Question about Microsoft Xbox 360 Console
Problem persists i've tried the solution provided but no matter how i connect my xbox to the TV i still get the same! (no video only audio)
  • 1 more comment
  • CKKsker Oct 26, 2008
    Has anyonecome up with a solution to the audio and no video problem? I have just started to experience it.
    No video when I start xbox 360 I get audio but no video.
  • KillaFoz89 Oct 26, 2008
    nice try dudebut i got it plugged into the HD componant input on my TV (with the switch onHDTV) and it dont work! same if i plug it into the standard defonition input on the TV (with the switch on TV) still no video on screen but audeo both times! solve that one please! lol! i just bought fable 2 and still not been able to play it!
  • 94 Answers
The switch in the back of the consle should be set on tv not hd
Posted on Oct 26, 2008
Xbox elite connected to TV thru HDMI works fine, but connected via bcs-fs500 receiver = no audio or video Cable tv through receiver works fine Have tried cable tv through receiver inputs HDMI 1 and 2...
Hook your Xbox to tv via HDMI, then hook TV to reciever through digital optical or composite cables. If you try to get your picture through receiver first, you may get picture and sound but, sound may be delayed and picture might not be the best. Bettter to run through tv first then provide sound to receiver.
Mar 31, 2011 | Pioneer Audio Players & Recorders
Dell mms 5650 to play xbox 360?
You want to hook it up to your xbox or your tv? If it is connected to your tv already just adjust tv/xbox audio settings. If your looking for a place to plug it into your xbox your out of luck. I don't think that can be done without some skilled craftsmanship.
Jun 23, 2010 | Video Game Consoles & Games
I plugged in my Xbox 360 and then i moved it to a different wall then put it back to the original place it was in the beginning now the sound cant work
Check the audio/video cable. Make sure it's securely in the back of the TV and console. If you still have the same problem, hook your xbox up to another TV on which you know the sound input works. If the problem persists, you no know that it's not the TV but the xbox. You could purchase a new audio/video cable from somewhere like Best Buy. If the new AV cable didn't work, you could take it back to the store and then give Microsoft a call at 1-800-4MYXBOX. Good Luck!
Jan 07, 2010 | Microsoft Xbox 360 Console
Which wires doi use to connect up my xbox with my
In order to connect your Laptop with Xbox 360, you will have to use the ethernet cable that came along with the Xbox 360,
For connecting the Xbox 360 to TV you would be having a HD AV cable if you have a Xbox 360 Pro model, you would have to insert one part of this cable with 3 colored wires red,blue and green to your composite video port behind your tv with similar color coding, and on the Xbox 360 HD AV cable you have an option to choose either TV or HD video output based on your TV make, also this cable has two more wires red and white meant for audio connectivity which would go to audio port behind TV with same color code ports
If you have got a normal AV cable with Xbox 360 then it would be a a wire with one single yellow colored wire for video and two wires Red and White for audio
Nov 23, 2009 | Microsoft Xbox 360 Console
Hi i want to know how to connect my gamecube to my portable dvdplayer
I'm going to assume you are trying to be able to play both gamecube and the dvd player on one tv. Not at once, but I'm guessing you think you can't hook both to the TV. If you no matter what big tv it is, you can connect it to your tv.
If your trying to connect the gamecube to the dvd player then you need to have inputs and outputs on the dvd player itself. hook the video and audio of the gamecube to the input of the dvd player and the ouput of the dvd player to the input on the tv
Aug 09, 2009 | Pyramat PM450WR for PlayStation 2,...
No sound but picture
You have several ways to receive the audio signal.
>Your HD tv should have inputs for DTS or HDMI
The HDMI transfers all signals audio and video with on cable
The DTS replaces the white/red audio. The xbox as this cables
or you can buy them
If you have the RED/White on your tv and you do not have enough
connections.. The you can buy a (Y-Splitter Cable) They are cheap!
Aug 26, 2008 | Microsoft Xbox 360 Console
XBOX 360
Your tv could have a losse connection on the video input. Try moving it around to see if you get any picture. Either that or u need a new audio video cord for your console
Feb 15, 2008 | Microsoft Xbox 360 Console
Black and White Only
I had a similar problem when I first connected my son's xbox using the Audio/Video cable (red, white, & yellow connectors). I connected the cable to the TV correctly, but incorrectly selected "component" as the input on the TV setup. Result was black and white display. Switch your TV input mode to "AV" or "Audio/Video" and you will get color.
FYI, "component" TV mode is only used with devices that use the red, green, & blue connectors.
Jan 30, 2008 | Microsoft Xbox Console
Xbox 360 video and audio
Hey mate, check to see if the cables are connected to back of the TV correctly, try another TV if you are able too.
How are you connecting the xbox 360? try using the scart cable, see if you have a picture.
Report back with your findings,
Hope it helps
Z33m
Dec 10, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
22 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
