Question about Bobcat Equipment Skid Steer Flatbed Tractor Trailer
Need to drain hydraulic fluid in my 1998 773 bobcat skidsteer
Need to know the location of the drain plug for hydraulic fluid
I took my bobcat post hole auger apart to service it and had to drain the hydraulic fluid! Now do I have to fill the auger head before connecting it to the machine? Or can the machine do it self?
if the hydraulic oil is from the auger head then the machine will fill and bleed out the air
the hydraulic oil would have been in the hydraulic motor that drives the auger
Jan 07, 2017 | Cars & Trucks
How do i fix my bobcat 825 skidsteers hydraulics ? the right steering leaver works fine but the left does very little to nothing.
basically there are 2 points of control
1---is the control valve for that side which may not be opening the system
2--- the drive motor for that side which may be passing excessive oil and not turning
for the lift action to be slow indicates excessive pressure leakage in that circuit
early units had lever action to the control valves where as later units use electronic controls from joysticks to operate the valves
If this is your type of machine, I would be looking at faulty electronic control mechanisms or corroded wires and contacts
Dec 15, 2015 | Bobcat Garden
How do you bleed the hydraulics on a Bobcat 751 skid steer loader?
Hi Joseph:
Usually hydraulic components will "self clear" any air in the system just by trying to cycle through the functions a few times.
Have to ask the question............
Did you remove and replace the hoses one at a time, or did you take them all off at the same time?
The reason I ask is............ Could there be a remote possibility that any of the hose onnection locations were switched?
Sep 23, 2015 | Toys
I added diesel to the hydraulic tank in my bobcat and never an it. I drained the tank, refilled it, and now the hydraulic system wont work.
You should use hydraulic oil, not diesel, drain it, refill it and if necessary bleed all the air from the system (some are self bleeding) Dependant on the type of hydraulic system you may have damaged the seals by using diesel oil, that, unfortunately is expensive.
Mar 05, 2015 | Bobcat 773
Bobcat 641 skidsteer hydraulic problems.
That's one of the first things that came to mind as I was reading through your post; that the system was air-bound. Are there bleeder valves on the system?
In any event here is a website where you can buy the service manual for your skidsteer; https://mypowermanual.com/shop/bobcat/bobcat-641-642-643-skid-steer-loader-service-manual-download-6566135-10-86/
Feb 20, 2015 | Bobcat Garden
My 1993 compact bobcat skidsteer won't start, it just stopped running and won't start, I have tried starting fluid and still nothing?
Could be engine speed sensor. All fuses need to be checked. Any smoke when cranking? Any fault codes? A bad fuel solenoid could cause no start if fuel is good.
Sep 09, 2012 | RTO Construction Bobcat by Woody Click
New holland ls170 skidsteer runs but will not move and hydralics do not work
Could be very expensive to fix. Check that there is hydraulic fluid in reservoirs/pumps. Check seals on all hydraulics. Check hydraulic pump. Leaks? I'm not an expert, but I almost bought a used skidsteer for next to nothing, but consulted a local excavator-guy I know on it. He steered me away from it saying "It may only be priced at $3000, but it could cost you $10,000 to fix it.
May 27, 2012 | Toys
I need a parts diagram for a 743 bobcat steer skid loader, where can i get a free one ? i need a part and don't know what it's called.
i have a 743 bobcat the hydraulics are noisy and moves very irratic now like its not getting any fluid any ideas
Jan 03, 2010 | Bruder Cat Skid Steer Loader
Hydrolic arms wont lift up or down on Bobcat skidsteer 873
CHECK ALL THE SAFTEY SWITCHES ON THE SAFTEY BAR . IF THE UNIT MOVES FORWARD AND BACKWARDS THE SWITCHES AREN'T THE PROBLEM
Aug 23, 2009 | Danfoss Sundstrand-sauer-danfoss Hydraulic...
Bobcat Equipment  Skid Steer Flatbed Tractor Trailer Logo
414 people viewed this question
Top Bobcat Welding Tools Experts
freddyfox
Troy
Troy
Level 1 Expert
Lawrence Oravetz
Are you a Bobcat Welding Tool Expert? Answer questions, earn points and help others
