Question about Sewing Machines
Pfaff ambition 1.0 buttonholer doesn't work
The machine makes a buttonhole, but never the size of the button. Sometimes there is a complete buttonhole, but too small. Sometimes one side is long enough, but the other is too short
SOURCE: machine will not complete a buttonhole, keeps showing error code 6L. No error code listed in manual. Machine will only do first half of buttonhole and then shows code and stops.
I've been looking too and I found here http://sewing.patternreview.com/cgi-bin/sewingclasses/board.pl?t=18328that you need to put the bar behind the needle threader down. I think they call it a button hole stop? I don't know, but it worked. I didn't even know it existed. But it solved my problem. On my Kenmore it looks like a black lever and you pull it down. It tells the button-holer that you are at the end of the hole and it needs to backup. nifty, kind of.
Posted on May 27, 2009
  • 323 Answers
SOURCE: how do i use the automatic buttonhole on kenmore 19233??
Your machine should have a special buttonhole foot which has a place to insert a button, You will probably have to pull on opposite ends of the foot to open it. Place the button in the foot and then squeeze it together to make the button secure. Attach the foot to the machine. It should snap on.
looking at the left side of the machine you will see your needle bar at the front and the presser foot bar at the back. You should also see another lever which needs to be pulled down so that it rests in the buttonhole foot.Select buttonhole on your machine and it should sew. The button determines how long the buttonhole is.
Sewman7
Posted on Jun 05, 2008
SewExpress
  • 41 Answers
SOURCE: machine made buttonholes.
Hi - we both worked for Pfaff for years and would love to help. Can you provide specific on the problems you are experiencing, i.e. is the fabric bunching, the beginning and end not lining up, more dense on one side than the other... just as much detail as you can. We'll do our best to help you figure out how to get your perfect buttonholes. Kim & Linnette
Posted on Jun 13, 2008
  • 192 Answers
SOURCE: Buttonholes
Put on the C foot. Select the buttonhole stitch. The machine will start sewing in the bottom left corner of the the buttonhole. Sew the length that you need, press and release the reverse button and sew the right side of the buttonhole. When you get back to the bottom, press and release the reverse button again and the buttonhole will be finished and the thread will tie off and the machine will stop. If the buttonhole is what you want, press and release the Stop button and the machine will repeat this buttonhole as many times as you need until the machine is turned off or the Stop is pressed again. When repeating, you need not press the reverse. Just press down on the foot control and continue until the machine stops by itself.
If you don't like the first one, just sew another one using the reverse button to set the ends.
Posted on Oct 02, 2008
  • 55 Answers
SOURCE: pfaff hobby 1142. only goes one way, does not
it sounds like the buttonhole mechanism is seized up or gummed up with old grease. try following the linkages for buttonhole mechanism or button to see you can locate the stuck linkage.
otherwise it sounds like a tech job.
scott.
Posted on Jul 28, 2009
I can not get the automatic button hole to work properly on my Janome 6019.
Hello what is the machine doing
for example i have a 5018 with mine there is a lever at the back to pull down which when it finishes half it stops and resets itself to complete the other side and stops when complete but need the button in the compartment to guide for sizing
i will do a video clip on my channel send more info to mysteria21@gmail.com
Feb 25, 2015 | Janome Sewing Machines
My buttonhole foot does not seem to be working on my pfaff ambition 1.5. All buttonholes end up the same size even though I change the gauge at the back of the foot. Anyone else had this issue? How di
If it's a digital machine try turning it off and on. Otherwise it might have a software problem and you will have to take it to be fixed.
Sep 13, 2014 | Sewing Machines
I have a performance 2054, and it's not making the buttonholes. missing the stitches
SKIPPED STITCHES
1.the needle is not inserted correctly
2.the needle is damaged
3.the wrong size needle is being used
4.the foot is not attached correctly
Sep 18, 2012 | PfaFF Sewing Machines
Buttonhole feature
try changing the needle
make sure the button hole lever is pulled down, it should be on the left
hand side of the needle, if your machine has one
it's also possible that the machine needs to be checked to see if
there is something wrong with a gear or just needs some type of
adjust inside of the machine
Sep 04, 2012 | PfaFF Sewing Machines
Just purchased a Singer 4423 machine, need more detailed instructions for buttonholes
when you press the button hole option & then pull the button hole lever
down it will rest against the button hole foot, having the button in the
button hole foot help the machine gage the size the button hole needs
to be, if the machine keeps on sewing & doesn't stop automaticily then
there is something wrong with the button hole option.
Jul 18, 2012 | Singer 4423 Sewing Machine
Pfaff 2170 will not make consistently sized buttonholes
Go to the following site regarding timing your machine. Are you placing a button in the buttonhole foot so the machine "knows" how long to make the buttonhole? If you have a button stop lever to the left of your needle bar, are you pulling it down and putting it in FRONT of the button stop so it can complete the rotation?
Try www.fixsewingmachine.com
Try http://www.manualowl.com
Apr 13, 2012 | PfaFF Sewing Machines
Pfaff hobby 1142. only goes one way, does not complete buttonhole.
scott.
Jul 28, 2009 | PfaFF Hobby 4260
Machine made buttonholes.
Here ya go! For 1 Step Automatic Buttonholes: 1. Place button into the buttonhole attachment. 2. Push slider to hold button securely in the slot. The button goes to the back! 3. Put button foot onto needle bar--just attach it securely. 4. Place needle thread and bobbin thread UNDER buttonhole attachment and let 4"-5" of thread trail behind it. 5. There's a lever called a Button Stop to the left of the needle bar. Give it a gentle tug and pull it down. Pull forward. Hear a click? Now the machine knows what length to STOP sewing! 6. Put foot on pedal and machine will sew barrack closest to you first. It will continue all around until it makes complete rotation of each side. 7. You must do these steps for each of your buttonholes! IMPORTANT: Make sure you set your dial for making buttonhole pattern because that "tells" machine to zig zag, and use appropriate size needle for the particular weight of your fabric. A new needle before you begin is recommended. Turn screw on needlebar to loosen screw. Hold it so it does not slip down into the feed dog area! New needle is inserted flat shank toward back of needlebar as far as it will go. Tighten screw. Did this help? Hope so!
Jimmy
Mar 03, 2008 | PfaFF Tiptronic 2030
Button holes
Hi
Are you using a Pfaff 7570 (or other Pfaff machine with Sensor)? If so, definitely use the sliding buttonhole foot and the sensor guide (slides below the needle plate from the back of the machine. This will keep your buttonholes consistent.
The size is regulated by the Stitch/Pattern Length button and Width button. Select the size you think you'll need (in millimeters).
Test sew your buttonhole on the EXACT same combination of fabric/layers & stabilizer that your garment is. Adjust the length/width of buttonhole if needed. I would recommend a bit wider buttonhole due to the thickness/puffiness of the fleece.
Hope this helps,
Kim
Jan 25, 2008 | PfaFF Creative 7570
Sewing Machines Logo
1,219 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
