Question about Ruud Heating & Cooling
UPMC 042JAZ MAnual RUUD - Ruud Heating & Cooling
4 Suggested Answers
  • 674 Answers
SOURCE: We have a RUUD AC unit, model number UAMB-042JAZ. ...
Those are the low voltage wires from the thermostat and transformer. Yes he can just match up the colors and splice with wire nuts or something else to hold the tight. If the transformer got shorted out during any of this it may need to be replaced. Hook them up and if the unit runs, then no problem with the transformer.
Posted on May 23, 2010
  • 45 Answers
SOURCE: ruud upne-042jaz fan not starting
If the fan motor is not starting it may be the capacitor located behind the electrical panel on the outside unit. These are relatively inexpensive and easy to change. You can disconnect the power to the outdoor unit and remove the capacitor. Take it to your local HVAC wholsaler or contractor and have them check it. If its bad it should run you 20 to 30 dollars to replace. If it is not the capacitor then it may be the fan motor. If the blade turns easy it means the bearings are fine. One of the windings may be open thus making it able to turn but not run when power is supplied. I think this is a heat pump and there may be a control board on the outdoor unit which may control the operation of the fan. I have not found a wiring schematic for the unit yet. Once I find one I will let you know. The problem listed above is very comon and inexpensive for you to fix. If it is something other than the capacitor, I would call you local NATE certified technician and get her looked at.
Posted on Jun 07, 2010
pctech1
  • 1940 Answers
SOURCE: I have a RUUD Model
Most likely you have this A/C plugged into an extension cord that is not large enough, an outlet that doesn't have the juice to power this A/C, or your A/C is burned out and drawing too much electricity. It could also be possible that the breaker is worn out. They are only designed to trip a few times before they don't operate properly any longer. Also, make sure you don't have this A/C plugged into a surge protector.
Posted on Jun 23, 2011
I need to know if the Ruuduaka-042jaz 3.5 is good for a mobile home
The outside unit will work,but not the matching furnace!
you have to have a specific manufactured home furnace, because off Co
Nov 15, 2015 | Ruud UAKA042 Air Conditioner
Where can I get a service manual for a Ruud Ac model UAPC-42JAZ
Go to the following web address:
www.servicemanuals.net/‎
Oct 07, 2014 | Ruud Heating & Cooling
What size capacitor does the out door fan motor require on a RUUD Model number UPMC-042JAZ
call your local ruud dealer and have him cross reference model number or look on fan motor itself, if original then cross reference ok, but if it has benn replaced look on the fan itself
Jun 19, 2014 | Ruud Heating & Cooling
What is the seer rating for UPMC-030JAZ
seer is dependent on what air-handler and coil it is mated with.
Oct 28, 2013 | Ruud Heating & Cooling
How to hookup Auxiliary heat (and/or use an extra wire at the thermostat)
They don't always use the correct wire colors,if it is labeled w it is for your strip heat,shouldn't hurt to hook it up,most likely they used it for the strip heat,most heat pumps are wired to turn on your strip heat when the heatpump is in defrost mode and it is controlled by the heat pump,you can hook this to the emerg. heat or w2 :)
Mar 08, 2013 | Ruud Heating & Cooling
WHAT SIZE UNIT IS A model # UAKB-042JAZ SERIAL # 6953F300414316..HOW MANY TONS IS IT...
They are: Height:19in X Length: 40-1/2in X Width: 27-5/8in
You can also check the manual here:
http://www.adamsheatingandcooling.com/ruud/ruud-ac/uakb/UAKB-specs.pdf
It is located on page 6.
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 04, 2011 | Ruud UAKB048 Air Conditioner
May 21, 2010 | Heating & Cooling
Central Air will not come on.
You may want to call around to the different supply houses in your area. Most supply houses will not sell to unlicensed people but occasionally you will find one that will but there isn't a warranty and they jack up the cost. You might have a hard time finding the right relay as well because Ruud/Rheem in the last few years are designing their parts to fit just their brand just like Lennox, Carrier, and Trane does. It keeps money in their own pockets. Good luck finding what you need.
Apr 04, 2009 | Ruud UAKA042 Air Conditioner
Is ruud heat pump model upka-042jaz a single or multiple stage pump?
I NEED THE MAKE AND MODEL OF THE T-STAT TO HELP YOU
DID HE CHANGE ANY WIRING?
Jan 15, 2008 | Ruud UAKA042 Air Conditioner
Heating & Cooling Logo
473 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
