Question about Toshiba 42HP83 42 in. HD-Ready Plasma Television
Toshiba 42hp93 can anybody tell me how to enter the service mode on a toshiba 42hp83 plasma tv i will appreciated it, need it asap. thank for your time and help.
  • ESTEBAN MERINO
    ESTEBAN MERINO Oct 27, 2008
    thanks hitchez for the info. i adjusted the brightness, it was too dark, now i know that i have a bad panel because i have a black stripe in the middle bottom part of the screen, or is there another problem with this tv please let me know and thanks again
  • 42 Answers
Press the MUTE button twice on the remote control, then press and hold the MUTE button, while pressing the MUTE button press the MENU button on the TV at the same time. This should get you into the service mode Good luck and be careful.
Posted on Oct 26, 2008
24af45 factory reset
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jan 08, 2017 | Televison & Video
How to reset my tv
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done..
Jan 08, 2017 | Samsung Televison & Video
My sh100 is stuck on the menu screen when you turn it on
Do a reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Black screen, green light on the bottom is on, electric plug is on house plug, no picture, was working fine last night, now only black screen!
Do a hard reset to this set, and then check. If it do not help you, check and replace its main digital board. It will be faulty.
WHERE IS THE RESET BUTTON ON MY TV
What is the brand name and model number of the TV. Can't say anything without these information. If the set is not too much older model, there will be no such button marked as "reset". For modern sets, if you have to do a reset, you should enter its service mode. It is somewhat skilled procedure.
How do i fix black spots on my LG plasma tv. model 50pj350ub
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jan 08, 2017 | LG 50PJ350 50 HDTVReady Plasma TV
Samsung plasma TV model #pn42b400p3dxza problem with no image. The TV has sound but no image. I've tried using other components on the TV like RCA jacks with a separate TV digital tuner. Thank you
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Check whether Va & Vs voltage come to the display panel, from the main power supply regulator board. If not, the SMPS board [power supply regulator board] is faulty.
Toshiba tv model32w2300A how repair? 0nly in the screen say do not put the power off
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Jan 07, 2017 | Toshiba Televison & Video
How do I reset the TV?
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 18, 2014 | Televison & Video
50" LG Plasma Screen TV does not have any sound or activity on the screen.
input correct ? eg:HDMI 1 USE MANUAL TO GET INTO SETUP MODE.go through all settings.check the contrast and brightness buttons n the TV if any on back or top.
Apr 15, 2013 | Televison & Video
Toshiba 42HP83 42 in. HD-Ready Plasma Television Logo
292 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
