Question about Fusion FEW12PK Car Subwoofer
How do i wire up fssion en at110 to stereo with NO rca outs
Just purchased an en at110 with no instructions dont know anything about it, how do i connect it to my stereo that has no rca sockets on it, i am a reall beginner with amps and subs so be specific please, hope someone can help me thanks
  • Anonymous Apr 20, 2009
    i dont no the first thing about wiring and i dont have any sub out puts on my sterio
  • 58 Answers
Posted on Oct 26, 2008
How do i install windows 2003 standard, to my new Acer AT110 F2? on Acer smart cd there's no option for 2003 server :(
I just checked the specs and it supports Windows Server 2003 so it must be possible. They probably did not make a setup wizard for it so you will have to do it the "old fashioned" way. Load the Windows Server 2003 disk in the CD/DVD drive and boot to it as you would any Windows install. If it reaches the screen where it displays the hard disk(s) you are good to go. While the installation is running go to Acer's website on another computer and download the 2003 drivers to a USB drive. When the installation completes, install the 2003 drivers and you are ready to customize it to your needs.
If it doesn't find the hard disks, you probably purchased the optional PCIe 4-port SAS RAID card and Windows 2003 doesn't have a built-in driver for it. You will need to press F6 after Windows install starts so it will prompt you later for a driver for your disk controller. This will allow you to manually install the driver which you should be able to find on Acer's website. (F6 Info:
I hope this helps!
Nov 30, 2012 | Acer At110 F2-E3-1220 E3 1220 1P
What cable do I need to get audio through my tv from the laptop
Assuming your TV has RCA audio input jacks (red/white), you can get a 1/8" stereo mini plug-to-RCA plug. The mini plug would connect to your headphone out jack on computer, and the RCA red/white would go to an audio input on the TV. Be careful with how much volume level you are sending to the TV from the computer. Trial and error, because it's not really common practice. You might have to choose the proper input via the remote/menu on the TV to listen. Be careful. Hope this helps.
Apr 02, 2010 | Televison & Video
I dont know how to setup my amplifier to MP3 Stereo...
Just like any other stereo. Get a wire harness for your car and match the wire colors together, tape them or cap them, or best yet soder them. Then run rca cables from the output in the back of the stereo to the amp. The run a remote wire (bue with white stripe) from the stereo to the amp remote terminal. Hook up the amp normal. let me know.
Dec 22, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Play Ipod thru JVC CD car stereo using RCA cable?
JVC KD-S731R does not have the option of connecting an ipod. The RCA ports on the rear of the unit are a Line-Out. These RCA's only OUTPUT sound. Not an INPUT RCA that you require. The only other method of using an ipod with this stereo is to purchase an FM-Modulator to connect the ipod. Once purchased, you must connect the antenna wire coming from the vehicle to the module, then you must connect the antenna wire coming from the module to the stereo. The other wire will be connected to either a jack or a ipod specific plug depending on the type of modulator used.
Dec 08, 2009 | JVC Car Audio & Video
How Do I Wire An Amp To A Factory Stereo Without Rca Jacks
Hello jon101478,
Purchase a line output converter (LOC) such as the PAC SNI-45T shown here. Tap the LOC inputs into your rear channel speakers and run RCA's from the LOC to your amp. The unit shown in the link also has a trigger wire that you connect to the remote terminal of your amp. You can get a cheaper LOC and just run a switched 12V source to the amp if you wish.
Hope this helps.
Jul 17, 2009 | Car Audio & Video
How to wire an eq to car stereo without an outboard amp?
no those wire is not for speakers out put that for signal in put only if there is rca jack follow the instruction and run your cable if your dont know dont guess you will burn unit audio out put if install wrong
Jun 28, 2009 | Power Acoustik PEQ-70 7-Band Car Equalizer
Need wiring instructions for vbx12a
You will need the following:
A power wire (preferably 4 or 8 gauge) with an inline fuse (typically 50amps)
A battery terminal adapter to connect the power wire
A signal wire to let the amp know when the stereo is on
RCA audio cables to connect the amplifier to your stereo
A ground wire for the amplifier (again 4 or 8 gauge preferred)
Walmart sells a Scosche kit that has all of the wiring as well as a basic diagram for about $25, but it does not include the battery terminal adapter.
If you have a factory stereo you won't have RCA ouputs, so you will need a line level converter. A basic one like the Scosche SLC4 usually runs in the $20 range. You splice into your speaker wires and run them into the unit, then plug the RCAs into it.
Mar 08, 2009 | Visonik VB-10PKG Car Audio Amplifier
Dont know how to insall it !!!
Purchase the aftermarket wire harness at from a local installation shop. WIres will match color for color to this harness then mate to the factory connector. This could save hours attempting to figure out the factory wire harness.
Nov 11, 2008 | Pioneer DEH-2800MP CD Player
Maystar cx475
Ok, I am assuming this is the 600 watt amplifier?
Supplies needed:
- 8 Gauge power wire (long enough to run from your battery to the amp placement) WITH an inline fuse!!
- Depending on your stereo (if it has amp pre-outs or not) you will either need RCA cables (long enough to reach your amp from your stereo) OR a Line-Out converter AND RCA cables.
- The power lead that connects to your "REMOTE" line on your stereo (long enough to reach from amp to stereo - usually blue)
- A good ground wire ( long enough to reach a metal part of your car from the amp)
STEP 1: Find a spot to run the power wire from your battery - through your firewall and into your car - and then to your amp. (DO NOT CONNECT IT TO ANYTHING YET)
STEP 2: Remove your car stereo and look to see if you have PRE-AMP outs (RCA connectors for an amp on the rear of the unit)
A- if you do, GREAT.. proceed to step 3
B- if you don't.. you will need to get a LINE-OUT CONVERTER - what this does is converts the higher signals from your standard wires on your radio, to RCA style wires to connect to your amp.
B2- you will also want to buy a wiring harness kit for your stereo, unless you want to hack away at your factory wires.. (not recommended) - connect the harness kit to your factory wire harness, wire in your leads for the output converter, and run the other end to your stereo.*
*you will need to know which wires run to the speakers you plan to power with the amplifier
B3 - once the converter is properly connected - proceed to step 3
STEP 3: Plug the RCA cables into the stereo or converter, and run them properly from behind your radio to the amp but DO NOT CONNECT THEM YET.
STEP 4: Connect the REMOTE wire from your stereo to the same wire for your amp . (this enables the amp to turn on/off with your radio.. otherwise.. you will have alot of dead batteries)
STEP 5: re-install your stereo into the car.
STEP 6: Connect the RCA speakers into the INPUTS on your amp
STEP 7: Connect the REMOTE wire to your amp.
STEP 8: Connect the speaker wire from the OUTPUTS on your amp to the speakers you wish to power
STEP 9: Connect the POWER CABLE to the amp PROPERLY
STEP 10: Connect the GROUND CABLE to a metal part of your car (sheet metal, not just a bolt)
STEP 11: Connect the POWER CABLE to the battery cable
STEP 12: Re-connect your Battery
STEP 13: Start your car, and test your radio.
If you have any issues from here.. you need to re-check all of your connections.
Oct 12, 2008 | Car Audio & Video
Fusion FEW12PK Car Subwoofer Logo
473 people viewed this question
Top Fusion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Jose Velazquez
Jose Velazquez
Are you a Fusion Car Audio and Video Expert? Answer questions, earn points and help others
