Question about Ovens
Main oven will not heat up
Electrolux eou6330x . fuse tripped off . no bottom oven will not heat up
  • Ovens Master
  • 19,396 Answers
Check the lower heating element, you should test the element for continuity, and inspect element wirings for a short.
If it is only the lower part that is not heating, and the circuit breaker tripped off, then it is usually a faulty element.
You can get parts from the following internetional part sellers:
Repairclinic
PArtselect.
Contact them if the part or the model is not in list.
Posted on Oct 26, 2008
Oven not producing any heat
just the oven? then more than likely the element. if the stove eyes are not working as well, then your looking more at a sensor, thermostat, fuse, breaker, etc. almost always an element though
Mar 20, 2012 | Electrolux Ovens
Electrolux EOB 6632 oven trips main house circuit breaker if used above 180c. Installation electrician has done whole house test, says everything normal, must just be a particularly sensitive ciecuit...
Hi, welcome to FixYa! my name is Shaun. I hope i can help you out with your question. Your main house breaker is tripping over 180C because of the amount of current your oven is drawing. Keep in mind that an oven is capable of pulling up to 1/4 the amount of amperage of your total house current capacity, up to 50 Amps. This is assuming you have a typical 200 Amp main breaker. Add this in with your heating/air-conditioning, up to 30A, if electric, your water heater, 25 A if electric, and whatever lights and appliances you have plugged in and turned on, you can imagine how quickly those amps add up when your oven is on. Your oven breaker won't trip because you're not exceeding 50A on that circuit, however if your total household load is exceeding 200A, your main will trip. Also, breakers lose efficiency over time. Sometimes they can drop current capacity by as much as 25%. So your best bet is to replace your house main and see if that fixes your problem. Hope this helps out. Have a good day!
May 05, 2011 | Electrolux EOB6632 Electric Single Oven
My electrolux EOD5330 fan oven tripped a fuse. ow it won't heat. The fan still works
Most likely problem is the the oven element short circuited which caused the fuse to blow. When power is restored everything generally works except for the element. If you check the element you may find a blow hole in it.
Feb 10, 2011 | Electrolux EOD5330 Ultrafan Electric...
The glass has shattered in my electrolux eou6330x door
i live in az here i use aplace called appalince depot . check phone book or net for something similar
Feb 22, 2010 | Electrolux EOU6330 Electric Double Oven
Main oven light and fan comes on but no heat. Reset clock. Happened after power trip. Small oven and grill works OK.
Check that the oven timeclock is not set to 'Auto' as if so this will prevent the oven from working. It should be set to 'manual'.
Try this and then reset oven.
Dec 23, 2009 | Electrolux Ovens
Oven not heating, and tripping .Aeg Electrolux
check your heating ellement
Mar 24, 2009 | Ovens
SMEG DO4SS-5 double oven not heating up
If the fan is running, then it is safe to say that the oven element has gone.
Replace with a new one,(element that is).,
Plz rate this solution.
Thanks.
Dec 15, 2008 | Smeg Ovens
EOU6330 grill doesn't heat-up all the time.
hi Step 1: Check the power cord, the plug, and the outlet. Then look for blown fuses or tripped circuit breakers at the main entrance panel or at a separate panel.
Step 2: If the range is receiving power, set the timer on the range to the MANUAL position.
Step 3: If the element still doesn't heat, turn off the power to the range and test it with a VOM set to the RX1 scale thank u................
Sep 11, 2008 | Electrolux EOU6330 Electric Double Oven
Electrolux oven wont heat up after power cut
hiya
sounds like the fan element could have blown, causing the electrics to trip out. best thing to do is remove all the racking
and then the rear panel that covers the fan and element. if he element has blown most of the time it will be visible.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 03, 2008 | Electrolux EOB6636X Ultrafan Electric...
Ovens Logo
216 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Are you an Oven Expert? Answer questions, earn points and help others
