Question about Daewoo Washing Machines
Dwd-g1241s switch it on fills with water for few mins then it beeps and E8 comes on screen
5 Suggested Answers
ginko
  • 19396 Answers
SOURCE: Daewoo Washer Error E8
Hi.
E8 is fault connection from CCU (Control board) to balancing sensor.
When you get E8, this is often because of a faulty control board.
Try first disconnecting power for a couple of minutes, to reset the appliance.
If you still get E8, then you need to call a technician. Testing is done jumping the two wires to the sensor to bypass the sensor, then replacing either sensor or control board.
If you want to arrange a repair, then you can call the phone number listed on the machine owners manual.
Regards.
Posted on Nov 08, 2009
  • 3 Answers
SOURCE: E8 code when washer fills on front loader daewoo
E3 CODE WHAT MEANS
Posted on Apr 09, 2010
  • 713 Answers
SOURCE: When using the smart drive 051 the machine
Hi just read your posting.Now when the machine beeps a series of lights will light up.They will be in a row of 8 lights.Starting from the left to right which ones are lit.Is it the 2nd and 4th or the 1st and 6th ---etc---?Please reply with additional information and I can help you rectify this fault.
Posted on Aug 04, 2010
Daniel S
  • 4323 Answers
SOURCE: I have a Daewoo DWD FD1233. It's brand new &
Hi
E8 error is displayed due to no communication between the Control board and the balancing sensor, the wire harness connecting both these should be checked. If fine then the control board should be replaced as its still under warranty. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 11, 2011
I have a Daewoo washing machine DWD-F1011 S, 7 KG..IT STOPS AND gave us an error with code E8.. HOW CAN WE SOLVE IT?
this is what I found E8 Washing machine motor error detectedA fault has been detected with the main drive motor.
  • Check motor connection block
  • Abnormal loading condition
Mar 13, 2015 | Daewoo Washing Machines
Cycle starts waters comes in, after about 30 seconds water goes out beeps 4 times goes off
Hi
It would be helpful to know the brand/ model etc.
Usually if the water gets in, and then drains out straight away, the dishwasher thinks that it is either not filling, or over filling. If there are 2 pressure switches, there would be one for fill and one for overflow, the fill one (or the pressure tube to it) would be faulty.
Otherwise, if there is only one pressure switch, it may be a dual switch, in which case it is faulty.
If it is a whirlpool or LG, there may be an issue with the flow meter which checks the volume of water coming in.
Best of luck with it. If there are further issues try to supply more info in your response as while dishwashers all do the same thing, some brands go about it in very different ways.
Adam
May 28, 2013 | Dishwashers
What meens E8 error at crystal DWD-F2011W
the coal of motor is finished , you must to change the coals
Apr 10, 2011 | Whirlpool Washing Machines
The washing machine model is DWD-G20D1 it just stops after about 10 minutes or so and starts beeping. H6 shows up on the display also. The fabric conditioner is not taken from the drawer but the soap...
it is shakeing during the spin if so level it saftey switch shutting it down because of low voltage...low water''' or to much shakeing going on durning spin
Mar 16, 2011 | Washing Machines
Daewoo DWD G1243S washing machine not filling properly. 'ie' coming up on display & bleeping. What can i do to solve it?
When you hear that macinhe is beeping and giving 1E code, turn it off and make sure that water feeder is turned on and that it can feed water into the machine, turn it back on and start your program, it should be fine :) .... Good Luck....
Dec 27, 2010 | Daewoo Washing Machines
When using the smart drive 051 the machine attempts to start filling (on a cold wash) then the water flow switches off after a few seconds and timing is inconsistent of the attempts to fill. After 3...
Aug 03, 2010 | Fisher and Paykel Washing Machines
My washing machine (dwd-wd32ws) only uses hot water to wash!
hi,
try and switch your hot and cold water hoses around the other way. it should start the cycle with hot and rinse cold.. If it still does it you may have to have it serviced..
jm
Nov 27, 2009 | Daewoo Washing Machines
Error code E8
Most likely a control or motor issue. Probably should call service.
Sep 15, 2017 | Daewoo Washing Machines
Reset anti flood device in dishwasher Beko DWD 4310 S
**** the water out of the pan below the dishwasher, there is a float in the pan if you have a leak and the pan fills with water
Jan 17, 2009 | Dishwashers
Hi.
Regards.
Nov 22, 2008 | Washing Machines
Washing Machines Logo
Top Daewoo Washing Machines Experts
Owen Barnes
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
