Question about Honeywell Heating & Cooling
I have a Honywell wall thermostat, Model RLV3120, and it gets very hot to the touch while it is on. Is this normal? The other thermostats in my house do not get hot.
hotuna
  • 288 Answers
SOURCE: Williams wall non-elec gas heater. Black copper wire tagged thermostat?
First make sure this is a heater set up for a remote mounted thermostat. If so, the gas valve has 3 screws labeled TH (thermostat) and TP (thermopile) that's the flame sensor with 2 wires coming off it, I don't know where the goofy name comes from. there will be one screw that has both, usually the top one. Wire accordingly. The new valves have a solenoid on the bottom. this connects to the high temp. sensor up top. It has 2 wires on it, one connects to the thermostat wire, the other goes to the screw with TH and TP. Or you can skip it and connect the wire from the back of the valve to the Th and TP screw. Make sure the thermostat wires aren't pinched somewhere, thus eliminating the thermostats control.
Posted on Mar 02, 2008
SOURCE: honeywell thermostat
Hold down the system button on the left side of the screen for a few seconds then after the screen changes hold the two buttons to the left and right of the center button on the bottom of the screen then use the left arrows to get to 670 and the right arrows to get to 0 that is how I unlock mine? Good luck!
Posted on Oct 20, 2008
  • 5 Answers
SOURCE: thermostat burning walls
your thermostat may not be made for electric heat, if not then your wiring is overloading the thermostat causing the wires to heat up.
Posted on Apr 26, 2009
milten1
  • 1304 Answers
SOURCE: i am installing honywell thermostat rth111/rth221
rh goes on red, this is what will provide power to the heat
rc is red if you want to power the ac unit
Posted on Oct 21, 2009
billyvangogh
  • 108 Answers
SOURCE: Replaced mercury thermostat w/Honeywell CT87K - doesn't work!
You need a specific thermostat for a Wall Furnace it is a Millivolt Thermostat and not a 24v standard thermostat....usually it will work anyway however if the powerpile (generator produces millivolts from the pilot light) is weak it may not be producing enough...or the Pilot light may be dirty and lazy...won't produce enough millivolts ...or you can have bad or dirty contacts or connections....or a combination of any of the above.....a 24v Thermostat and particularly a non-mercury thermostat has too much resistance in it for a millivolt system....as your Wall Furnace (other than the fan) runs on less than 1 volt
Posted on Oct 31, 2009
Door rubbers heating up to much
FRIDGE COILS or door walls SEEM VERY HOT:
The condenser coils do get hot. They can even be to hot to comfortably touch and this is normal.
The refrigerator should not run constantly but shut off with each defrost cycle.
Running constantly and never cycling off can indicate a cooling problem.
One thing to try is to wait till it has been running a few minutes then open the door and turn your cycling thermostat towards the off position. It should cycle off before getting to the off position on the dial.
If it does not cycle off then it's not getting cold enough to satisfy the thermostat. This is likely the reason the refrigerator runs all the time.
A thermometer in a glass of water can be used to check the temperatures in the refrigerator section.
You can check that all fans are running.
Dec 25, 2014 | Samsung Refrigerators
Out side gets really hot why?
Jun 30, 2014 | Kenmore Refrigerators
Dryer is extremly hot to the touch, condensation on cabinets and walls in the laundry room it gets so hot in there when dryer is running
Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat. What is your model number?
Nov 28, 2010 | Electrolux Dryers
Cant take off cover to replace battery from my honywell thermostat
Here is a tip that tells you how to get a manual for most any Honeywell product online...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Nov 26, 2010 | Honeywell Programmable Thermostat Heater
I have a honywell programable thermostat, that, once a week or so, " unprogammes itself and shows a code "olo eo", the problem started about the same time an electrician came to our house to do some work,...
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Feb 22, 2010 | Honeywell Programmable Thermostat Heater
Front Center wall getting hot to the touch On Frigidaire side By
Normal operation to reduce outside condensation.
Could get up to 120 degrees.
Jul 04, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
A8 4.2 v8 engine overheating v reg 1999 no oil loss check system ok temp falls to normal if heater on full maybe engine fan failure ? coolant level ok thanks craig
run it and let it get hot (not to the point of overheating just let it warm up to normal or slightly above normal).  put your hand near the upper radiator hose, if you feel not heat, touch it, be careful as it may be hot.  if it is not hot at all but the engine is warmed up it is the thermostat, the thermostat is located where the upper radiator hose connects to the motor, usually a 2bolt metal fitting, if this is the case just replace the thermostat.
Jan 26, 2009 | 2000 Audi A8
Replacing a non-programable thermostat for electric baseboard heater with model CT410B. This is a 4 wire thermostat replacement for a previous 2 wire. Directions indicate that I can do this. I connect...
If you take thermostrat back off and connect the wires together will baseboard heater get hot. If not you may have bad heater. If it gets hot your new tstat may be bad. The way you have it wired is correct. Most line voltage tstats have a ground screw. Your 's may not but will work without one .
Jan 23, 2009 | Heating & Cooling
Heating & Cooling Logo
131 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
