Question about Sony DVP-SR500H DVD Player
Sony dvp-sr500h playback prohibited - Sony DVP-SR500H DVD Player
4 Suggested Answers
SOURCE: Sony DVP-NS57P all region
try thomson
Posted on Feb 04, 2008
ginko
  • 19396 Answers
SOURCE: need unlock code.
I found this region hack here Sony DVP-NS575P region code , check it out:
"Warning
The following guide describes how I managed to make my Sony DVP-NS705V DVD player multi-region.
There are no guarantees that you will be able to do the same. Be aware that you will probably void any warranty you have and possibly even break the player.
Put shortly, you proceed at your own risk.
Introduction
First of all, the Sony DVP-NS705V can be made multi-region simply by applying appropriate service codes, you do not need to install a so called "mod chip".
This supposedly applies to the entire NS-series of Sony DVD players. There are some encouraging reports out there supporting this, but nothing has been verified by me. Again, if you choose to apply this guide to any DVD player, you do so at your own risk.
If you do find that this procedure works on another model, please drop me a line at sonyhelp@selen.org and let me know. Include the exact model number and original region of your player.
Update: Some users have reported success on the following players:
DVP-F21 (special thanks to Garry Self for this one)
DVP-LS500
DVP-LS755
DVP-LS785
DVP-NC615
DVP-NS300
DVP-NS305
DVP-NS310
DVP-NS315
DVP-NS330
DVP-NS333
DVP-NS355
DVP-NS360
DVP-NS400
DVP-NS405
DVP-NS410
DVP-NS430
DVP-NS433
DVP-NS575
DVP-NS585
DVP-NS590
DVP-NS700
DVP-NS730
DVP-NS765
DVP-NS900
DVP-NS905
DVP-NS930
DVP-PQ1 (thanks go to Michael Joy for this one)
DVP-PQ2
RDR-GX3 (thanks to Andreas Norman)
RDR-GX7 (thanks to Daniel Tapie)
RDR-GX300
RDR-GX700
RDR-HX900
RDR-HX1000
Please note that not all players behave exactly like the NS705. For example, some players do not display "success" when hacked.
Thanks to all who have contributed.
The infrared service codes required to make the update are available on the Internet. Unfortunately, not many people have an appropriate device to enter the codes into. You basically need a programmable remote (Philips Pronto, One-For-All) or a PDA (Palm, iPAQ) with suitable software.
This guide shows you how to make the update with a regular PC equipped with an IRDA port.
The procedure
1. Download the winsamp -package from Blank Frank's site.
http://www.veg.nildram.co.uk/remote.htm
This innovative piece of software allows you to send standard home electronics IR signals using a PC IRDA port.
2. Extract the package onto a bootable DOS floppy disk.
3. Download this IR code
http://www.selen.org/files/REMOTE.TXT
file and place it in the same directory as the package above.
This file holds the five necessary IR codes converted to the format used by Blank Frank's winsamp.exe. Please do not bother Frank with questions concerning this particular procedure.
4. Boot up your PC from the floppy disk and run winsamp.exe.
If your IRDA port doesn't appear as COM2 you may override this by using an appropriate command line switch. For example, use COM1 by running 'winsamp C1'.
5. Press the 'r' key to load up the codes into winsamp.
6. Make sure your DVD player is in standby mode and your IRDA port is within range.
7. Run the IR codes from 1 to 5 by pressing Enter on each corresponding button.
8. Your DVD player should start up and display the text "SUCCESS".
9. Repeat step 7. Your player should return to standby mode.
10.Your player is now multi-region."
Posted on Feb 10, 2009
SOURCE: I am from Asia and
Is out there any kind soul that could provide me clear instructions to region unlock a SONY DVP-SR500H ?
Thanks in advance
Please avoid to send misleading links and any other propaganda stuff!. Thanks
Posted on Apr 27, 2011
My DVD player is saying Playback prohibited by area limitations. What does that mean
You can try the region code hack. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Search the site by keyword "Region code"
Jul 14, 2015 | Sony DVP-SR200P DVD Player
What is the universal remote control code?
For Sony DVD Player, one of the below codes should work.
20533, 21533, 20864, 21033, 21070, 21431, 21536.
Sep 02, 2014 | Sony DVP-SR500H DVD Player
Sony dvp-sr500h will not spin and reads error
The error likely is the unit detects the platter is not moving---unless an expensive unit it will be cheaper to replace the player than fix it.
Jun 13, 2012 | Sony DVP-SR500H DVD Player
Region unlock a Sony DVP-SR500H
Ok here's what I've figured out for Sony dvp sr500h...
To get to the hidden menu, you need to start with the DVD player power OFF
then hit
TOP MENU
CLEAR
POWER (to turn the dvd player on)
and you should now see the hidden menu
then go to option 2
then option 4
then this is as far as I get...you can enter codes here but none I've tried have worked....
the ones I've tried so far are 2812, 34570, and 12450
if anyone can figure out the correct code please post here.
Apr 27, 2011 | Sony DVP-SR500H DVD Player
We bought a new Sony DVP-SR500H dvd player. I hooked it up with hdmi cable. It will not eject the tray to load a dvd. It just says "load" - no errors. Not childproof locked. Help!
After NOTHING worked (including tips from other sites) I took it apart and literally forced the tray in and out of the player. Guess what? The damn thing works like a champ now!!!!!
Feb 06, 2011 | Sony DVP-SR500H DVD Player
Sony DVP-SR500H DVD Player Logo
65 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
