Question about Exercise & Fitness
Error message 3 on cybex pro 530t model treadmill
  • Exercise & F... Master
  • 918 Answers
Error 3 is a speed signal lost error. Check speed sensor, lower board, drive motor then display.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Posted on Nov 23, 2015
2 Suggested Answers
  • 218 Answers
SOURCE: Need to download manual for cybex 530t treadmill. Can't find link
replace the console, you buy that part individually
Posted on Aug 13, 2010
Cybex belt not starting
Are you getting any error codes. Usually no belt movement is bad or short motor brushes. I would start there first.
Apr 24, 2014 | Cybex 530T Pro Plus Treadmill
Cybex 530t error 1
Error 1, Err1 Belt didn't start (or no speed sense) 1. Perform speed calibration procedure
2. Check speed sensor
3. Check motor brushes
4. Check drive motor
5. Check lower board
I am attaching a link for the service manual. This information can be found on page 65. You can use this manual to determine the steps required for checking the above mentioned items.
http://www.sportsmith.net/images/product_support/cybex/Manuals/Service/LT177304-CybexProPlusTreadmillOwnersServiceManual.pdf
Cybex Pro 530T Treadmill Parts Deck Belts Motor Rollers SPORTSMITH net
Apr 09, 2014 | Exercise & Fitness
Displaying error 1 what could be wrong and how do I repair it?
Apr 09, 2014 | Cybex 44325 Pro 530t Walking Belt X07-07
Cybex 530t error 6
Error 6 is a motor over voltage error. Motor voltage exceeded 200 VDC for 200 milliseconds. This can be caused by a worn deck and belt due to a lack of routine maintenance. AKA adding wax between your deck an belt. You might be able to wax your machine and make the error go away. More than likely a new deck and belt will be needed. Using the link below and your model and serial number, you can find the needed items. In worse case scenario, you may also need a new motor control board.
Repair Parts for Trotter Cybex Treadmill 400T 410T 500 Series SPORTSMITH...
Jan 20, 2014 | Exercise & Fitness
How to calibrate speed on a treadmill
Make sure power switch is off; hold down any key on the display and turn power switch back on. Unit will go into diagnostic mode. Press and hold the start key until unit beeps and begins to calibrate. Make sure you are not standing on the belt during process. Let unit run its course and slow completely then hit stop. you're done.
Dec 30, 2013 | Cybex 530T Pro Plus Treadmill
Cybex 530t error 1
Error 1 is a no speed signal at startup error. With or without belt movement? Check the Speed sensor, lower board, or brushes as a possible solution to this error code.
Jun 25, 2013 | Exercise & Fitness
Cybex 530t treadmill speed slows down intermittently anyone help
Please LUBE deck belt + rollers bearing too
2) test the input voltage motor, if there are the motor need repair.
3) test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Dec 17, 2012 | Cybex 530T Pro Plus Treadmill
Cybex 520T error message 3
Feb 08, 2012 | RTO Cybex 520T Remanufactured Treadmill
Jul 20, 2010 | Exercise & Fitness
Exercise & Fitness Logo
275 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
