jet boats your route of easiest resistance is gonna be to take the boat to a Yam dealer so they can put a diagnostic machine on it. Alot of sensor problems can be solved much easier and cheaper after running the diagnostic and pinpointing exactly what the issue is. The lights on the dash are for high temp and low oil. If you checked the water temp and it seemed ok, check your oil levels.
Apr 12, 2009 | Sport & Outdoor - Others
I have a 1987 mercury 9.9 outboard drive problems
the inside of the prop has a rubber between the prop itself and the inside splines to act as a shock absorber,say if you were to hit a rock. that rubber had spun out and the splines are turning inside the prop. the prop is screwed. seen it 100 times before.
Aug 25, 2008 | Sport & Outdoor - Others
Boat stereo/speakers
Wonder if the return line from both speakers was wired to a common earth, and you've lost that connection? If that happened, you'd end up with the two speakers in series instead of in parallel, and just playing the difference between left and right channels (so very much quieter). Check also the stereo doesn't have a separate fuse (possibly internal) for the power amp stage. A.
Mar 30, 2007 | iLO XM-MP3-CD Car Stereo
Boating Logo
66 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
