Question about Black & Decker Drills
How to remove chuck from black and decker firestorm 7 amp drill
How do I remove the chuck from a B&D Fire Storm 7 amp drill?
  • 583 Answers
SOURCE: Cordless Drill, Keyless Chuck stuck in full open position.
if chuck is wide open ,look down inside there should be an allen screw or bolt at the bottom of the chuck it should undo anti clocwise and the chuck comes off
Posted on Aug 18, 2009
woobie dog
  • 1273 Answers
SOURCE: Black and Decker Cordless Drill Chuck stuck in full open position
I'd put penetrating oil in it and tap the chuck with a plastic hammer. That should free it up.
Best rgrds, W/D
rowdy45176
  • 2176 Answers
SOURCE: replacing the chuck on black & decker drill
remove the chuck retaining screw LH thread, and then find a bent handle allen wrench about the chuck capacity and insert the shorter piece in the jaws and tighten, Shift the tool to the low position (if it has one) and the selector to drill only (if it has one) position the chuck on a block of wood at about a 30 degree angle so you can strike it counter clockwise and hit it with a hammer, it might take a couple times but it will come off. Reinstall in reverse order,
Posted on Oct 10, 2009
  • 32 Answers
SOURCE: how to remove chuck from cordless Black and decker
open the chuck all the way then look in and you will see the head of a screw take that out .
then you need to hold the arbor some how so you can un screw the chuck from the shaft.
Posted on Nov 06, 2009
wireguy212
  • 1627 Answers
SOURCE: I have a Black & Decker 18V cordless drill
Look at the three jaws in the chuck,if on is further out than the others the you need to tap ti back into place with a small punch and a hammer.If this does not work then you need to replace the chuck,remove the screw at the bottom of the chuck[where you put the bit],then you will need to to clamp vise grip on the chuck and with it pointed away from you hit the vise grips with a hammer with a sharp blow downward and it should come off.Hope this helps.
Posted on Jun 12, 2010
How to remove a dr200 BLACK & DECKER 3/8" DRILL CHUCK, no chuck screw in chuck
Hi- We have instructions on how to remove the chuck listed on our website Q&A. I have included the link. Please use the instructions for the Keyed chuck. blackanddecker com
Thanks Black + Decker Customer Care
Mar 18, 2015 | Black & Decker Drills
Keyless chuck overtightened
two strap wrenches work well becasue they will not crush or scratch the chuck like channel locks or any plier.
Apr 04, 2014 | Black & Decker Black and Decker FIRESTORM...
Black & Decker cordless drill 9.6V chuck will not come off shaft
If it won't close the only other option you have is to break the outer collar and use a chisel to hit on the exposed jaws inside the chuck. I have detailed instructions in the tip section on how to remove a chuck from these drills. Let me know if you need more assistance.
Jan 31, 2012 | Black & Decker Drills
Chuck removal B&D KD335 drill
I have instructions in the tip section that might help. There is usually not much difference in the removal of a corded or cordless drill. Let me know if you need more assistance.
Jan 25, 2012 | Decker BlackN Household Drills and Kits...
How do I remove an attachment to chuck of black & decker household drill with cord
There is an 2 types of chuck ether it is an screw type or not..If your drill chuck is an screw type it is easy to remove if it is not you must have a special tools to remove it.
Jul 23, 2011 | Decker BlackN Household Drills and Kits...
How to remove the chuck of Black & Decker Drill BD154R?
You need to open the chuck and remove the bolt from the bottom of it[usually a #2 phillips].The next step is to insert a 5/16 allen wrench into the chuck and tighten the chuck.Hold the drill with the chuck facing away from you then strike the allen wrench with a hammer on the right side[so it goes down] and now you will be able to remove it by hand,good luck.
Mar 21, 2010 | Rotary Ryobi 1/2" Hammer Drill ZRD551HK
How do you change the different tools on a firestorm black and decker 12v cordless drill.
I am guessing that you need instructions on how to use the chuck.
Put the drill in reverse, grab the chuck with one hand and then run the drill for a moment, this will loosen the chuck so you can insert a new bit into the end.
Be careful to not spin the drill too fast or you may hurt your hand.
To tighten the chuck you simply put the drill in regular/forward mode and grab the chuck while running the drill.
Mar 17, 2010 | Garden
Black & Decker 24 volt battery will not hold a
Click on the link below and you will find replacments
You need to work out if the cost of two batteries is cheaper than a deal on a new drill pack
http://www.svcvacuum.com/black_and_decker/black_and_decker_battery.htm
Jun 01, 2009 | Black & Decker Black And Decker FS24C...
Can't remove the chuck on a drill.
There are one-way (non-reversible) and two-way (reversible) drills. Mine is one-way. Methods for chuck removal are different for these two types.
Procedure for one-way (non-reversible) drills:
Drills of this type have no chuck screw, so one have to hold the spindle with a wrench, than to sharply strike the wrench with a hammer to spin it off.
Procedure for two-way (reversible) drills:
Open the chuck up and in the bottom is a screw that holds the chuck on the shaft.The screw turns in a clock wise motion to be removed and then you can top the chuck off the shaft.
May 19, 2009 | Black & Decker Drills
I can't get the drill bit out!
IT SOMETIMES HAPPENS WHEN THE SAME BIT IS USED WITHOUT REMOVING IT,HOWEVER I WOULD TAKE 2 PAIR OF CHANNELLOCKS TO OPEN THE CHUCKIF THE BIT IS STUCK TO DEEP IN THE CHUCK YOU MIGHT TRY A LITTLE AND I MEAN ALITTLE PENNETRATING OIL.HOPE THIS HELP'S
May 10, 2009 | Black & Decker Firestorm Slide Battery
Drills Logo
99 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
