Question about Plustek Office Equipment & Supplies
Plustek smartoffice ps282
Started getting DocTWAIN - Generic Error after 3 or 4 pages have scanned. Downloaded latest driver from mfg. Solution?
4 Suggested Answers
mohanchennai
  • 490 Answers
SOURCE: Parts of page being scanned are cut off
Whcih version of CapturePerfect you are using?
I use ver 2.0. In the settings page select scanners maximum. In the 'advanced' select auto detection. Then whatever size of the paper guides you choose, that will will be the width and ofcourse the length is automatic. There is a sensor under the paper guide, and it detects the paper width. Any rotation chosen will be after scanning the required size.
S. Mohan, Chennai, India
Posted on Jul 21, 2009
Tauqeer
  • 496 Answers
SOURCE: I have a Plustek OpticFilm
It is quite possible that there is another piece of software that is clashing with your Plustek OpticFilm scanner. It is hard to tell which software is having a clash. If you remove that software from your system you will obtain the desired results. I suspect the SP3 of Windows XP may be responsible for this because Microsoft has indicated that Windows XP SP3 is not for everyone. If you install Windows XP SP2 uninstalling XP SP3 your problem can definitely be rectified.
Good Luck!
Posted on Mar 10, 2011
SOURCE: i have plustek opticpro A360
There is a pink line down the middle of each clour scanning
Posted on Oct 31, 2011
We currently have a PlusTek SmartOffice PS282 scanner that we use for our tax business. Between the hours of 9am and 12pm it works perfectly fine. However after 12pm it quits working for the rest of the...
Try this
Open Printers and Faxes from the Start Menu (or from Control Panel)
Right click on the PS282 device and select 'Properties' from the popup menu
Select 'Advanced' tab
Make sure 'Always Available' is selected NOT 'Available From' ...
Mar 11, 2011 | Computers & Internet
I have a Plustek OpticFilm 7600i SE film scanner. Every time I try and load-up the setup disc, the set up install starts and then comes up with this error message: An error (-500 : 0x8004ace8) has...
Good Luck!
Mar 10, 2011 | Plustek OpticFilm 7200 Film Scanner
Message says generic error
Reinstalling the latest driver for your scanner should correct any software related issues.
You can find the drivers for your scanner here: Drivers V 4.2.2.2
1. Download the driver and save it to a folder on your desktop. You will then need to right-mouse click the file and EXTRACT the installation files. Do not run the installation with the scanner connected.
2. Turn off your computer and disconnect the scanner.
3. Restart your computer with the scanner disconnected and run the scanner installation program found in the folder, usually SETUP.EXE. Follow the prompts. Do not reconnect the scanner until prompted to or the installation ends.
Please be aware that the scanner installation file is 118MB and may take quite a while to download depending on your internet connection.
Happy Scanning, Myridom
Mar 05, 2011 | Plustek OpticBook 3600 Plus Flatbed...
HAVE A REV SCAN 192001 BUT COMPUTER WILL NOT CONNECT TO SCANNER I DO NOT HAVE INSTALLATION DISC
Disconnect the scanner from your computer and go to Plustek's website (http://plustek.com/)
Download the driver that matches the scanner model and the version of Windows you are using.
Double click on the driver file you downloaded and connect the scanner when prompted or when the driver finishes installing.
If this helps please vote for my solution.
Nov 30, 2010 | Plustek OpticPro UT12 Flatbed Scanner
I HAVE LOST CD FOR INSTALLATION FOR SCANNER PLUSTEK OPTIC Pro U12B. kindly tell how to install scanner in my computer
1.First download the scanner driver- ->Plustek OpticPro U12B driver(Windows XP ver.)_ 2.Save it somewhere where you will remember after download . We recommend that you save it on your desktop , so it will be easy to find ..
3.Double- click the file you downloaded .
4. Follow the on-screen instructions.
5.When it's successfully installed , please restart your computer
6.After you have restarted the computer , plug the scanner into your computer and it will automatically recognize the new hardware.
Nov 26, 2010 | Plustek OpticPro U12B Flatbed Scanner
Cant find driver for plustek scanner 1248U
Here is a link to the download page for the driver http://www.nodevice.com/driver/1248U/get25445.html
Just to the middle right of the page 3/4 of the way down is a box that says please enter verification code and then below it a download box. You will need to enter that code and then click download. Then install it on your computer. The driver works for OS up to windows XP.
Nov 11, 2009 | Plustek OpticPro 12000P Flatbed Scanner
Scan to OCR error message
remove all associated driver and scanner software reinstall all the software with the scanner and printer disconnected then rebootit all connected. Try again
Jul 24, 2009 | Brother MFC-9840CDW Laser Printer
Canon DR-3080 CII Scanner
I recieved this error when trying to scan pages in using our new Kofax scanning solution with a DR-3080CII. I discovered that the latest canon driver for that scanner was not compatible with the software and it made the application hang in the background. I found an older driver that was compatible and installed it, no more error.
Sep 10, 2008 | Canon DR-3080CII Path-Through Flatbed...
Scanner will not scan
Various things[as usual] can affect the performance of a USB device, so check these out. 1.Too many USB device hooked up drawing power from the system - So if it is not in use -unplug it. 2. The driver and or software for the device has corrupted.- Re install 3.Too many programs of a similar nature [graphics in this case] running and confusing resources.- shut down those not in immediate use. Do check the Plustek website for the latest driver[s] A Golden Rule for clean and simple computing is if you are not using it - shut it down. Come back with this one let us all know how it goes.
May 19, 2007 | Alestron OpticBook 3600 Flatbed Scanner
64 people viewed this question
Top Plustek Office Equipment & Supplies Experts
Gareth Cockram
Gareth Cockram
Jax Planet
Jax Planet
Are you a Plustek Office Equipment and Supply Expert? Answer questions, earn points and help others
